Old 16th November 2006, 00:11   #241  |  Link
agressiv
Registered Loser
agressiv's Avatar
Originally Posted by TinTinFan View Post
With the latest build I get this message in deint.log again.
Error: Error calling AVIStreamGetFrameOpen
decomb and TIVTC are the version I tried with yesterday
Any new ideas?
I used to get this as well. I traced it back to something missing on the client. After I installed AutoGK (notypo, really, AutoGK) with the XVID library this went away.
I did some registry traces and there is some reference to:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Drivers\vidc.XVID
...that its looking for. Why, I dont know. I just know that when this stub appeared here, baudodeint.exe started working.
YMMV
agressiv
agressiv is offline
Old 16th November 2006, 08:13   #242  |  Link
buzzqw
HDConvertToX author
i have
vidc.XVID
in HKLM\Software\Microsoft\Windows NT\CurrentVersion\Drivers32\ (using WinXp Pro SP2)
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 16th November 2006, 12:43   #243  |  Link
TinTinFan
Thanks for the advice guys! I tried to install AutoGK with XVID codec.
It seems to be okay now! But I have no idea how Xvid vfw can affect bautodeint.exe.
TinTinFan is offline
Old 16th November 2006, 14:30   #244  |  Link
weaver4
I think something else may be wrong with the Xvid-CQ. I did a movie and was surprised that it was only 611Meg so I did the same movie with AutoGK, avi.net and MPEG Mediator with a quantizer of 2.5 and the movie size came out 825Meg, 818Meg and 829Meg; much bigger than the 2.5cq version of AutoMKS.
What should I look at to help you debug this?
weaver4 is offline
Old 16th November 2006, 14:37   #245  |  Link
buzzqw
HDConvertToX author
check resolution, matrix, filter... and, as always post the log
btw: have you answered "Unlimited media size" or "Hit media size" ?... since is 611 mb +audio =~ 1CD
BHH
buzzqw is offline
Old 16th November 2006, 14:59   #246  |  Link
weaver4
The resolution was 640x272 on all of them. I used the default sharktooth Matrix (Sharktooth's EQM v3ULR.cqm) and here is the log file. I selected "unlimited media size"
12:50:16 0.51 - - - - - START JOBS - - - - - - - - - - - - -
12:50:16 Selected Input file: E:\Movies\DVDFabRip\MainMovie\CRASH\VIDEO_TS\VTS_01_0.IFO
12:50:16 Selected Output dir: E:\Movies\Output\
12:50:16 Selected Container type: AVI
12:50:16 Selected Size: 1 CD
12:50:16 Selected Slice: 1
12:50:16 Selected Encoder: XviD
12:50:16 Selected Profile: XviD_CQ.xml
12:50:16 Selected Width: 640
12:50:16 Selected Resizer: SimpleResize
12:50:16 Selected Filters: RemoveGrain(mode=2)
12:50:16 Selected Deinterlacer: AUTO
12:50:16 NeroAACEnc.exe not present
12:50:16 Enabled CRF/CQ autoresize with value 2.5
12:50:16 Track Language 1: English (AC3 6ch, 0xBD 0x80) [0]
12:50:16 Audio Codec 1: Lame
12:50:16 Audio Quality 1: 6
12:50:16 Starting Indexing
12:50:16 Dgindex CMD: C:\Downloads\AutoMKV\AutoMKV051\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=1 -YR=2 -AIF=[E:\Movies\DVDFabRip\MainMovie\CRASH\VIDEO_TS\VTS_01_1.vob] -OF=[E:\Movies\Output\movie] -exit -minimize
12:52:43 Finished indexing
12:52:43 Starting fixing audio delay on track number 1
12:52:43 DelayCut CMD: C:\Downloads\AutoMKV\AutoMKV051\exe\dgindex\Delaycut.exe -auto -out "E:\Movies\Output\fixed1.ac3" "E:\Movies\Output\movie T01 3_2ch 448Kbps DELAY 0ms.ac3"
12:53:01 Original 1' Audio Size: 377871872 bytes
12:53:02 Finished fixing audio delay
12:53:02 Encoding E:\Movies\Output\fixed1.ac3 To Mp3 with 6 quality
13:16:24 Encoded 1' Audio Track: 67682290 bytes
