Old 30th December 2012, 02:57   #981  |  Link
frencher
French Love
Originally Posted by [SLiM]D12 View Post
I've read this thread, and am a little confused. Basically looking to re-encode 3DBD to 25GB and keep all menus, most audio in tact. I've managed to find another guide, telling me how to use bioset and the biomvc.dll files, but all i get is green video with my right_eye stream. I'm trying to figure out another way to simply my right eye stream to not be green. I use cinevision to encode to mvc using left/right, but like i said, i just want my stream without the green, not even sure where that came from.
Any thoughts on what tools i can use in this thread to basically get uncompressed left and right streams i can feed into cinevision to re-encode?
thx in advance.
http://forum.doom9.org/showthread.ph...95#post1601195
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial
Demo for MVC Player Free: Trailer 3D
3DBD's Free - v0.0.0.0005.exe Old
Programing free for all.
frencher is offline   Reply With Quote
Old 30th December 2012, 03:01   #982  |  Link
[SLiM]D12
thx i've read that post, and understand who the owner is. My question i guess is, what causes the right eye stream to be all green? I read here i think sometimes it's bad fps, but can it be caused by something else?
I tried to decode my streams to left/right using ldecod but i got the error you guys said was related to a bad rip of disc. Not sure what else to go on here, kinda like hitting a wall.
I'm trying MVC to AVI right now to split my MVC to left/right and gonna see if the right avi has green in it. As you all know, it takes a long time and i've run out of space twice while trying this
[SLiM]
[SLiM]D12 is offline   Reply With Quote
Old 30th December 2012, 15:18   #983  |  Link
frencher
French Love
I do not understand the continued use biomvc.dll knowing that "BD3D2AVS" and "MVC Player Free" do it without problems and are much faster
Old 30th December 2012, 15:40   #984  |  Link
frencher
French Love
"MVC Player Free v0.0.0.9" In my signature...
Extract and run MVC Player Free.cmd or play associated file with MVC Player Free.exe
# Added: Left View AVC seekable and Right View MVC. Thank to Nico8583 ;)
# Added: Resizing resolutions (No resize Works if export to x264 , 1920x1080, 1280x720, 720x576, 720x480)
# Some fixes
Old 30th December 2012, 17:58   #985  |  Link
Nico8583
# Some fixes
You're welcome but why thanks to me ?
Nico8583 is online now   Reply With Quote
Old 30th December 2012, 18:42   #986  |  Link
frencher
French Love
This PM, I forgot to activate
Je viens de tester mais j'obtiens un fichier en SBS et dans le menu "Vue" les options vu de gauche et vu de droite sont grisées.
I just tested but I get a file and SBS in the menu "View" options given on the left and saw right are grayed out.
Old 30th December 2012, 20:34   #987  |  Link
Nico8583
this pm, i forgot to activate :d
ok :d
Old 6th January 2013, 11:12   #988  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
BD3D2MK3D v0.13
I forgot to release the latest version of BD3D2MK3D. Sorry!
It should fix some problems with the E-AC3 audio and some subtitle streams of recent BDs (such as Brave 3D). It has also a lot of other fixes and improvements.
# v0.13 (November 21, 2012)
# - New method to demux the streams from the M2TS files (instead of MPLS) to avoid the eac3to crashes with subtitle
    streams in SSIF files.
# - Added the options "seek=false, seekzero=true" in the DirectShowMVCSource commands to avoid the seek crash.
# - New error message when trying to open a non-3D blu-ray.
# - The eac3to error message "This track is not clean" is now processed (but the demux operation continues normally).
# - The console messages are now also printed to the new "BD3D2MK3D.log" file during the main operation.
# - Better BDSup2Sub error message when no captions are found.
# - Fix: When aborting the demux operation, eac3to was not killed.
# - Workaround for the eac3to "Brave 3D" French audio bug: The automatic streams selection tries to avoid
    the AC3 streams @512kbps when another stream is available in the same language.
# - Some small bugs fixed and some GUI enhancements.
Download latest version: BD3D2MK3D.7z
r0lZ
Old 8th January 2013, 01:31   #989  |  Link
frencher
French Love
Nice Update Roland
Old 9th January 2013, 10:18   #990  |  Link
SpaceNerd
Thanks for the update and updating! :-) I noticed that 3D subtitle creation fails if "b-spline" is selected as 3D subtitles resize filter. As a result, the final MKV file does not contain any subtitles:
Done scaling PNG Subtitles
An Error occured in the last command
********** Suppe3D.exe stderr: child process exited abnormally
The default ("bilinear") works, however.
SpaceNerd is offline   Reply With Quote
Old 9th January 2013, 12:57   #991  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
OK, for the next update, I'll remove b-spline from the list. Thanks.
