28th July 2011, 02:45 | #4321 | Link |
new to lav spliter/decoder.
i bitstream hd audio to my receiver so I used to use ffdshow and gabest/mpc mkv splitter but i'm gonna give this a go when I get a chance. I have a question about the built in flac decoder. if you want full multi-channel flac audio, is it still advised to use a different flac decoder, such as madflac, or is there no difference? I always like to streamline the decoders/filters as much as possible. |
28th July 2011, 07:16 | #4322 | Link | |||
Implementing something like Seamless Branching without knowing the spec is not trivial, so i had to go on the discs that i had, and figure out how the things would play together. I worked fine on every disc i own (except that one mentioned above), and apparently for everyone else as well. Anyhow, without owning the disc i cannot do anything. There will always be the occasionally oddly mastered disc that needs some special magic. Quote:
In general, i would say there isn't a big reason to use something else, unless you find something that doesn't work. (and if you do, let me know, so i can fix it!)
28th July 2011, 07:42 | #4323 | Link | ||
Thanks for the response and thank you for your efforts in this. EDIT: one question - is there a way to only enable subtitles if there's a forced subtitle present? I can only get it to work so that subtitles are on or off. I've played around with the subtitle settings, but again, they're either on or off. Do I have to disable something in MPC HC? I'm using MPC HC btw (MPC subtitles are not enabled) with only LAV installed. Last edited by rahzel; 28th July 2011 at 09:35. |
28th July 2011, 14:42 | #4324 | Link |
Seeking does not work with these two FLV files (using ffdshow as decoder).
http://www.mediafire.com/?62jbf8i722ngdfe http://www.mediafire.com/?oil4vtf1v483qol Works with the Gabest splitter.
MPC-HC 2.2.1 |
28th July 2011, 17:32 | #4325 | Link |
LAV Filters 0.31
LAV Splitter - Improved audio codec selection priorities - Improved VC-1 playback when using the madVR internal decoder - Improved playback of MPEG-TS files with a timestamp wrap right at the beginning of a file - Reduced amount of data required for file probing, resulting in faster startup time - Fixed demuxing/timestamping of RealMedia files LAV Audio - Fixed a bug in the DTS parser which caused occasional hiccups on DTS-HD content - Added the ability to detect DTS-in-WAV The most important fix for me in this version was the DTS parser fix. It happend on quite alot of discs for me, but i never cba to fix it .. until now. In addition to that, startup should be faster again now, although with the negative side-effect that some streams might not be detected if the file is muxed kinda odd. Don't worry, i have some plans for that, which will hopefully resolve this issue in the future, without delaying the playback start. Additionally, DTS in WAV is now supported by LAV Audio. Its implemented only in the audio decoder, that of course means it only works if your WAV content (which was probably identified as PCM) is going through LAV Audio. With LAV Splitter thats no problem, because it uses LAVs special audio mediatype to send it to LAV Audio - however with all other splitters, LAV Audio won't be able to do it just yet, because i do not accept the usual raw PCM mediatypes. I'll have to come up with some solution for this - but anyway, its now possible to play DTS-in-WAV with LAV Splitter/LAV Audio at least. As you may have noticied, LAV Video is not part of this release. I wanted to get this small bugfix release out, before LAV Video is merged into the main source tree. This is mostly because i'll be on vacation soon, and i don't expect much work all through August. I'll be releasing a new "official" test version of LAV Video before i leave for you guys to test and accumulate feedback for me when i come back. For anyone that missed it earlier, i moved from GitHub to Google Code. The new project page can be found here: http://code.google.com/p/lavfilters/ Please submit all issues to the Issue Tracker there (http://code.google.com/p/lavfilters/issues/list) You're of course free to discuss them here first, if you're not sure if its really an issue, or things like that. You can also see a rough roadmap up there on features to eventually come (or are at least somewhat planned, nothing is guaranteed) Have fun! PS: I would also like to repeat my request from some days ago: If someone is good at drawing graphics/artwork, i could use a logo and a set of icons for LAV Filters. I'm not really fixed on anythign specific, just something simple. The icons should come in 4 versions, one for LAV Splitter, LAV Audio, LAV Video and LAV CUVID each. They should work in 16x16 for tray icons, but also in bigger sizes for normal icons (at least 32x32, but if its vector based, it would be best) This is your chance to give something back.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 28th July 2011 at 20:49. |
28th July 2011, 20:03 | #4329 | Link |
@ Nev
Just a small request / bug : it's "odd" / not recommended to have the x64 version of the LAV Filters installed in the "%ProgramFiles(x86)% especially when they are the only version installed on the system (no x86 version installed) Anyway thanks and enjoy your well deserved vacation P.S. Can you please post here all the working git locations (https://code.google.com/p/lavfilters/ it's "acting out" ) for the source ?