13:16:24 ForcedFilm applied: 99.300003% FILM found
13:16:32 Number of Frames: 161784
13:16:32 Framerate: 23.976025
13:16:32 Movie lenght in Seconds: 6748
13:16:32 Movie Width: 720
13:16:32 Movie Height: 480
13:16:32 CQ encoding XviD: C:\Downloads\AutoMKV\AutoMKV051\exe\encoder\xvid_encraw.exe -cq 2.5 -progress -threads 1 -max_bframes 2 -imax 31 -quality 6 -vhqmode 1 -qtype 0 -pmax 31 -bmax 31 -bquant_ratio 162 -nochromame -noclosed_gop -bvhq -qmatrix "C:\Downloads\AutoMKV\AutoMKV051\profiles\XviD-profiles\matrix\Sharktooth's EQM v3ULR.cqm" -i "E:\Movies\Output\movie.avs" -type 2 -avi "E:\Movies\Output\movie.avi"
14:52:21 Accepted values are between 697303040 and 741343232 bytes (movie+audio)
14:52:21 Got a file of size: 565409520 bytes + audio size 67682290 bytes (633091840)
14:52:21 Only Movie Size: 565409520 bytes
14:53:10 Final Muxed size: -1 bytes
14:53:10
14:53:10 Muxing Script
14:53:10 C:\Downloads\AutoMKV\AutoMKV051\exe\matroska\AVIMux_GUI.exe E:\Movies\Output\muxavi
14:53:10
14:53:10 CLEAR
14:53:10 LOAD E:\Movies\Output\movie.avi
14:53:10 LOAD E:\Movies\Output\audio.mp3
14:53:10 SELECT FILE 1
14:53:10 ADD VIDEOSOURCE
14:53:10 SET INPUT OPTIONS
14:53:10 SET OPTION MP3 VERIFY CBR NEVER
14:53:10 SET OPTION MP3 VERIFY RESDLG OFF
14:53:10 SET OUTPUT OPTIONS
14:53:10 WITH SET OPTION
14:53:10 OPENDML 0
14:53:10 RECLISTS 0
14:53:10 AUDIO INTERLEAVE 3 FR
14:53:10 AVI ADDJUNKBEFOREHEADERS 0
14:53:10 PRELOAD 200
14:53:10 WITH AUDIO
14:53:10 NAME 1 english
14:53:10 END WITH
14:53:10 OVERWRITEDLG 0
14:53:10 CLOSEAPP 1
14:53:10 DONEDLG 0
14:53:10 ALL AUDIO 1
14:53:10 LEGACY 0
14:53:10 RECLISTS 1
14:53:10 NUMBERING OFF
14:53:10 MAXFILESIZE OFF
14:53:10 END WITH
14:53:10 START E:\Movies\Output\movie_full.avi
14:53:10
14:53:10 Script AutoCrop.log
14:53:10
14:53:10 Crop(10,58,700,368)
14:53:10
14:53:10 Script Resmovie.avs
14:53:10
14:53:10
14:53:10 Script movie.avs
14:53:10
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\autocrop.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\blockbuster.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\cnr2.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\ColorMatrix.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\Convolution3D.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\corrector.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\DctFilter.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\Decomb.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\Deen.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\degrainmedian.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\DGDecode.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\EEDI2.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\fft3dfilter.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\FluxSmooth.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\frfun7.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\hqdn3d.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\LeakKernelDeint.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\MaskTools.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\medianblur.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\MipSmooth.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\mvtools.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\NicAudio.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\RemoveGrain.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\SangNom.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\SimpleResize.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\TBilateral.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\TDeint.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\TIVTC.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\TomsMoComp.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\TTempSmooth.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\UnDot.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\UnFilter.dll")
