Old 30th October 2010, 13:32   #9981  |  Link
gg72
Originally Posted by colinhunt View Post
Those might have something to do with your problems.
OK, thanks!
I installed now the HAALI Splitter, I try the full disc rebuild process this night again.
What is the recommended version of the FFDSHOW? I have this version: rev3611_x64
gg72 is offline   Reply With Quote
Old 30th October 2010, 15:11   #9982  |  Link
Capsbackup
Originally Posted by gg72 View Post
OK, thanks!
How about try the one and only one listed on the first page where you download BD-RB!
This page has all the programs you will need.
Capsbackup is offline   Reply With Quote
Old 30th October 2010, 15:43   #9983  |  Link
gg72
OK, thanks! ;-)
Old 30th October 2010, 17:20   #9984  |  Link
LowDead
Elit Amans
@gg72
- HAALI Splitter: Not installed
- FFDSHOW: , not recommended version
Here's your problem ;-)
/LD
oooops.. I was too late.. sorry
LowDead is offline   Reply With Quote
Old 30th October 2010, 19:51   #9985  |  Link
gg72
Originally Posted by LowDead View Post
@gg72
/LD
With HAALI Splitter and the newest ffdshow it's works fine now, thanks for everyone!
Old 30th October 2010, 22:17   #9986  |  Link
Ch3vr0n
newest FFDSHOW ? Well don't come crying when your version cant process a disc in a while. No bug reports are accepted from non-recommended versions. Use only the ones from the first page. This includes ffdshow
Ch3vr0n is offline   Reply With Quote
Old 31st October 2010, 13:24   #9987  |  Link
john920
Originally Posted by john920 View Post
tried to backup the new grindhouse blu-ray it failed on the last video during audio extraction
[19:27:44] BD Rebuilder v0.35.01 (beta)
- Source: GRINDHOUSE_BD_D1
- Input BD size: 41.72 GB
- Approximate total content: [03:12:12.229]
- Target BD size: 22.66 GB
- Windows Version: 6.1 [7600]
- Quality: Highest (Very Slow), Two Pass
- Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640
[19:27:47] PHASE ONE, Encoding
- [19:27:47] Extracting A/V streams [VID_00002]
- [19:27:51] Reencoding: VID_00002 (1 of 3)
- [19:27:51] Collecting video information
- Rate/Length: 23.976fps, 1,404 frames
- [19:27:51] Reencoding: VID_00002, Pass 1 of 1
- [19:28:22] Video Encode complete
- [19:28:22] Reencoding audio tracks (if req'd)
- [19:28:22] Multiplexing M2TS
- [19:28:24] Extracting A/V streams [VID_00004]
- [19:38:57] Reencoding: VID_00004 (2 of 3)
- [19:38:57] Collecting video information
- Rate/Length: 23.976fps, 131,119 frames
- Bitrate: 14,818 Kbs
- [19:38:57] Reencoding: VID_00004, Pass 1 of 2
- [20:47:20] Reencoding: VID_00004, Pass 2 of 2
- [01:22:27] Video Encode complete
- [01:22:28] Reencoding audio tracks (if req'd)
- [01:22:28] Multiplexing M2TS
- [01:27:35] Extracting A/V streams [VID_00009]
- Extracting video streams [VID_00009]
- Extracting audio streams [VID_00009]
- Error in attempt to extract audio/subs.
- Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: E:\GRINDHOUSE_BD_D1\BDMV\STREAM\00009.m2ts
[01:42:23] - Failed to retrieve audio, aborted
after the fail I uninstalled, restarted and reinstalled ffdshow, Matroska Splitter and AVISYNTH tried again and got this result:
[20:31:12] BD Rebuilder v0.35.01 (beta)
- Resuming from previously started job.
[20:31:13] PHASE ONE, Encoding
- [20:31:13] Extracting A/V streams [VID_00009]
[20:45:46] - Failed to retrieve audio, aborted
Originally Posted by Dirk Diggler View Post
Try deleting your WORKFILES folder and restart the job from scratch
did all that, removed the work files, I tried a re-rip another fail, I even tried a direct from disc read and got the same result...
