Old 7th September 2018, 11:49   #52281  |  Link
Sunset1982
For those who didn't follow the thread on avsforums, madshi is preparing a new official build, so it should not be long till we see an new official build...
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 7th September 2018, 11:56   #52282  |  Link
LigH
LigH's Avatar
New German Gleitz board
Old 7th September 2018, 12:03   #52283  |  Link
BluesFanUK
I learnt my lesson when I went from a 270x to a 980ti, never waste your money on a GPU for MadVR. The programme does a great job sharpening up a picture, but the source is far more important than the GPU in your system.
BluesFanUK is offline   Reply With Quote
Old 7th September 2018, 13:21   #52284  |  Link
tharjr
Originally Posted by tharjr View Post
HDR is not working for me. Using latest NVidia driver
Just fixed. Working fine now
tharjr is offline   Reply With Quote
Old 7th September 2018, 14:04   #52285  |  Link
mclingo
there are one or two pitfalls on both AMD and NVIDIA cards getting HDR working, should be added to the help docs, or at least the minimum prerequisites like 10 bit set in MADVR and DIRECT3D11 ticked etc.
Old 7th September 2018, 16:27   #52286  |  Link
Warner306
It worked for me when going from a GTX 750 Ti to a GTX 1050 Ti at 1080p. Using higher levels of RCA and NGU very high instead of NGU high with video add-on content through DSPlayer actually provided a noticeable improvement. It also made it possible to use features such as HDR -> SDR at full quality.
Some of us definitely notice and appreciate the difference. Everyone's mileage will vary.
Old 7th September 2018, 17:03   #52287  |  Link
mclingo
A fairly low power card may also get hot and loud, a faster card can be run at high quality settings before its gets too loud, I certainly appreciated my move from RX 460 to RX580. My RX460 could just barley manage NGU Sharp low and when it got hot the fans were quite loud. My RX580 also gets loud when its hot but its completely silent at the same settings I ran the RX460 at.
Old 7th September 2018, 18:03   #52288  |  Link
or you just by a good card so you can use it to it'S full potential
Old 8th September 2018, 10:43   #52289  |  Link
el Filou
el Filou's Avatar
@huhn I think mclingo means that even if your card has a good quality cooling system, using it at lower power is still gonna make less noise.
I'm sure that for a constant manufacturer build quality, an RX580 is gonna make less noise than an RX460 on the same workload.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 8th September 2018, 12:21   #52290  |  Link
getting a faster card because you think it will be not as loud even through the old card can do the same workload is ignorance over proper cooled cards. it's not rare that a 560 and a 580 have very very similar cooling solutions.
good low-mid range cards have a very little difference in term of noise between idle and full load. madVR is not furmark and is not able to use every part of the GPU like literally every game too.
Old 8th September 2018, 14:34   #52291  |  Link
el Filou
el Filou's Avatar
I get what you mean but come on, you really think a 185W TDP card running at 40-50% usage is not gonna be quieter than a 75W TDP card?
No manufacturer is gonna waste money by putting exactly the same cooler on both.
Old 8th September 2018, 15:32   #52292  |  Link
mparade
Hello there,
Does anyone know why in FSE mode madVR switches to 60.000 Hz the composition rate? Source is UHD HDR and has a frame rate of 23.976 fps. My LG 55C6V HDR display supports 23.976 Hz refresh rate as well.
Thanks for any advice.
mparade is offline   Reply With Quote
Old 8th September 2018, 16:36   #52293  |  Link
strumf666
75W TDP graphics card can be passive cooled
strumf666 is offline   Reply With Quote
Old 8th September 2018, 17:12   #52294  |  Link
Asmodian
What options do you have set in Display Modes? Which OS?
madVR options explained
Asmodian is online now   Reply With Quote
Old 8th September 2018, 17:18   #52295  |  Link
el Filou
el Filou's Avatar
I know, mine is. The price premium is generally as heavy as the weight of the heatsink, though.
Old 8th September 2018, 17:22   #52296  |  Link
Gser
WTF Micrococks, the new update for Windows 10 that added the new "Focus assist" feature pretty much crippled my transition from windowed mode to exclusive mode to the extent that I thought my graphics card was broken (it sometimes also crashed my system after playback ended or I exited a game). So if anybody else is having problems just go to windows settings and disable ALL THE THINGS in Focus assist. Mother fucking morons adding features nobody needed or asked for, this is just one part of a long list of bullshit like "game mode" or "notification center". Wish I could go back to windows 7.
Gser is offline   Reply With Quote
Old 8th September 2018, 18:20   #52297  |  Link
mclingo
regardless of your opinion on this the reality is that my 580 is almost completely silent (fan runs about 40%) doing the identical load my 460 did where the fan was running at 60-70% and considerably louder.
and it was obvious to me this was going to be the case.
Old 8th September 2018, 21:01   #52298  |  Link
http://www.sapphiretech.com/productd...EA40A&lang=eng
http://www.sapphiretech.com/productd...7F4D7&lang=eng
the same cooler to me it will have some difference but mass production can be quite cheap.
and i a 90 % loaded GPU can produce less noise than a 40 % GPU only the cooler matters https://www.guru3d.com/articles-page...review,10.html
a proper passive cooled cards can't be beat by a good cooling solution. TDP is not that important.
it's far cheaper to buy a better cooled card than a bigger card that is only used for half of it'S power.
Hello there,
what display modes are you using?
Old 8th September 2018, 21:34   #52299  |  Link
XMonarchY
I wonder if madshi finds a way to utilize upcoming NVidia RTX ray tracing cores to benefit video playback. Perhaps AI capabilities of NVidia GPU's can perform more accurate and faster frame interpolation?
BTW, what is the general advice and\or concensus on settings for 1440p displays. I just got this sweet 32" LG VA G-Sync 144Hz panel and it's only 8 inches smaller than my 40" 1080p VA TV with same contrast ratio, but maxing out at 60Hz. I thought about just switching to use that monitor as, but non-standard 1440p along with G-Sync make it complicated to select settings for the best visuals
8700K @ 5Ghz | ASUS Z370 Hero X | Corsair 16GB @ 3200Mhz | RTX 2080 Ti @ 2100Mhz | Samsung 970 NVMe 250GB | WD Black 2TB | Corsair AX 850W | LG 32GK850G-B @ 165Hz | Xonar DGX | Windows 10 LTSC 1809
XMonarchY is offline   Reply With Quote
Old 8th September 2018, 22:12   #52300  |  Link
Selur
Selur's Avatar
More accurate: sure (with enough training data)
faster: probably not
see Transforming Standard Video Into Slow Motion with AI
https://news.developer.nvidia.com/tr.../?ncid=--43539
https://www.youtube.com/watch?v=MjViy6kyiqs
-> I doubt it'll be really useful for madVR, but it might be interesting if there were Vapoursynth or Avisynth filter which could be using this,...