14:53:10 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\VSFilter.dll")
14:53:10 #loadpluginstart
14:53:10
14:53:10 #test1
14:53:10
14:53:10 Import("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\mvbob.avsi")
14:53:10 Import("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\QMF.avsi")
14:53:10 #importstart
14:53:10
14:53:10 #test2
14:53:10
14:53:10 movie = mpeg2source("E:\Movies\Output\movie.d2v")
14:53:10 function getOrder(clip c) {
14:53:10 order = GetParity(c) ? 1 : 0
14:53:10 Return order }
14:53:10 #filter1start
14:53:10
14:53:10 #test3
14:53:10
14:53:10 #cropstart
14:53:10
14:53:10 cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=0,threshold=34,samplestartframe=0)
14:53:10 fixed_aspect = 1.185185
14:53:10 c_width = width(cropclip)
14:53:10 c_height = Round(height(cropclip) / fixed_aspect)
14:53:10 input_par = float(float(c_width)/float(c_height))
14:53:10 input_par = input_par > 1.4 ? input_par : (4.0/3.0)
14:53:10 out_width = 640
14:53:10 out_height = Round(float(out_width) / input_par)
14:53:10 hmod = out_height - (floor(out_height / 16 ) * 16)
14:53:10 out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
14:53:10 new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
14:53:10 autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=new_aspect,threshold=34,samplestartframe=0)
14:53:10
14:53:10 #resizestart
14:53:10
14:53:10 #test4
14:53:10
14:53:10 SimpleResize(out_width,out_height)
14:53:10 #filter2start
14:53:10
14:53:10 #test5
14:53:10
14:53:10 RemoveGrain(mode=2)
14:53:10 ColorMatrix("Rec.709->Rec.601",hints=false)
14:53:10
14:53:10 Script mkvmaudio.avs
14:53:10
14:53:10 NicAC3Source("E:\Movies\Output\fixed1.ac3")
14:53:10 EnsureVBRMP3Sync()
14:53:10 ConvertAudioTo16bit()
14:53:10 #Applyed Stereo downmixing routines
14:53:10 function stereo(clip a)
14:53:10 {
14:53:10 fl = GetChannel(a, 1)
14:53:10 fr = GetChannel(a, 2)
14:53:10 c = GetChannel(a, 3)
14:53:10 lfe = GetChannel(a, 4)
14:53:10 sl = GetChannel(a, 5)
14:53:10 sr = GetChannel(a, 6)
14:53:10 l_sl = MixAudio(fl, sl, 0.2929, 0.2929)
14:53:10 c_lfe = MixAudio(lfe, c, 0.2071, 0.2071)
14:53:10 r_sr = MixAudio(fr, sr, 0.2929, 0.2929)
14:53:10 l = MixAudio(l_sl, c_lfe, 1.0, 1.0)
14:53:10 r = MixAudio(r_sr, c_lfe, 1.0, 1.0)
14:53:10 Return MergeChannels(l, r).Normalize()
14:53:10 }
14:53:10 #
14:53:10 function original(clip a)
14:53:10 {
14:53:10 Normalize(a)
14:53:10 Return last
14:53:10 }
14:53:10 6==Audiochannels() ? stereo() : original()
14:53:10
14:53:10 Script mkvmaudio.bat
14:53:10
14:53:10 "C:\Downloads\AutoMKV\AutoMKV051\exe\besweet\bepipe.exe" --script "Import(^E:\Movies\Output\mkvmaudio.avs^)" | "C:\Downloads\AutoMKV\AutoMKV051\exe\besweet\lame.exe" -v --vbr-new -h -S -V 6 - "E:\Movies\Output\audio.mp3"
14:53:10
14:53:10 Script mkvmaudio2.avs
14:53:10
14:53:10
14:53:10 Script mkvmaudio2.bat
14:53:10
14:53:10
14:53:10 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - -
weaver4 is offline
Old 16th November 2006, 15:13   #247  |  Link
buzzqw
HDConvertToX author
it's all ok (on automkv side). i can suppose that autgk use a different xvid configuration, maybe bquant_ratio (1.62) or BQuantOffset (1.00)...
