2nd May 2019, 14:26 | #56101 | Link | |
---HDR: "where left to decide by madvr" So changed it like you said to "passthrough to display" but you say use passthrough or HDR using pixelshaders..? which one to choose? Or did you mean just put the HDR option on pixelshader? If so. what to put @Target peak nits? and tone mapping curve? ---Put error Diffusion on Option 2. ---Put chroma on NGU sharp very high. What about image downscale and image upscale? ---And what about the trade quality for performance tab? ---Tried changing ycbr to rgb but nvidia only allows me to choose 8 bit RGB. So can't choose 10 bit.. I think personally I found ycbr 10/12 bit to look better then 8 bit RGB..? The blacks were more black and colours more vibrant? Last edited by chrisssj2; 2nd May 2019 at 14:29. |
2nd May 2019, 16:24 | #56102 | Link | |||
Set the target peak nits to 700-1,000 nits; Tone mapping curve to BT.2390; Leave color tweaks for fire & explosions at balanced; Set highlight recovery strength to medium-high. Quote:
Neither is required with 4K output. Leave them all unchecked. Quote:
https://forum.kodi.tv/showthread.php...438#pid2739438
2nd May 2019, 17:29 | #56103 | Link | |
For example, my samsung tv's white point algorithm doesn't always arrive at precisely the same gains between backlight setting changes. The room temperature also greatly affects LED temperature, and white led has +/- 10-20% luminance difference between operable temps Things like this will add to the delta E far greater than what the meter can improve with measurement speed. If you catch the i1d3 at sale price, then that's one thing, but facing non-sale prices, There's no reason not to choose Cmunki instead. Yea, it was sold by adorama camera on Rakuten during rakuten's 20% off black friday promotion. So, $165 (sale price) * 0.8 = $132 + Tax ~$140
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 2nd May 2019 at 17:34. |
2nd May 2019, 17:57 | #56104 | Link |
What do you guys think about this?
https://www.amazon.com/Wacom-EODIS3-.../dp/B01B96L2QE It's just a i1d3 right? Any reason to get the official brand over this? I'm only going to use it with open source software and drivers anyways like ArgyllCMS, DisplayCal, HCFR, madVR. Last edited by SirMaster; 2nd May 2019 at 18:01. |
2nd May 2019, 22:24 | #56108 | Link |
how can you make sure the room temperature doesn't change to much in a measurement with speed even through it doesn't matter anyway heating the screen(and meter) by simply running has far more effects on temperature and is a default calibration part anyway. the number of patches is just defined by the time you are willing to spend on it and the speed of the meter.
2nd May 2019, 22:28 | #56109 | Link |
I do it for quality. I don't care how long it takes. I always go for the most amount of patches. With that said, this is where the rabbit hole part comes in, if you're anything like me you'll always be looking at it thinking you can squeeze just that little bit more out of your display.
2nd May 2019, 22:57 | #56111 | Link |
You guys are overthinking this. The TV and Sensor are unstable over 1.5-2 hours.
Measurements you take exceeding 1.5 to 2 hours (has a probability) of being NON relevant to the data within that 2 hours. A very good human eye on a person who's trained to know precisely what to look for can discern quality up to ~2-3000 patches. Any more than that is purely academic. again, if anything more patches will increase the average error. The only time where EXCESSIVELY many patches may outperform fewer is if the monitor has some really weird behavior. The error will still be higher than fewer patches, but it may fix the busted spot.
Ghetto | 2500k 5Ghz |
3rd May 2019, 01:28 | #56112 | Link |
What do you mean "the TV [...] is unstable over 1.5-2 hours"?
Is this only valid for LCDs with local dimming as the LEDs can vary in temperature depending on content displayed? Once a display is warmed up it should be stable in its responses.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
3rd May 2019, 01:32 | #56113 | Link |
No it absolutely is not. Daily temperature can vary quite alot. even 2 degrees difference changes the backlight characteristics.
The meter also heats up as the photons hit the sensor surface. There's a very specific reason you should not calibrate for more than 1-2 hours. Even 2 hours is asking a bit much. Y'all can relax on this , cuz the outcome colors are Interpolated, it's not a 1:1 matching game where the accuracy increases linearly with ever more patches. It just needs to define the general shape of the monitor's behavior.
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 3rd May 2019 at 01:50. |
3rd May 2019, 02:42 | #56114 | Link |
madVR, not calibration in general. We do have a good Calibration Thread.
madVR options explained |
3rd May 2019, 11:34 | #56115 | Link | |
As for the link it says recommended: (madVR) PC levels (0-255) -> (GPU) Full Range RGB 0-255 -> (Display) Output as RGB 0-255 I understand MadVR part, And the GPU is set in Nvidia control panel. but as for the display part I don't remember seeing a 0-255 option. As to why I can't select RGB 10 bit is because I need to put it at 30 hz.. lol ok so I need to switch this manually each time i watch a movie.. Got it. I created an nvidia profile for kodi with anisoptric filtering off etc. everything as close to nvidia defaults. And "adaptive power" and "Vsync" on. Pre-render frames @default (3) Did the same for MPC-BE. Will report back on how it runs! |
3rd May 2019, 13:45 | #56116 | Link |
In displays, the RGB range setting is sometimes called "HDMI black level" and sometimes the values are called Low/High or Standard/Extended.
You could also just leave the graphics card output on 8-bit for all refresh rates and trust madVR's dithering, it's that good.
3rd May 2019, 13:56 | #56117 | Link | |
any suggestions for which software to use, I have the softw that came with it and SpectraCal Ultimate for Business v 5.6.1
Livingroom: Ryzen 7 1700@3.9ghz - Win Insiders Fast Ring - MSI RTX 2700 Gaming - Philips 65OLED803 | Bedroom Ryzen 3 1200 - Win 8.1 - GTX1060 - LG OLED EG920V 55" > All with MadVR latest test build |
3rd May 2019, 16:30 | #56118 | Link | |
3rd May 2019, 19:11 | #56119 | Link | |
3700X - RTX2070 - 970EVO - EVGA Supernova 750W Gold - Sony KD55X720E |
3rd May 2019, 23:09 | #56120 | Link | |
But on Samsung, it's either Normal or Low. On PC mode, normal is 0-255, on low it's 16-235 On OTHER inputs, normal is 16-235, low is 0-255 WTH righ?
