24th December 2019, 09:20 | #6842 | Link | |
4th January 2020, 09:24 | #6844 | Link |
I see megui offer some .ts file use DGIndex but video encoded audio don't sync with video, same error with L-Smash
Video test: https://drive.google.com/a/my.smccd....w?usp=drivesdk After i was changed to ffms2 and audio can sync with video Alternatively, megui offer some .ts with L-smash and it's work perfectly Video test: https://drive.google.com/a/my.smccd....w?usp=drivesdk |
4th January 2020, 09:27 | #6845 | Link |
FFMS2 2.23.1 (w/ FFmpeg 4.2.2) compiled by l33tmeatwad
https://forum.doom9.org/showthread.p...14#post1894414 |
4th January 2020, 11:37 | #6846 | Link | ||||
Here are ok: https://forum.doom9.org/showthread.p...65#post1894665 Please remember rule 8: Quote:
The MPEG4-AVC (h264) video need DGIndexNV or Lsmash or ffms2, all of them works fine for me without async (15704 fields -> -stripPulldown -> 6281 progressive frames 23.976 -> 4:22 like audio) Your second video: Quote:
CODED frames 4069 135,769 seg PLAYBACK frames 4523 150,917 seg 49.69% FILM Code:
Output Decoder MeGUI Analyse frames fps Duration MeGUI fps correction ------------------ -------------- ------ ------ -------- --------------------------------- DGIndex Hybrid film 3821 23.976 2:39.36 tfm(order=1).tdecimate(hybrid=1) DGIndexNV Hybrid film 3618 23.976 2:30.90 tfm(order=1).tdecimate(hybrid=1) LWLibavVideoSource Partially film 4069 26.962 2:30.91 tfm(order=-1).tdecimate(hybrid=3) FFVideoSource not detected 4523 29.970 2:30.91 (fpsnum=30000, fpsden=1001) With LWLibavVideoSource we obtain a fps not standard than can be problematic, the output frames are the same than CODED frames. With FFVideoSource we force 29.970 (4523 PLAYED frames) but there are frames with double image. Maybe the DGIndexNV decoder is the best option with MeGUI options.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 4th January 2020 at 14:39. Reason: add info |
16th January 2020, 10:40 | #6847 | Link | |
17th January 2020, 10:30 | #6849 | Link |
@LeXXuz
With MeGUI 2913 still pending. BTW you can open the script tab and modify the DGSource line, example: DGSource("D:\Test\futbol-i.dgi", deinterlace=1)
23rd January 2020, 21:29 | #6851 | Link | |
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 23rd January 2020 at 21:31. |
25th January 2020, 20:08 | #6852 | Link |
Apologies if these things are already requested or already in the program or whatnot but I cannot find anything like it. I'd really like the One Click Encoder to be able to use all the settings from its initial dialog box to folders as well as files - I was sad that I could, say, change the title track of audio and video for one file, but as soon as I wanted to do a whole folder, it makes the OCE profile take center stage, and I cannot find these same options in that. So now I'll have to edit these files post work to change/remove them. It's really just a design issue I think. Like, the audio tabs in the intial dialog box are more thorough than if I go to the config of the OneClick profile because I can apply delay, change the track name etc. Just put all of that stuff in the OneClick profile config as well and everything would be great, right?
Also looking for information on here https://forum.doom9.net/showthread.p...59#post1896259 Either way thank you for all your work and this tool, it is amazing and I've always loved working with it. |
5th February 2020, 05:09 | #6856 | Link | |
With MeGUI closed, move x265.exe from the MeGUI\tools\x265\x64 folder to a safe place as a backup, or simply rename it to something like x265.exe.old, and put the new x265.exe in that folder. If you're using a 32 bit version of Windows, you'd do the same for the 32 bit x265.exe in the x86 folder instead. |
7th February 2020, 12:10 | #6857 | Link | |
21 years and counting...
It's sad that until now there was no time to fix this as this was working before. |
14th February 2020, 12:49 | #6858 | Link |
Excuse me why every time i create an xml Avisnyth Profile file in this path: C:\Users\mypc\Programs\MeGui\allprofiles\AviSynth\ Megui deletes the file after i close the app ? How can i manually create an avisnyth profile outside of app ?
14th February 2020, 15:13 | #6859 | Link | |
At my side I can modify the templates to my like and save them for later use. Just make sure your MeGUI is not in a write protected directory like programs/etc. Or make some templates in MeGUI\allprofiles\avisynth manually. You can use the included AviSynth_dp_ _st_scratchpad_st_.xml as a start and build them on your own. |