BHH
buzzqw is offline
Old 16th November 2006, 15:31   #248  |  Link
weaver4
BHH
Thanks, I will compare the quality of the encodes tonight and let you know the results.
weaver4 is offline
Old 16th November 2006, 16:25   #249  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Hi Buzz,
Just noticed a little "typo" in the audio encoder drop down options.
It currently says: WinAmp CCT. When I think it should say: WinAMP CT.
That said, seeing as though Coding Technologie's (500KB) AAC encoder is now named "enc_aacplus.dll", it might be okay to call it just "Coding Tech. AAC"
By the way, Coding Technologie's AAC encoder offers both AAC-LC and AAC-HE encoding
SeeMoreDigital is offline
Old 17th November 2006, 03:43   #250  |  Link
weaver4
On the latest version it does not appear to be saving all the settings. For example if forgets that my audio codec is Lame, but it does remember the setting is 4 for the audio codec. It also forgets that I selected XviD, and the XviD-CQ profile and such.
weaver4 is offline
Old 17th November 2006, 07:27   #251  |  Link
buzzqw
HDConvertToX author
on my side save default is ok. Delete old automkv.ini and save a new one. if you have the error again please post here your automkv.ini , i will load it and check.
btw what you mean by "but it does remember the setting is 4 for the audio codec" ? bitrate ?
thanks
BHH
buzzqw is offline
Old 17th November 2006, 23:57   #252  |  Link
weaver4
Here you go this is after I deleted the automkv.ini file.
Here are the Setting when I hit the Save Settings buttons
Output Folder
E:\Movies\Output
Audio Track 1
Lame
Quality - 4
Resizer
Set Width Resolution 640
Container - AVI
Codec - XviD
Profile - XviD_CQ.xml
Movie Name - movie
Disk Settings: 1 DVD-R (grayed out)
After Quiting AutoMKV 0.51 and restarting it I get the following
Output Folder
E:\Movies\DVDFabRip\MainMovie\X3\VIDEO_TS\
Audio Track 1
Nero ACC
Quality - .55
Resizer
Container - AVI
Codec - X264
Profile - 1P-Intermediate.xml
Movie Name - movie
Disk Settings: 1 DVD-R (not grayed out)
Here is the INI file.
; AutoMKV default parameters
; If AutoMKV.ini is present then specified parameters will be loaded
[AutoMKV]
Container = 2
Size = 1 DVD-R
Slice = 1
Resizer = 2
Width = 640
Set encoding mode = 0
Audio Codec 1 = 1
Audio Bit 1 = 11
Audio Channel 1 = 1
Audio Codec 2 = 1
Audio Bit 2 = 7
Audio Channel 2 = 1
Encoding Profiles = 1
Bitrate Encoding = 0
Bitrate Value = 700
Delete temporary files = 1
Encrust/Burn Subtitles = 0
Enable Shutdown = 0
Episodic DVD = 0
Force ITU Resizing = 0
Anamorphic Encoding = 0
Filter = RemoveGrain(mode=2)
Enable Last Line AVS Script = 0
Deinterlacer = AUTO
Language = eng
weaver4 is offline
Old 18th November 2006, 10:17   #253  |  Link
buzzqw
HDConvertToX author
update to 0.51a
www.64k.it/andres/data/a/AutoMKV051a.exe
Fixed: XviD CQ profile now read the value of CQ from profile
Fixed: renamed audio codec "Winamp CCT" to "Coding Tech. AAC" (thanks to SMD for suggesting)
Fixed: In log the final muxed size of AVI+XviD wasn't reported
Fixed: save default with new XviD profiles was broken (thanks to weaver4 for reporting)
Added: in log file is now reported if cor CQ/CRF profile, the media size is unlimited or fixed
buzzqw is offline
Old 19th November 2006, 01:43   #254  |  Link
travisbell
Hey man,
I had this problem before but I am not sure why it went away, but is now back.