Intel UHD Graphics 750; Win 10 22H2 |
28th July 2011, 20:06 | #4330 | Link |
I won't install it into two locations, that adds alot of complexity to a very simple install script. I don't really see the downside of installing it there anyway.
The Google Git works perfectly for me, otherwise i wouldn't be able to push changes. Try the same with http instead of https. Also, you need at least git 1.6.6. Otherwise, my own hosted git repository still works and is being updated. (git://git.1f0.de/lavfsplitter.git)
28th July 2011, 20:09 | #4332 | Link |
Uninstalling is not required.
28th July 2011, 23:15 | #4334 | Link | |
i have this one and i didn't notice lag (it should be happen @ 18:27 minutes from the end of the movie). I have open 00800.mpls and i confirm that i have the correct m2ts too. Thanks.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
29th July 2011, 07:11 | #4335 | Link |
There seems to be a problem with Sequential read problematic muxed DivX 5 ASP AVIs (sound gets stuttery playback slows down) and Lav Splitter + DivX Decoder, though need to further check falling back like MPC-HCs splitter to the default Avi Splitter avoids this, so it isn't critical
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
29th July 2011, 07:49 | #4336 | Link |
DTS Surround level issue
Hi Nevcairiel,
I use LAV Audio and I found an issue on DTS decoding due to Arcsoft DTS decoder. I try differents dtsdecoderdll.dll from TMT2, 3, 5 and some differents releases but the problem is always there. I use HDMI output of my graphic card and if I configure output mode on PCM, there is an issue on surrounds speaker but only on DTS signal. If I choose a bitstream mode, all is fine because it is my sound processor which decode the signal (like others processors and amplifiers). The problem is my processor can't decode HD soundtrack so I must use PCM signal to do it. To calibrate multichannel levels, I use a pink noise encoded in Dolby Digital 5.1 and DTS 5.1. The level is normalized, so -30dBFS for individual channels. The -30dBSF should produce a +75dB SPL if the volume control is turned up to reference level (0dBr). With Arcsoft decoder, in DTS, surround levels are 3dB lower than others channels. If I use a Dolby Digital signal, all channels have the same output level. Normally, output levels should be same on all channels despite we use a DTS or DD signal. I test same procedure to control level on HD sources and using Dolby True-HD, DTS-HD or LPCM signals, levels are corrects for each, even for DTS-HD !!! If I test this normalized soundtracks with some blu ray players (Pioneer or Panasonic), all levels are corrects. I can use PCM mixing on HDMI output or PCM to analog output and all is fine. Players make a good job to convert DD5.1 or DTS5.1 to PCM. So I test also others software players on my computer and both PowerDVD 10 Ultra and Media Player Classic Home Cinema work perfectly in PCM mixing. DTS and DD give the right output levels for all channels. Otherwise if I use TotalMedia Theatre, the bug comes back so for sure it's the arcsoft decoder which as an issue. I think the problem is Arcsoft which use the wrong method to decode DTS signal. It exist 2 types of decoding method: one for Cinema processing and one for Entertainment. They choose Cinema method which has a surrounds levels 3dB lower than front speaker. This is the wrong method and I have contact them to inform but they have never answered. Do you think it's possible to fix the issue by yourself with an automatic surround level compensation on DTS signal … or maybe replace Arcsoft decoder by Cyberlink decoder because PowerDVD is fine? Thank you |
29th July 2011, 08:09 | #4337 | Link |
The Cyberlink decoder is unable to decode 7.1 HD content (only producing 5.1), as far as i know.
Anyhow, i have no plans at this time to replace the ArcSoft decoder with anything. It may be an option to compensate for this when using the ArcSoft decoder to decode lossy 5.1 DTS. How did you measure those values, is there some easy tool i can use to measure the created PCM? Did you test without the ArcSoft decoder, using ffmpegs native DTS decoding? Is it correct then? If you could share you testing procedure (ie. the tools you used), and possibly your DTS 5.1 pink-noise test file, that would be great, and would allow me to work on it without establishing my own procedure first.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 29th July 2011 at 08:16. |
29th July 2011, 09:04 | #4338 | Link |
The DTS and DD pink noise are in Digital Video Essentials disc. I can send you file by private mail.
However High Definition files (LPCM, DTS-HD MA and DolbTrue HD) are available on another disc. To measure level, you need a sound meter. If you don't have this device, you could find a free application for iPhone or others phones. Precision doesn't matter: what matters is to measure differences between front and surround speakers. You could also hear differences without sound meter. Off course you need 5 speakers for easy tests. I don't know how test Arcsoft decoder using ffmpegs native DTS decoding but give me the procedure and I will do. Thank you. |
29th July 2011, 09:05 | #4339 | Link | |
I think i can add some code in LAV Audio to actually compute the average loudness coming from the decoder, i'll investigate into that direction.