BTW, it's probably not Suppe3D that crashes, but BDSup2Sub++, called by Suppe3D, itself called by BD3D2MK3D.
r0lZ
Old 16th January 2013, 12:34   #992  |  Link
Nico8583
Hi
Does the join SSIF tool of BD3D2MK3D work well ? And could I use in "standalone" mode ?
I would like to join SSIF files on a BD 3D to obtain one SSIF file and use it with DirectShowMVCSource.
Or is it possible to join M2TS of a playlist without problem ?
Old 16th January 2013, 14:08   #993  |  Link
frencher
French Love
"MVC Player Free v0.0.1.0" In my signature...
# Added: Recode x264 2 pass @ 10240 Kbps (temporary) I work to custom x264 preset
# Fixed: AVS Script
# Fixed: False posive (DragnDrop-3D Player.dll)
# Some fixes
Old 16th January 2013, 18:14   #994  |  Link
Nico8583
I have extract raw .h264 from MPLS and there is a difference of frames number between left and right. Is it normal ? How can I solve this ?
command line: "eac3to.exe" "G:\" 1) 1:"E:\Rips\1_1_chapter.txt" 2:"E:\Rips\1_2_video.h264" 3:"E:\Rips\1_3_video.h264" 5:"E:\Rips\1_5_audio.dtshd" 10:"E:\Rips\1_10_subtitle.sup" 12:"E:\Rips\1_12_subtitle.sup" -progressnumbers
M2TS, 2 video tracks, 3 audio tracks, 6 subtitle tracks, 2:16:17, 24p /1.001
1: Chapters, 16 chapters
2: h264/AVC (left eye), 1080p24 /1.001 (16:9)
3: h264/AVC (right eye), 1080p24 /1.001 (16:9)
4: AC3, English, 5.1 channels, 448kbps, 48kHz
5: DTS Master Audio, French, 5.1 channels, 16 bits, 48kHz
(core: DTS, 5.1 channels, 16 bits, 1509kbps, 48kHz)
6: AC3 Surround, English, 2.0 channels, 192kbps, 48kHz
7: Subtitle (PGS), English
8: Subtitle (PGS), Arabic
9: Subtitle (PGS), Dutch
10: Subtitle (PGS), French
11: Subtitle (PGS), Dutch
12: Subtitle (PGS), French
Creating file "E:\Rips\1_1_chapter.txt"...
[s10] Extracting subtitle track number 10...
[v03] Extracting video track number 3...
[v02] Extracting video track number 2...
[s12] Extracting subtitle track number 12...
[a05] Extracting audio track number 5...
[v03] Creating file "E:\Rips\1_3_video.h264"...
[v02] Creating file "E:\Rips\1_2_video.h264"...
[a05] Creating file "E:\Rips\1_5_audio.dtshd"...
[s12] Creating file "E:\Rips\1_12_subtitle.sup"...
[s10] Creating file "E:\Rips\1_10_subtitle.sup"...
Video track 2 contains 196055 frames.
Video track 3 contains 196056 frames.
Old 16th January 2013, 18:18   #995  |  Link
frencher
French Love
Uses the track have more images, here is the track 3: h264/AVC (right eye), 1080p24 /1.001 (16:9)
Old 17th January 2013, 11:23   #996  |  Link
slavanap
slavanap's Avatar
As for CoreAVCdecoder, it always couldn't extract the last frame for right view, so the left view gets one frame larger.
slavanap is offline   Reply With Quote
Old 18th January 2013, 17:19   #997  |  Link
Nico8583
Does anyone could help to choose H264 settings for MVC encode ?
For this capture, I think all is correct :
For this capture, I think all should be correct but I'm not sure :
For this capture, I think all should be correct except "Maximum I-(or P- or B- or Br-)frames size) :
Thanks !
Old 19th January 2013, 00:30   #998  |  Link
frencher
French Love
Hi all,
I search the perfect command line of x264 for playback on all decks BluRay market (encoding Bluray commercial) because I found this option using x264
--bluray-compat         Enable compatibility hacks for Blu-ray support
Thanks
Old 19th January 2013, 09:12   #999  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Someone (I don't remember who) told me to use these settings:
--bluray-compat --profile high --level 4.1 --vbv-maxrate 40000 --vbv-bufsize 30000 --keyint 24 --slices 4
--open-gop --colorprim bt709 --transfer bt709 --colormatrix bt709 --b-pyramid strict --fake-interlaced --aud
But I don't understand why --bluray-compat is not sufficient alone. If it does what its name suggests, that option should force all necessary flags. Anyway, BD3D2MK3D forces all options above when you tick the "BD compatible" checkbox.
r0lZ
Old 20th January 2013, 18:16   #1000  |  Link
frencher
French Love
OK thanks
If someone could capricious platinum give us feedback and tell us if it works well ?