I have linked my log here, but for whatever reason at the end of 2 days of encoding no .mkv file is created... I can't seem to see any problems from the .log file so here it is. Hopefully you can explain why it didn't work.
http://consumeroo.com/files/little.m...0i.dd20.ts.txt
Thanks man!
Travis Bell
Consumeroo!
travisbell is offline
Old 19th November 2006, 04:06   #255  |  Link
weaver4
I am having a problem where I put multiple files into the queue and then start the queue and the AutoMKS51a application disappears. It still runs, I can see it in the task manager and all of the "child" programs still run but the window is missing from the screen. There is no entry in the TaskBar either.
I am running WindowsXP.
weaver4 is offline
Old 19th November 2006, 10:34   #256  |  Link
buzzqw
HDConvertToX author
no mkv is created 'cause no audio is created.
In log file your audio is "PID 1001, Private AC3 Audio Stream 1" but when dgindex demux it search "-AP=001" , so the walue is wrong "1" is missing.
Why ? i never found pid over 1000... (and btw i have only 2 s streams to test...)
try this build should be bulletproof to audio pid (and video pid): www.64k.it/andres/data/a/AutoMKV051b.exe
A BIG Thanks for reporting !
it's know. i will work on this when my knowledge of programming will be better.
BHH
buzzqw is offline
Old 19th November 2006, 19:52   #257  |  Link
travisbell
Trying it now... I will let you know if it's smooth sailing from here on in...
THANKS!
Travis Bell
Consumeroo!
Old 19th November 2006, 22:40   #258  |  Link
TinTinFan
I am not sure how episodic DVD in advanced settings is working. I have an episodic DVD and I see different PGC:s for each episode.
But when I try to encode an episode the entire DVD is encoded to 1 movie.
If I check Episodic DVD in advanced settings nothing seems to happen.
What am I doing wrong?
Old 20th November 2006, 08:49   #259  |  Link
buzzqw
HDConvertToX author
i have few epsodic dvd to test... anyway do this:
lauch automkv
go in advance and check episodic dvd
on main click on INPUT and browse to your IFO to process
set application as you want and click start
PGC selection is actually used only for subtitles extraction.
But i think that selectiong pgc "could" be like selecting different ifo... i will work on this
BHH
buzzqw is offline
Old 22nd November 2006, 02:02   #260  |  Link
weaver4
OK here is a really good one. I am using a profile that is for XviD single pass quantizer of three. But when I encode the log file says the quantizer is set to 18. It is encoding with a quantizer of 18 because the file is tiny. Below are the profile and the log file.
Profile
<?xml version="1.0"?>
<VideoProfile xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<Name>cq</Name>
<Settings xsi:type="xvidSettings">
<EncodingMode>1</EncodingMode>
<BitrateQuantizer>3</BitrateQuantizer>
<KeyframeInterval>300</KeyframeInterval>
<NbBframes>2</NbBframes>
<MinQuantizer>2</MinQuantizer>
<MaxQuantizer>31</MaxQuantizer>
<Turbo>false</Turbo>
<V4MV>false</V4MV>
<QPel>false</QPel>
<Trellis>true</Trellis>
<CreditsQuantizer>12</CreditsQuantizer>
<FourCCs>
<string>XVID</string>
<string>DIVX</string>
<string>DX50</string>
<string>MP4V</string>
</FourCCs>
<Logfile>.stats</Logfile>
<CustomEncoderOptions />
<FourCC>0</FourCC>
<Zones />
<MaxNumberOfPasses>2</MaxNumberOfPasses>
