Old 23rd December 2006, 19:16   #1  |  Link
Sirber
retired developer
Sirber's Avatar
BENCOS - Windows and Linux batch encoder GUI
Bencos is an easy to use Graphical User Interface (GUI) for Windows and Linux to convert big video files into smaller files using standard codecs. It's mainly aimed for japanese animated content (anime) but it can encode general files too.
http://www.detritus.qc.ca
http://code.google.com/p/bencos
Detritus Software
Sirber is offline   Reply With Quote
Old 23rd December 2006, 21:35   #2  |  Link
killerhex
does this software can encode to asp without any sync problems
avc to mpeg4 asp
killerhex is offline   Reply With Quote
Old 23rd December 2006, 21:38   #3  |  Link
Sirber
retired developer
Sirber's Avatar
sure. It doesn't have the delay problem RA4 and bellow had.
Be sure to set the right FPS in the Settings tab. *
* now automatic
Detritus Software
Old 23rd December 2006, 21:56   #4  |  Link
killerhex
thanx
one bug
coudn't open input audio.wav using FAAC
Old 24th December 2006, 03:42   #5  |  Link
Kayser
Kayser's Avatar
Cool, I'll try it and post feedback tomorrow ... Thanks for the work Sirber, Damrod and Sharktooth.
Kayser is offline   Reply With Quote
Old 24th December 2006, 03:44   #6  |  Link
Sirber
retired developer
Sirber's Avatar
Source?
please post more infos when you report bugs. Just saying that doesn't help.
Detritus Software
Old 24th December 2006, 04:26   #7  |  Link
killerhex
source
mkv[AVC]720x480 16/9 anamorphic
[dual audio]audio vorbis 2ch 48hz
english
japanese
im encoding to mpeg4 asp+AAC LC 128kbps preferred audio :english
and why does bencos has both
enhAacPlusEnc
faac
Old 24th December 2006, 14:47   #8  |  Link
Sirber
retired developer
Sirber's Avatar
Where can I get your source? And what was your settings?
enhaacplusenc = AAC HE+PS
faac = AAC LC
Detritus Software
Old 26th December 2006, 18:24   #9  |  Link
Sirber
retired developer
Sirber's Avatar
found bugs regarding to subtitles.
http://www.detritus.qc.ca/forum/view...php?pid=17#p17
Detritus Software
Old 26th December 2006, 22:09   #10  |  Link
mael
my version: 2006-12-26
i get the error "Couldn't open input file audio.wav" on encoding a .mov file when AAC LC is selected with uncompressed audio. from the logfile:
Opening audio decoder: [pcm] Uncompressed PCM audio decoder
AUDIO: 44100 Hz, 2 ch, s16be, 1411.2 kbit/100.00% (ratio: 176400->176400)
Selected audio codec: [pcm] afm: pcm (Uncompressed PCM)
AAC HS+PS works fine, but 32kbit/s is not enough
also, the "about" tab is empty
it would be very nice, if bencos would find out the FPS itsself
what about support for audio with more than 2 channels?
mael is offline   Reply With Quote
Old 26th December 2006, 22:14   #11  |  Link
Sirber
retired developer
Sirber's Avatar
I'll look about LC problem.
Later
Later This is a preview release.
Nope. I don't have any encoder for that.
Detritus Software
Old 26th December 2006, 22:54   #12  |  Link
mael
thanks for the support
maybe take a look at the nero digital aac encoder, it's free:
http://www.nero.com/nerodigital/eng/...tal_Audio.html
Old 26th December 2006, 22:56   #13  |  Link
Sirber
retired developer
Sirber's Avatar
free to use, not free to bundle and doesn't work on linux.
Detritus Software
Old 26th December 2006, 23:06   #14  |  Link
mael
okay, you win
Old 26th December 2006, 23:07   #15  |  Link
Sirber
retired developer
Sirber's Avatar
okay, you win
and linux
Detritus Software
Old 27th December 2006, 00:22   #16  |  Link
Sirber
retired developer
Sirber's Avatar
I'm gonna have to remove MPEG4 ASP and AAC LC for compatibility reasons.
mencoder outputs PCM, not wave, and faac.exe don't handle PCM like enhaacplusenc does.
mencoder using lavf crash in access violation.
Detritus Software
Old 27th December 2006, 00:55   #17  |  Link
killerhex
what no more
MPEG4 ASP
Old 27th December 2006, 00:59   #18  |  Link
Sirber
retired developer
Sirber's Avatar
no more xvid and aac lc due to incompatibility with encoders.
I did not manage to get the encoding chain working with faac.exe, and xvid + he-aac+ps don't make much sense...
Detritus Software
Old 27th December 2006, 01:10   #19  |  Link
killerhex
how about adding xvid+vorbis
Old 27th December 2006, 01:14   #20  |  Link
Sirber
retired developer
Sirber's Avatar
nope. I'm sticking with standards.
Detritus Software
aac, bencos, gui, webm, x264