[00:12:27] BD Rebuilder v0.35.01 (beta)
- Input BD size: 41.73 GB
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[00:12:27] PHASE ONE, Encoding
- [00:12:27] Extracting A/V streams [VID_00004]
- [00:46:54] Reencoding: VID_00004 (1 of 3)
- [00:46:54] Collecting video information
- Bitrate: 14,501 Kbs
- [00:46:54] Reencoding: VID_00004, Pass 1 of 2
- [01:57:35] Reencoding: VID_00004, Pass 2 of 2
- [06:58:35] Video Encode complete
- [06:58:35] Reencoding audio tracks (if req'd)
- [07:00:36] Multiplexing M2TS
- [07:05:31] Extracting A/V streams [VID_00002]
- [07:05:48] Reencoding: VID_00002 (2 of 3)
- [07:05:48] Collecting video information
- [07:05:48] Reencoding: VID_00002, Pass 1 of 1
- [07:06:19] Video Encode complete
- [07:06:19] Reencoding audio tracks (if req'd)
- [07:06:20] Multiplexing M2TS
- [07:06:22] Extracting A/V streams [VID_00009]
- Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: D:\BDMV\STREAM\00009.m2ts
[08:05:33] - Failed to retrieve audio, aborted
Are there any issues with the new release of grindhouse (region A oct,2010)
john920 is offline   Reply With Quote
Old 31st October 2010, 21:00   #9988  |  Link
DarWun
I had the same issue. I was only able to do a full backup if Death Proof's second english audio track was excluded.
DarWun is offline   Reply With Quote
Old 1st November 2010, 14:09   #9989  |  Link
john920
I just did the same thing, it worked. This is a problem... whats up with the other audio tracks?
Old 1st November 2010, 15:03   #9990  |  Link
stage_man
Is it possible to make a dvd-9 full backup thats playable on the ps3?
stage_man is offline   Reply With Quote
Old 1st November 2010, 17:02   #9991  |  Link
brogan
Does anyone w/an Oppo BDP-83 have any problems w/BD Rebuilder (Full Movie) to BD25? Regardless of whether I use Verbatim, Sony or Riteks, 90% + will come up as "Unrecognized Disc" in the Oppo. It will play fine on PS3 or my Sony BDP-350 but not the Oppo. I burn the discs using Cyberlink Power2Go, if that helps. I don't know if there's a setting I should be using & aren't but I thought I would ask.
brogan is offline   Reply With Quote
Old 1st November 2010, 17:34   #9992  |  Link
DrinkLyeAndDie
DrinkLyeAndDie's Avatar
I've had no issues with BD Rebuilder and Verbatim 25 GB 4x BD-R's or 2x BD-RE's playing on my Oppo BDP-83. I've done full-disc and movie-only backups without issue. I use a Pioneer BDR-205 burner and do all my burning with ImgBurn.
DrinkLyeAndDie is offline   Reply With Quote
Old 1st November 2010, 17:37   #9993  |  Link
omegaman7
omegaman7's Avatar
Does your Oppo actually support burned BD-R? My Samsung BD-P1590 (stock firmware) supposedly only supports BD-RE. But I got it to recognize a Verbatim BD-R NON LTH type. I only use imgburn. It does not like the LTH type. As far as I know, they have not released a firmware to combat this...
The current Verbatims I use, have a Disc Id of "VERBAT-IMc-00". Perhaps these discs are highly compatible
omegaman7 is offline   Reply With Quote
Old 1st November 2010, 17:51   #9994  |  Link
brogan
Yes, it does support BD-R. The new ones I have are actually LTH & that might be part of the problem. I'll buy new media & start there...
Old 1st November 2010, 18:11   #9995  |  Link
omegaman7
omegaman7's Avatar
I believe LTH is supposed to replace other BD media. I could be mistaken. I bought the Verbs that I did, because I want to do my own testing You might check if they have released a new firmware for your player. A lot of manufacturers have released one, addressing the LTH issue.
Old 1st November 2010, 21:11   #9996  |  Link
Ch3vr0n
I don't know if they're ment to replace the other ones but it sure fits. LTH discs are made on converted DVD fabrication belts at a fraction of the cost for standard BD-Rs. All i know is that my panasonic DMP-BD85 doesnt have an issue playing them
Old 1st November 2010, 21:29   #9997  |  Link
omegaman7
omegaman7's Avatar
Thanks for the info
Old 2nd November 2010, 15:31   #9998  |  Link
KeVe1983
Banned
I have Problems with the new Shrek BD.
Th Disc is in 2D and 3D and i want to backup to a BD25.
But i dont need the 3D Version and i just want the 2D Version.
Is there a way to do that?
  - Source:  SHREK_3D
  - Input BD size: 66,29 GB
  - Approximate total content: [01:30:51.779]
  - Target BD size: 23,14 GB
  - Quality: High Quality (Default), Two Pass
 - Target too small.  Encode stopped.
KeVe1983 is offline   Reply With Quote
Old 2nd November 2010, 18:23   #9999  |  Link
Ch3vr0n
@KeVe1983 If it uses the current non-anaglyph 3D (colored glasses) technology, not right now no. There currently is no freeware application out there that can process 3D technology like RealD
Old 2nd November 2010, 18:28   #10000  |  Link
ftb32
Hi i have problem :
- [12:49:29] Extracting A/V streams [VID_00016]
- Not enought buffer for parse video stream. Current frame num 1665
[12:49:32] - Failed to retrieve audio, aborted.
Thanks..
ftb32 is offline   Reply With Quote
