Old 6th February 2014, 08:42   #561  |  Link
kypec
User of free A/V tools
kypec's Avatar
Originally Posted by ultim View Post
... new test build[/B], r1689
Right, http://goo.gl/e0VFYn.
Can anyone be so kind and tell me how am I supposed to download comfortably from that MEGA folder? When I choose "Download as ZIP" it always got stuck at 10~13% in Firefox. When I choose standard download then I have to confirm manually each single file to be downloaded and folder hierarchy is lost, x86 & x64 files are mixed due to having identical names Not very user friendly and very error-prone IMO.
EDIT: I just tried with Chrome on Windows 7 - same issue with "Download as ZIP".
kypec is offline
Old 6th February 2014, 10:37   #562  |  Link
ultim
AVS+ Dev
ultim's Avatar
Originally Posted by Nevilne View Post
divide=1 or divide=2 doesn't work in MAnalyse with avisynth+
super = MSuper()
backward_vectors = MAnalyse(super, isb = true)
forward_vectors = MAnalyse(super, isb = false)
MFlowBlur(super, backward_vectors, forward_vectors, blur=15)
working
super = MSuper()
backward_vectors = MAnalyse(super, divide=1, isb = true)
forward_vectors = MAnalyse(super, divide=1, isb = false)
black screen
Will check at home.
AviSynth+
ultim is offline
Old 6th February 2014, 10:46   #563  |  Link
ultim
AVS+ Dev
ultim's Avatar
Originally Posted by qyot27 View Post
Both builds crash immediately due to a SIGILL.
On a different computer (that has SSE2), though...
Ah yes, I forgot to mention this in the changelist, I'll go and edit shortly. Previous stable Avs+ have been compiled to SSE2 unknowingly, this has been already discovered and is fixed in the current MT build. SSE is still required though.
AviSynth_check.dll = error, truncation
AviSynth_nocheck.dll = error, truncation
I was afraid of this. Then I think this is something to be fixed in FFAudioSource(). The special test builds for you were the same as stable r1576 (which you said was still working), except I removed the audio caches. No changes, just pure code removal, so that the Cache filters becomes completely transparent for audio and call through directly to the source filter. So unless the audio cache has been doing something funky, I think this might be a problem in FFAudioSource(). I'm not 100% sure though, as I'm not familiar with the audio cache of old AviSynth.
AviSynth+
ultim is offline
Old 6th February 2014, 10:48   #564  |  Link
ultim
AVS+ Dev
ultim's Avatar
Originally Posted by naoan View Post
Thanks for the build ultim, haven't tried much but fft3dgpu need mode 3 to operate without glitch.
Thx. This will probably be true for all filters that use the GPU. For these filters, there is nothing Avs+ can do about them, aside from using mode 3. Try to place these calls towards the beginning of your script to minimize the performance affect on other filters.
AviSynth+
ultim is offline
Old 6th February 2014, 14:29   #565  |  Link
zero9999
AviSynth+-2.6.0.5-MT-r1689-g0d5dfb7.7z
AvsPmod-2.5.1-r426-x86-04874ed.7z
zero9999 is offline
Old 6th February 2014, 15:59   #566  |  Link
Groucho2004
Originally Posted by turbojet View Post
blankclip(1630,1920,1080,"YV12",23.976)
resize(1280,720)
measured with avsmeter 1.7.6
            AVS+   2.60
Lanczos3    116    132
Spline64    108    116
Bicubic     192    159
Bilinear    205    225
Bicubic being faster while the others are slower might be interesting.
Same script with i5 2500K @ 4GHz:
(There is no Lanczos3 so I left it out)
            AVS+ r1689     2.60A5
Spline64    161            190
Bicubic     341            298
Bilinear    382            461
The relative differences seem roughly the same for Intel/AMD, Intel is just a lot faster.
Groucho2004 is offline
Old 6th February 2014, 16:02   #567  |  Link
innocenat
innocenat's Avatar
turbojet, Groucho2004: Would you guys also mind testing horizontal resizer only? (i.e. 1920x1080 to 1280x1080 etc.) Thank you in advance.
AviSynth+
innocenat is offline
Old 6th February 2014, 16:09   #568  |  Link
Groucho2004
                             AVS+       2.60A5
Spline64resize(1280,1080)    211        250
Bicubicresize(1280,1080)     472        379
Bilinearresize(1280,1080)    472        571
Old 6th February 2014, 16:14   #569  |  Link
innocenat
innocenat's Avatar
                             AVS+       2.60A5
Thank you very much. It seems that it is not as fast as I initially tested and expected.
AviSynth+
Old 6th February 2014, 17:40   #570  |  Link
Nevilne
Will check at home.
Thanks
But should there be such a huge performance hit? I have a heavy script which has setmtmodes 2,3 and 4 for fft3dgpu at the end, it runs at 9 fps and fft3dgpu doesn't slow it down at all.
avs+ runs it at 12 fps with mode 2 but if i choose mode3 for fft3dgpu it runs at 6 fps.