<NbThreads>1</NbThreads>
<MotionSearchPrecision>6</MotionSearchPrecision>
<VHQMode>1</VHQMode>
<QuantType>0</QuantType>
<MinPQuant>2</MinPQuant>
<MaxPQuant>31</MaxPQuant>
<MinBQuant>2</MinBQuant>
<MaxBQuant>31</MaxBQuant>
<BQuantRatio>162</BQuantRatio>
<BQuantOffset>100</BQuantOffset>
<KeyFrameBoost>10</KeyFrameBoost>
<KeyframeThreshold>1</KeyframeThreshold>
<KeyframeReduction>20</KeyframeReduction>
<OverflowControlStrength>5</OverflowControlStrength>
<MaxOverflowImprovement>5</MaxOverflowImprovement>
<MaxOverflowDegradation>5</MaxOverflowDegradation>
<HighBitrateDegradation>0</HighBitrateDegradation>
<LowBitrateImprovement>0</LowBitrateImprovement>
<ReactionDelayFactor>16</ReactionDelayFactor>
<AveragingPeriod>100</AveragingPeriod>
<FrameDropRatio>0</FrameDropRatio>
<RateControlBuffer>0</RateControlBuffer>
<VbvPeakRate>0</VbvPeakRate>
<VbvMaxRate>0</VbvMaxRate>
<VbvBuffer>0</VbvBuffer>
<PackedBitstream>false</PackedBitstream>
<GMC>false</GMC>
<ChromaMotion>true</ChromaMotion>
<ClosedGOP>true</ClosedGOP>
<VHQForBframes>true</VHQForBframes>
<AdaptiveQuant>true</AdaptiveQuant>
<Greyscale>false</Greyscale>
<Interlaced>false</Interlaced>
<BottomFieldFirst>true</BottomFieldFirst>
<LumiMasking>false</LumiMasking>
<BframeThreshold>0</BframeThreshold>
<CustomQuantizerMatrix>extra\Sharktooth's EQM v3ULR.cqm</CustomQuantizerMatrix>
</Settings>
</VideoProfile>
Log File
18:14:06 0.51a - - - - - START JOBS - - - - - - - - - - - - -
18:14:06 Selected Input file: E:\Movies\DVDFabRip\MainMovie\KILLBILL_VOL1\VIDEO_TS\VTS_01_0.IFO
18:14:06 Selected Output dir: E:\Movies\Output\
18:14:06 Selected Container type: AVI
18:14:06 Selected Size: 1 DVD-R
18:14:06 Selected Slice: 1
18:14:06 Selected Encoder: XviD
18:14:06 Selected Profile: XviD_CQ30.xml
18:14:06 Selected Width: 640
18:14:06 Selected Resizer: SimpleResize
18:14:06 Selected Filters: RemoveGrain(mode=2)
18:14:06 Selected Deinterlacer: AUTO
18:14:06 NeroAACEnc.exe not present
18:14:06 Enabled CRF/CQ autoresize with value 18
18:14:06 Track Language 1: English (AC3 6ch, 0xBD 0x80) [0]
18:14:06 Audio Codec 1: Lame
18:14:06 Audio Quality 1: 4
18:14:06
18:14:06 Starting SubRipping
18:15:31 Selected subtitle tracks: English 0 (0xBD 0x20) [0] wide
18:15:31 Finished SubRipping
18:15:31 Subtitle Size: 425984 bytes
18:15:31 Starting Indexing
18:15:31 Dgindex CMD: C:\Downloads\AutoMKV\AutoMKV051\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=1 -YR=2 -AIF=[E:\Movies\DVDFabRip\MainMovie\KILLBILL_VOL1\VIDEO_TS\VTS_01_1.vob] -OF=[E:\Movies\Output\movie] -exit -minimize
18:17:12 Finished indexing
18:17:12 Starting fixing audio delay on track number 1
18:17:12 DelayCut CMD: C:\Downloads\AutoMKV\AutoMKV051\exe\dgindex\Delaycut.exe -auto -out "E:\Movies\Output\fixed1.ac3" "E:\Movies\Output\movie T01 3_2ch 448Kbps DELAY 0ms.ac3"
18:17:24 Original 1' Audio Size: 372006656 bytes
18:17:24 Finished fixing audio delay
18:17:24 Encoding E:\Movies\Output\fixed1.ac3 To Mp3 with 4 quality
18:38:00 Encoded 1' Audio Track: 106714704 bytes
18:38:00 ForcedFilm applied: 99.800003% FILM found
18:38:06 Number of Frames: 159274
18:38:06 Framerate: 23.976025
18:38:06 Movie lenght in Seconds: 6644
18:38:06 Movie Width: 720
18:38:06 Movie Height: 480
