2nd March 2013, 05:08 | #14301 | Link |
If Win8 N version has WMVideo Decoder DMO, then LAVs WMV9 DMO decoder will work fine as well.
Sorry I have no N version. |
2nd March 2013, 07:31 | #14302 | Link |
Hi could you help me ? I have run CCLEANER and uninstalled all codecs. Then when i try to install LAV filters (last version) only the 64 bits are present (i verify with Win7DSFilterTweaker_5.7). It seems my win 8 pro (official) doesn't allow me to install 32 bits codecs anymore :s even if there is no error at the installation
2nd March 2013, 09:32 | #14303 | Link | |
The Media Feature Pack for N and KN versions of Windows 8 will install Media Player and related technologies on a computer running Windows 8 N or Windows 8 KN editions." http://www.microsoft.com/en-us/download/details.aspx?id=30685
Windows 7 RC 64bit, NVidia GF8600GT 190.38 |
2nd March 2013, 10:09 | #14304 | Link |
Thanks for the reply's but it's not what i ment or what i think Blexley was asking either. At the bottom of Lav Filters video configuration is Use Microsoft WMV9 DMO decoder WMV3 and VC-1 Would it be better to have Windows Media Player installed to use this Lav option? |
2nd March 2013, 11:27 | #14305 | Link | |
2nd March 2013, 20:37 | #14307 | Link |
Only if its required, because your renderer doesn't support 10-bit content for example. Untouched is always preferred, but not always possible. If you use madVR, you should get untouched.
2nd March 2013, 22:21 | #14309 | Link |
Sample?
3rd March 2013, 10:05 | #14311 | Link | |
Nevcairiel is always saying that Win XP is a problem yet when asked about a Lav filters setting for Windows 8 he rudely ignores people. Go figure. |
3rd March 2013, 10:16 | #14312 | Link | |
I remember reading that Windows 7 N does indeed not have the codecs in addition to not having the media player, so I would not get the N version. I don't know if this applies to Windows 8 as well. |
3rd March 2013, 10:25 | #14313 | Link |
That still doesn't answer the question as that is not what is being asked.
Is it better to use that option if available or is it not needed ? If it's not needed or doesn't give any advantage over Lav filters for WMV9 DMO decoder WMV3 and VC-1 then you don't need mediaplayer installed. A developer doesn't need a version of windows installed to know if an option is best used or not because knowing if it's best used or not then the rest can be worked out by ourselfs.? Thanks |
3rd March 2013, 10:45 | #14314 | Link |
Geez.
If you have the DMO Decoder installed -> The option will work. If you don't have the DMO Decoder installed -> Initializing the decoder will fail. http://code.google.com/p/lavfilters/source/browse/decoder/LAVVideo/decoders/wmv9.cpp Code:
hr = CoCreateInstance(CLSID_CWMVDecMediaObject, NULL, CLSCTX_INPROC_SERVER, IID_IMediaObject, (void **)&m_pDMO); if (FAILED(hr)) { DbgLog((LOG_TRACE, 10, L"-> Failed to create DMO object")); return hr; } No one owes you any answers, and therefor it isn't rude to ignore you. Welcome to the internet. Also, support given by nev in this thread is much better than MANY open source developers I've seen on the net... so don't b!tch. :P Last edited by Superb; 3rd March 2013 at 10:47. |
3rd March 2013, 10:46 | #14315 | Link | |
In any case, LAVs default settings are the recommended settings (why would anything else be default?), you can figure it out from there.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 3rd March 2013 at 10:49. |
3rd March 2013, 10:47 | #14316 | Link |
Just because he develops LAV Filters does not mean he magically knows whether Windows 8 N has the things needed for these LAV Video options. You didn't ask whether these were "best used" or not. If Nev didn't think they were needed he wouldn't have added the function to LAV Video to utilize them and definitely wouldn't have activated them by default.
3rd March 2013, 11:11 | #14317 | Link | |
I'm not sure if you guys are just naturally rude and obnoxious or it's a case of Asperges.
Ridiculous to expect us to buy Windows 8 N to find out when you could just simply answer if Lav Filters prefers to use Windows Media DMO or not and without it if it would limit media playback. No need for anyone to be a complete ass over it like media is some sort of leet club. |
3rd March 2013, 11:16 | #14318 | Link |
If it didn't have any advantages, it wouldn't be the default.
So concluding from that, disabling it does give you disadvantages. Obviously this option only works if the DMO decoder is present in your system. If this is the case on a "N" install? I don't know. Feel free to find out and report your findings. You're the one being rude, there is no magic secrets here, just logical conclusions anyone can arrive at.
3rd March 2013, 11:35 | #14320 | Link |
Here is one Dxtory sample:
http://www36.zippyshare.com/v/60688661/file.html There can be also different colorspaces and compression. |