However, if i put prefetch before fft3dgpu script seems to run correctly, and at 16 fps.
Nevilne is offline
Old 6th February 2014, 17:43   #571  |  Link
innocenat
innocenat's Avatar
Just a note: having filter after Prefetch() will currently result in two group of pipelined filter: filter before Prefetch() will run in number of threads specify, while filter after Prefetch() will run in single, main thread. Not sure if this behaviour will change or not.
AviSynth+
Old 6th February 2014, 18:27   #572  |  Link
qyot27
qyot27's Avatar
Yeah, for my own builds with VS2013, I just disabled additional CPU optimizations completely (/arch:IA32), regardless of the fact that I do have an SSE-capable processor.
How much of an equivalent is /arch in MSVC to GCC's -msse/etc. parameters? Does it have an impact on the intrinsics (since the option to dis/enable them is different), or are the two completely separate and the /arch stuff just optimizes the C/C++ parts?
I'll have to see. From looking at FFMS2's audiosource.cpp, that error message is defined in the FFMS_AudioSource::GetAudio function, here:
https://github.com/FFMS/ffms2/blob/master/src/core/audiosource.cpp#L343
Not sure if anything particular jumps out, but I thought I'd still point to it.
qyot27 is offline
Old 6th February 2014, 18:30   #573  |  Link
innocenat
innocenat's Avatar
It only affect compiler-generated code. Unlike GCC/Clang, the flag has no effect on intrinsics. But we have dynamic dispatcher with pure-C path for every internal filter so multiple version of filter is chosen automatically at runtime.
AviSynth+
Old 6th February 2014, 19:01   #574  |  Link
ultim
AVS+ Dev
ultim's Avatar
Yes, everything that you showed here is nothing out of ordinary. If you put a mode 3 fiilter in your script, all filters before it will also be serialized, which is the cause of the performance hit. This is why I recommended earlier that if you have a mode 3 filter, try to put it towards the beginning, which minimizes this hit.
The solution that you have implemneted, putting fft3dgpu *after* Prefetch(), is also a perfect solution, and is even better than placing it just before the Prefetch() if you have nothing after fft3dgpu.
AviSynth+
ultim is offline
Old 6th February 2014, 19:03   #575  |  Link
ultim
AVS+ Dev
ultim's Avatar
Oh, you get that error? Then I'm puzzled and even less sure than I was before. This definetely needs investigation.
AviSynth+
ultim is offline
Old 6th February 2014, 23:15   #576  |  Link
qyot27
qyot27's Avatar
Ah, I see.
Correct. I did a little bit more testing, and it happens with both SSRC and ResampleAudio, with slightly different behavior (see below). Based on the wording of the error message, could it be that the resampling filters are requesting extra samples out of FFAudioSource that just aren't there, leading to the error?
The results are as follows:
SSRC = error message is thrown just before the end of the read, script exits immediately causing audio to be truncated at the end
ResampleAudio = error message is thrown immediately, script exits, empty output file
No resampling step(s) at all = output audio is 44056kHz, no error is thrown, read ends successfully with no truncation
Steps to reproduce:
Generate test video+audio with FFmpeg:
ffmpeg -f lavfi -i testsrc=duration=60:size=352x176:rate=30 -f lavfi -i aevalsrc="sin(440*2*PI*t):s=44100" -vcodec mpeg4 -acodec aac -strict experimental -t 60 output.mp4
Index the file:
ffmsindex -t -1 output.mp4
Script:
FFmpegSource2("output.mp4",atrack=-1,fpsnum=30000,fpsden=1000)
#SSRC(48000,fast=false)
AssumeFPS(29.97,sync_audio=true)
#ResampleAudio(48000)
Uncomment for SSRC vs. ResampleAudio tests.
qyot27 is offline
Old 7th February 2014, 02:27   #577  |  Link
turbojet
What I meant by Lanczos3 is lanczosresize(taps=3) which is default.
Interesting that intel has the same kind of results, I don't have time to test horizontally only right now but I can do it in a few hours if it's still needed.
PC: FX-8320 GTS250 HTPC: G1610 GTX650
PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0
turbojet is offline
Old 7th February 2014, 09:32   #578  |  Link
kypec
kypec's Avatar
although you might consider to replace secure https linking with standard non-secure http due to untrusted (self-signed) certificate issues for potential downloaders of your builds.
kypec is offline
Old 7th February 2014, 09:32   #579  |  Link
naoan
Yeah it's like mode 5 in the old mt. Thanks for the tips but I need it last, and it's actually fast enough on my simple real time ffdshow-avisynth+ anyway (just it and fastlinedarkenmod).
naoan is offline
Old 7th February 2014, 11:22   #580  |  Link
ultim
AVS+ Dev
ultim's Avatar
If it needs to be last, you can also place it after the call to Prefetch().
AviSynth+
ultim is offline
