21st October 2019, 00:27 | #21 | Link |
3.1 has a dark UI and a word wrap settings. It requires .NET Core 3.0 being installed.
https://github.com/stax76/MediaInfo.NET
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 21st October 2019 at 00:44. |
21st October 2019, 02:01 | #22 | Link | |
cosmic entity
very nice, that was kinda quick.
Thank you very much for the "Dark Skin" support... Its very comfortable to read now. At first i didnt get it to run, but was shure i did install the .NET Core Runtimes.. After some searching i learned that you need to install: Quote: Quote:
Just thought i mention it if someone else has Problems starting it. Ok, now a BUG i encountered.. MediaInfo.NET does not start in the correct Window size. I think its best to show you. I have no clue whats going on there.. It doesnt save the window size? I did delete everything before using the new Version. Using Win7 64bit.. Best Regards, Beta Last edited by BetA13; 21st October 2019 at 02:27. |
21st October 2019, 02:30 | #23 | Link |
The window size value is ten times more in the new version because of the new UI toolkit. Try this:
font = Consolas font-size = 13 window-width = 700 window-height = 550 center-screen = yes raw-view = yes word-wrap = no Windows 10 users can install Windows Terminal Preview which installs the new font Cascadia Code, looks like this:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 21st October 2019 at 02:38. |
21st October 2019, 02:45 | #24 | Link | |
cosmic entity
You are right
Thanks, it looks like its using pixel as width and height now.. It works now with the selected size. Strangely i do not have those settings: Quote:
This isnt a Limitation to Windows 7, is it? Anyway, Thanks a million, with or without Word wrap, this is now my new MediaInfo Tool... Cheers Last edited by BetA13; 21st October 2019 at 20:10. |
22nd October 2019, 12:28 | #25 | Link |
New in v4.0 is:
- search highlighting - summary shown - left column is wider - few other minor tweaks Fun fact: staxrip was the first dotnet app announced 2002 at doom9. MediaInfo.NET is the first dotnet core app announced at doom9 I believe.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 22nd October 2019 at 12:35. |
22nd October 2019, 12:44 | #26 | Link | |
cosmic entity
Thank you for the new Update... Great Work!!
I like the Tweaks on TOP in the "basic" view, Settings are also better now, very readable.. And teh search function with the Green markings, GREAT STUFF!! I love it :P Quote:
If i might ask, the "word wrap" setting, is it integrated? Its still not showing for me? Best Regards... Last edited by BetA13; 22nd October 2019 at 12:48. |
22nd October 2019, 13:29 | #27 | Link |
Thank you for the positive feedback. What you see in the settings dialog is the plain text content of the settings file which is created when it's missing, because the file was created with an old version settings added by newer versions don't show. I added the defaults on the web site:
https://github.com/stax76/MediaInfo.NET#defaults Ideally there would be a real settings dialog with check boxes etc., problem is I don't have great experience with the UI framework, so it would take more time to build, I should probably create this dialog, maybe in the next release.
22nd October 2019, 13:48 | #28 | Link | |
cosmic entity
No worries though ill whait for the next release.. |
22nd October 2019, 15:58 | #29 | Link | ||
some info on dotnet:
Quote from Scott Hunter, Director Program Management, .NET Quote:
mpv.net will likely be ported but maybe not so soon. https://dotnet.microsoft.com/downloa...re/3.0/runtime
23rd October 2019, 03:01 | #30 | Link |
4.1
- encoder parameters have a nice presentation - if the text has focus the caret is visible and key scrolling works
23rd October 2019, 10:19 | #31 | Link |
Any plans on making it also available via https://chocolatey.org/packages? (it is a package manager for windows)
If not I can do it and maintaining it on chocolatey if you're cool with it.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 23rd October 2019 at 10:24. |
23rd October 2019, 13:19 | #32 | Link |
Yes I'm cool with it, thank you.
I had a feature requests for mpv.net and chocolatey but found it difficult to understand but meanwhile my powershell knowledge has significantly improved, maybe now I'm ready for it. I realized the app has grown enough to clean up the code and add everything missing of what a solid app is supposed to have, working on a new version right now.
23rd October 2019, 20:58 | #34 | Link |
Yes, I want to add it.
24th October 2019, 06:48 | #35 | Link |
5.0 --- - changelog added to repo - if no file is open message is shown - file can be opened from menu: Open File... - file can be saved from menu: Save File... - exclude setting added to hide defined parameters - encoding presentation can be disabled - compact summary can be disabled - file types for setup can be customized - column width can be customized - new settings dialog with proper UI controls and greatly improved usability - some dialogs use task dialog instead of msg box - about dialog added - settings directory can either be AppData, Portable or Custom https://github.com/stax76/MediaInfo.NET As far as I can tell the app is now complete.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 24th October 2019 at 06:57. |
24th October 2019, 08:14 | #36 | Link |
Hello Frank.
Just tried your utils today (MediaInfo.NET, ShellNew and Open++) Having the "original" MediaInfo GUI registered in Windows File Explorer showing with a right click on a media file, your MediaInfo GUI doesn't show up with a right click on a media file, even after installing it from inside the app. Only the original MediaInfo is present in right click context menu on a media file. It seems that your MediaInfo GUI can only be registered for the unregistered extensions by any Media Player - I mean the "orphan" media extensions - while the original MediaInfo is always present, if you set it in its preferences. BTW, have you found out a way to register all of the extensions supported by an app (e.g Chrome) with a single click and not one by one using Windows 10 (latest versions) ? That would be a very useful util! Also, for both your .NET Core apps (ShellNew and MediaInfo.NET) it would be useful a pop up message warning the user that both .NET Core v3.0 runtime and .NET Core v3.0 Desktop runtime must be installed, ideally with a direct hyperlink to download the installers Or you can put the links in a ReadMe.txt file. Because now it seems that they are simply not working. Just my two cents...
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
24th October 2019, 13:53 | #37 | Link | ||
Hello Nikos,
I got both, the extension based menu of the original app and the registry based menu of my app and both work, there is not much I can do other than suggesting to use Open with++. Quote:
24th October 2019, 19:34 | #38 | Link | |
There are many apps like MPC-HC that support dozens of different types of files and can register themselves as the default app for all those file types (file extensions e.g .mp4 .mkv .ts .aac etc) Last few versions of Win10 do not allow you to set MPC-HC as the default app for all those supported extensions by MPC-HC with just a single click. Win10 allow you to set and register one by one the extensions supported by the app as the default program to open those extensions. Understood.
24th October 2019, 19:52 | #39 | Link | |
https://github.com/stax76/mpv.net/bl...sc/Misc.cs#L61 https://github.com/stax76/MediaInfo....Program.cs#L60 Setup can be found in the mpv.net menu at : Tools > OS Setup It features: video file types registration audio file types registration image file types registration and it has a button to bring you to the default apps dialog, that buttons calls the shell address: ms-settings:defaultapps https://betanews.com/2015/06/19/wind...control-panel/
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 24th October 2019 at 19:59. |
24th October 2019, 20:07 | #40 | Link | |
I hoped you could do some magic and bring the old functionality to new Win10