18:38:07 CQ encoding XviD: C:\Downloads\AutoMKV\AutoMKV051\exe\encoder\xvid_encraw.exe -cq 18 -progress -threads 1 -max_bframes 2 -imax 31 -quality 6 -vhqmode 1 -qtype 0 -pmax 31 -bmax 31 -bquant_ratio 162 -nochromame -noclosed_gop -bvhq -qmatrix "C:\Downloads\AutoMKV\AutoMKV051\profiles\XviD-profiles\matrix\Didees SixOfNine.cqm" -i "E:\Movies\Output\movie.avs" -type 2 -avi "E:\Movies\Output\movie.avi"
19:49:44 Accepted values are between 4461743104 and 4743537664 bytes (movie+audio)
19:49:44 Got a file of size: 147092958 bytes + audio size 106714704 bytes (254020656)
19:49:44 Only Movie Size: 147092958 bytes
19:49:44 Selected Subtitle Track: English 0 (0xBD 0x20) [0] wide
19:50:14 Final Muxed size: -1 bytes
19:50:14
19:50:14 Muxing Script
19:50:14 C:\Downloads\AutoMKV\AutoMKV051\exe\matroska\AVIMux_GUI.exe E:\Movies\Output\muxavi
19:50:14
19:50:14 CLEAR
19:50:14 LOAD E:\Movies\Output\movie.avi
19:50:14 LOAD E:\Movies\Output\audio.mp3
19:50:14 SELECT FILE 1
19:50:14 ADD VIDEOSOURCE
19:50:14 SET INPUT OPTIONS
19:50:14 SET OPTION MP3 VERIFY CBR NEVER
19:50:14 SET OPTION MP3 VERIFY RESDLG OFF
19:50:14 SET OUTPUT OPTIONS
19:50:14 WITH SET OPTION
19:50:14 OPENDML 1
19:50:14 RECLISTS 0
19:50:14 AUDIO INTERLEAVE 3 FR
19:50:14 AVI ADDJUNKBEFOREHEADERS 0
19:50:14 PRELOAD 200
19:50:14 WITH AUDIO
19:50:14 NAME 1 english
19:50:14 END WITH
19:50:14 OVERWRITEDLG 0
19:50:14 CLOSEAPP 1
19:50:14 DONEDLG 0
19:50:14 ALL AUDIO 1
19:50:14 LEGACY 0
19:50:14 RECLISTS 1
19:50:14 NUMBERING OFF
19:50:14 MAXFILESIZE OFF
19:50:14 END WITH
19:50:14 START E:\Movies\Output\killbill1_full.avi
19:50:14
19:50:14 Script AutoCrop.log
19:50:14
19:50:14 Crop(2,60,716,356)
19:50:14
19:50:14 Script Resmovie.avs
19:50:14
19:50:14
19:50:14 Script movie.avs
19:50:14
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\autocrop.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\blockbuster.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\cnr2.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\ColorMatrix.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\Convolution3D.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\corrector.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\DctFilter.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\Decomb.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\Deen.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\degrainmedian.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\DGDecode.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\EEDI2.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\fft3dfilter.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\FluxSmooth.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\frfun7.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\hqdn3d.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\LeakKernelDeint.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\MaskTools.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\medianblur.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\MipSmooth.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\mvtools.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\NicAudio.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\RemoveGrain.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\SangNom.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\SimpleResize.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\TBilateral.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\TDeint.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\TIVTC.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\TomsMoComp.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\TTempSmooth.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\UnDot.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\UnFilter.dll")
