13th August 2008, 16:01 | #461 | Link |
No it isn't. What you want is not the metric that adapts to encoding algorithm, but the metric that simulates your eyes (with algo specific metric, you can't compare algorithms and settings, which is what you want to do). And there is no such metric in existence. Furthermore existence of mathematical objects/concepts is a fundamental problem it is certainly doesn't follow from some "definition" nor can you assume existence most of the time.
Geforce GTX 260 Windows 7, 64bit, Core i7 MPC-HC, Foobar2000 |
13th August 2008, 16:01 | #462 | Link |
brontosaurusrex
lexor, you are right, however i was trying to avoid any filters in the chain (especially if there is a chance of additional posterization by filter itself).
p.s. looks correct with coreavc where input&output are set to auto.
certain other member Last edited by smok3; 13th August 2008 at 16:07. |
13th August 2008, 16:08 | #463 | Link |
Yeah, that stuff is always a trade off, the only reason I noticed is because wrong colour scale really shows up on my lcd. So I just have a habit for personal use to prioritize colour correction over everything else. The trailer still looks awesome though, I noticed it gets better as it goes to. In the intro, after tree with the birds disappears and the red line appears you can see a quick blocky flash in the bottom half of the frame, never happens again after that. I wonder if that's in the source?
13th August 2008, 16:13 | #464 | Link |
brontosaurusrex
lenox, check the 720p 'original';
http://www.apple.com/trailers/lions_gate/thespirit/ edit: another test, fast 2pass encoding, looks great http://somestuff.org/flashAVC/flvpla...-x1280y544.mp4 (trailer for the movie 'australia' seems to be a good partybreaker, when trying to encode at sub 2k bitrates, probably due to bunch of dissolves?) q: if i use the compile 'x264.928.modified.02.exe' then --trellis 2 = psytrellis ?
certain other member Last edited by smok3; 13th August 2008 at 17:42. |
13th August 2008, 19:19 | #467 | Link |
Software Developer
Good news
13th August 2008, 19:24 | #468 | Link |
Will there be a chance to use PsyRDO without Psy Trellis when commited? Old movies usually have lots of noise and/or grain and don't have many details (probably similar to 300). For the bitrates I'm using PsyRDO seems to be great on every kind of source, but PsyRDO+Psy Trellis is not so great on those old movies unless I use a more bitrate.
edit: I haven't tried using Psy Trellis with a 'lowered' PsyRDO and/or 'lowered' AQ |
13th August 2008, 19:52 | #471 | Link | |
13th August 2008, 21:27 | #472 | Link |
Insane Encoder
it will be good if we are able to desactivate psy-trellis when we use psy-rdo.
Because psy-trellis isn't very usefull on anime. He try to conserve details that are invisible (or even not existing at all) and include some ringing (even at high bitrate). |
13th August 2008, 22:02 | #475 | Link |
Not on most anime, but some of the newer ones that are broadcast in HD have artificial grain added to them like the movies shot all digital do (not quite as much though). So psy-rd is becoming useful for anime.
13th August 2008, 22:02 | #476 | Link | |
x264 developer
I may switch --psy-rd as a parameter though from --psy-rd X to --psy-rd X:Y; this will allow you to tweak both psy-RD and psy-trellis. |
13th August 2008, 22:52 | #478 | Link |
Is there any sort of "Holey bible for the x264 settings) ?
Currently there are so many options, and many exceptions like "Never use option x with option y" that most not-so-knowledged users are completely loosing sight on how to correctly encode using x264 ? |
13th August 2008, 22:54 | #479 | Link | |
x264 developer
13th August 2008, 23:07 | #480 | Link |
Software Developer
That's why MeGUI provides various pre-defined profiles from "Fast" up to "Insane"
psy-rd, psyrdo |
