Old 17th July 2019, 16:07   #1  |  Link
K.i.N.G
How to scale 2160p i420 to 1080p i444 without rescaling chroma (UV) components?
So, since the UV components in a YUV i420 source are half the resolution of the full-res luma (Y′) component:
How does one re-scale a i420 2160p source to a i444 1080p source without re-scaling the UV components thus keeping their original quality/resolution/detail/...?
K.i.N.G is offline   Reply With Quote
Old 17th July 2019, 18:15   #2  |  Link
This is it in avisynth, but methinks that it might need some kind of chroma shift to be properley standard.
ColorBars(pixel_Type="YV12")
U=UToY8
V=VToY8
Y=Spline36Resize(Width/2,Height/2)        # Some Resizer
YtoUV(U,V,Y)    # Just uses Y channel from Y clip
info
Old 17th July 2019, 19:46   #3  |  Link
K.i.N.G
U=UToY8
V=VToY8
info
Hey StainlessS,
Thanks for the reply and helping me out (again)!
Just to be sure, this supports 10 and 12bit sources?
Also, is it possible to do this with vapoursynth? Since I've read it has better support for high bitrates (I've configured staxrip to use vapoursynth).
Old 17th July 2019, 20:32   #4  |  Link
Sorry, no idea how to do it in vapoursynth, me never tried it.
but
ColorBars(width=1440,height=1080,pixel_Type="YV12")
BITS=16    # Or 10, or 12, or 14, dont work with 32 for some reason. EDIT: Yes it does. VDub2 loads ok.
ConvertBits(BITS)
U=UToY    # EDIT: Changed UToY8 to UToY, still worked for some strange reason, probably should have thrown error @ YtoUV()
V=VToY    # EDIT: Changed VToY8 to VToY
info
EDIT: I imagine that the function names to do similar are not so very different.
EDIT: Works with BITS=32, was the player that failed, VDub2 loads ok.
Old 17th July 2019, 20:44   #5  |  Link
DJATOM
DJATOM's Avatar
The approach is the same, but core.std.ShufflePlanes is used for plane extraction, and if you don't want to do something with colors, there is no need to extract UV planes at all.
source = <some source filter>
Y = core.std.ShufflePlanes(source, 0, vs.GRAY)
Y = core.resize.Spline36(Y, 1920, 1080)
clip1080 = core.std.ShufflePlanes([Y, source], [0,1,2], vs.YUV)
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 17th July 2019, 22:29   #6  |  Link
K.i.N.G
Thanks to the both of you
I got it working in StaxRip with some very minor editing. (Had to change the name of source clip variable... just added a '1' behind it and rename 'clip1080' to 'clip' so that StaxRip sees it correctly as the output).
Just posting it here in case if someone else gets into the same StaxRip error I had without the adjustment. (this is assuming you use a ffms2 source)
clip1 = core.ffms2.Source(r"%source_file%", cachefile = r"%source_temp_file%.ffindex")
source = clip1
clip = core.std.ShufflePlanes([Y, source], [0,1,2], vs.YUV)
Old 17th July 2019, 23:13   #7  |  Link
K.i.N.G
Comparison of result with saturation boosted (to better show the difference).
Can make quite a noticeable difference especially with HDR.
Old 30th December 2020, 14:39   #8  |  Link
PoeBear
Was curious about doing this, and this seemed the most recent thread...
Trying out StainlessS' second AVS script, it seems to work well:
Here's a 1080p 4:4:4 script scaled back up to 2160p (with a slight zoom) for comparison's sake. It keeps more of the reds (very noticeable in the shirt), while a simple z.lib resizer kills a lot of it, and merges them with the surrounding colors. It's even keeping a tiny bit of the red on the makeup pen
Script:
DGSource("Test.dgi")
U=UToY
V=VToY
Y=z_Spline36Resize(Width/2,Height/2)
YtoUV(U,V,Y)
Source file: 2160p/HEVC/8-bit/BT.709
...it might need some kind of chroma shift to be properley standard.
I was curious about this comment though, wanted to make sure I'm doing it right. Should we be shifting the chroma/chromaloc at some point? My sources are all top-left chroma
PoeBear is offline   Reply With Quote
Old 31st December 2020, 17:28   #9  |  Link
poisondeathray
Originally Posted by PoeBear View Post
W
Script:
U=UToY
V=VToY
YtoUV(U,V,Y)
I see the difference in your screenshots, but I cannot reproduce that difference on some random camera UHD source. There are negligible difference using subtract(a,b) for me. It might be different versions of plugins, or avs version, not sure
If there was a material difference between the methods, you should be able to use subtract(a,b) and see difference on a synthetic test like colorbarshd
Can you reproduce it on this
ColorBarsHD(3840, 2160)
ConvertToYV12()
U=UToY
V=VToY
YtoUV(U,V,Y)
a=last
ConvertToYV12()
ConvertBits(BITS)
YtoUV(U,V,Y)
ConvertBits(8)
b=last
subtract(a,b)
420 to 444, chroma 444, re-scale