19:50:14 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\VSFilter.dll")
19:50:14 #loadpluginstart
19:50:14
19:50:14 #test1
19:50:14
19:50:14 Import("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\mvbob.avsi")
19:50:14 Import("C:\Downloads\AutoMKV\AutoMKV051\exe\filter\QMF.avsi")
19:50:14 #importstart
19:50:14
19:50:14 #test2
19:50:14
19:50:14 movie = mpeg2source("E:\Movies\Output\movie.d2v")
19:50:14 function getOrder(clip c) {
19:50:14 order = GetParity(c) ? 1 : 0
19:50:14 Return order }
19:50:14 #filter1start
19:50:14
19:50:14 #test3
19:50:14
19:50:14 #cropstart
19:50:14
19:50:14 cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=0,threshold=34,samplestartframe=0)
19:50:14 fixed_aspect = 1.185185
19:50:14 c_width = width(cropclip)
19:50:14 c_height = Round(height(cropclip) / fixed_aspect)
19:50:14 input_par = float(float(c_width)/float(c_height))
19:50:14 input_par = input_par > 1.4 ? input_par : (4.0/3.0)
19:50:14 out_width = 640
19:50:14 out_height = Round(float(out_width) / input_par)
19:50:14 hmod = out_height - (floor(out_height / 16 ) * 16)
19:50:14 out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
19:50:14 new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
19:50:14 autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=new_aspect,threshold=34,samplestartframe=0)
19:50:14
19:50:14 #resizestart
19:50:14
19:50:14 #test4
19:50:14
19:50:14 SimpleResize(out_width,out_height)
19:50:14 #filter2start
19:50:14
19:50:14 #test5
19:50:14
19:50:14 RemoveGrain(mode=2)
19:50:14 ColorMatrix("Rec.709->Rec.601",hints=false)
19:50:14
19:50:14 Script mkvmaudio.avs
19:50:14
19:50:14 NicAC3Source("E:\Movies\Output\fixed1.ac3")
19:50:14 EnsureVBRMP3Sync()
19:50:14 ConvertAudioTo16bit()
19:50:14 #Applyed Stereo downmixing routines
19:50:14 function stereo(clip a)
19:50:14 {
19:50:14 fl = GetChannel(a, 1)
19:50:14 fr = GetChannel(a, 2)
19:50:14 c = GetChannel(a, 3)
19:50:14 lfe = GetChannel(a, 4)
19:50:14 sl = GetChannel(a, 5)
19:50:14 sr = GetChannel(a, 6)
19:50:14 l_sl = MixAudio(fl, sl, 0.2929, 0.2929)
19:50:14 c_lfe = MixAudio(lfe, c, 0.2071, 0.2071)
19:50:14 r_sr = MixAudio(fr, sr, 0.2929, 0.2929)
19:50:14 l = MixAudio(l_sl, c_lfe, 1.0, 1.0)
19:50:14 r = MixAudio(r_sr, c_lfe, 1.0, 1.0)
19:50:14 Return MergeChannels(l, r).Normalize()
19:50:14 }
19:50:14 #
19:50:14 function original(clip a)
19:50:14 {
19:50:14 Normalize(a)
19:50:14 Return last
19:50:14 }
19:50:14 6==Audiochannels() ? stereo() : original()
19:50:14
19:50:14 Script mkvmaudio.bat
19:50:14
19:50:14 "C:\Downloads\AutoMKV\AutoMKV051\exe\besweet\bepipe.exe" --script "Import(^E:\Movies\Output\mkvmaudio.avs^)" | "C:\Downloads\AutoMKV\AutoMKV051\exe\besweet\lame.exe" -v --vbr-new -h -S -V 4 - "E:\Movies\Output\audio.mp3"
19:50:14
19:50:14 Script mkvmaudio2.avs
19:50:14
19:50:14
19:50:14 Script mkvmaudio2.bat
19:50:14
19:50:14
19:50:14 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - -
weaver4 is offline
