Old 6th April 2010, 20:51   #7601  |  Link
Capsbackup
@jdobbs;
I have a second XP Pro installation on a seperate hard drive, since I like knowing I can boot from either drive if one has a problem.
I have not used that OS for some time, so after booting to it, updating antivirus and windows, I unzip a fresh BD-RBV03302, and run the inspect tool to check things out.
I get the message that " HAALI Splitter: Isn't recommended version", so I uninstall the one I have, run Regedit, delete all entries of Haali, reboot and download the one from the first page of your thread.
After installing that one, I reboot, and run the inspect tool again, but I get the same message.
MatroskaSplitter says 1.9.42.1.
I have not tried BD-RB yet, but why would I get this message from your download version?
Capsbackup is offline   Reply With Quote
Old 6th April 2010, 21:45   #7602  |  Link
jdobbs
Originally Posted by Capsbackup View Post
@jdobbs;
You probably have some residual files in "c:\program files\haali\matroskasplitter". After you uninstall, clear that folder before the reinstall.
Website: www.jdobbs.net
Old 6th April 2010, 22:12   #7603  |  Link
Capsbackup
Thank you kindly. You were exactly correct!
Old 7th April 2010, 11:32   #7604  |  Link
user822
Hi!
how can I use "Hiddenopts"
Rebuilder keeps on ignoring TWEAK_PASS
although it says " - X264 Tweak(s) enabled"
i have them in the following format: TWEAK_PASS_ONE= --slices 0 --keyint 250 --min-keyint 25 --b-pyramid normal --bframes 5 --ipratio 1.4 --pbratio 1.4
EDIT: found the problem, it puts my options after the other options and the first option is taken, i think this is a BUG
thanks in advance!
user
user822 is offline   Reply With Quote
Old 7th April 2010, 12:02   #7605  |  Link
Discoboy
Forced subs missing after 1080p to 720P movie only encode projects
Hi jdobbs and all,
If I run a project and keep the original movie size at 1080P, keeping the main languages subs, the forced subs will automatically display. The standard subs are off by default but can be enabled at any time by the player’s subs on/off option. This is how I like so as to be the same as the original movie.
But if I run the same project but resize from 1080P to 720P the forced subs do not display automatically. I have to turn on the subs on the player but then I get all the subs and not just the forced subs. If I was to set subs to on in BD_RB then I guess I will get all subs on again and not just the forced subs.
Question is: How to setup BD_RB to just show forced subs defaulted to ON when resizing from 1080P to 720P?
Discoboy is offline   Reply With Quote
Old 7th April 2010, 13:08   #7606  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
Originally Posted by user822 View Post
Hi!
I guess you're aware that except for --ipratio 1.4 --pbratio 1.4 all of the other options you're using will produce non-compliant Blu-ray disc which probably won't play in any hardware player, aren't you?
Old 7th April 2010, 13:09   #7607  |  Link
user822
my player worked with a test stream i encoded that way, so for me there seems to be no problem!
it gives much better qual. so i would really like to use those options
Old 7th April 2010, 13:33   #7608  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
No, they'll probably play just fine. The Blu-ray spec is a massive subset of what Blu-ray players actually support, since most Blu-ray players use chipsets designed for general H.264 decoding.
Old 7th April 2010, 14:30   #7609  |  Link
jdobbs
Hi!
thanks in advance!
user
No it's NOT a bug. That's how it's supposed to work. Any options you enter will override earlier options. There are also some options that BD-RB will remove from your line because they might violate blu-ray requirements. The one's you are trying to enter very definitely do.
This is why I hesitated to add the "tweak" option and why it will probably be removed eventually.
Old 7th April 2010, 14:35   #7610  |  Link
jdobbs
Just because a player will play it doesn't mean it should be allowed. The problem is that some may not -- and folks always seem to "forget" to mention that the problem was self-inflicted when they tell me that BD-RB created a coaster.
Old 7th April 2010, 14:36   #7611  |  Link
jdobbs
If you look at the command line that was used, though, you'll see that of the things you added, the ones that would violate spec were removed by BD-RB. So the "better qual" is very likely your imagination.
While people like to play with the options that violate spec, and sometimes they're seem to work fine, it would really be a disappointment when you buy a new-and-improved player next year only to find that none of your discs work anymore.
A specification is there for a reason.
Old 7th April 2010, 14:58   #7612  |  Link
jdobbs
Originally Posted by Discoboy View Post
Hi jdobbs and all,
They should work the same way whether resized or no... but maybe I missed something. I'll take a look.
Old 7th April 2010, 16:46   #7613  |  Link
user822
so i need to encode this stream manually or is there an old version where it works 100%?
better quality is not an imagination with 10 times as much keyint more b and re-frames and rc-lookahead
worse compatibility, true
and i will not be disappointed when i buy a new blu ray player because i exactly know it might happen
Old 7th April 2010, 17:28   #7614  |  Link
jdobbs
This one works 100%, the problem isn't BD-RB, it's your decision to do it wrong. If you want to encode outside of standards, I'd suggest you use something else, because that's one thing that isn't going to change in BD-RB.
Old 7th April 2010, 17:34   #7615  |  Link
jdobbs
You really don't want to listen, do you? What you are saying is nonsense -- especially in consideration of the blu-ray standards. I've made my point. This is a bug thread and I make decisions on my software -- if you post anything else related to this non-bug, you will receive a strike. Consider yourself warned.
Old 7th April 2010, 17:35   #7616  |  Link
user822
Edit. read your post after posting mine
How can i enable the "blank this item" option? it is greyed out
Old 7th April 2010, 17:39   #7617  |  Link
jdobbs
is it compatible to encode the rest and then add the data from tsmuxer myself into the structure without the main movie?
No. Read my last post... final warning.
Old 7th April 2010, 17:45   #7618  |  Link
user822
yep I posted mine before having a chance to read yours, sorry for that!
so far ok, one mroe question:
Old 7th April 2010, 18:09   #7619  |  Link
jdobbs
It's there as a placeholder, I haven't implemented it yet. I probably should have just hidden it.
Old 7th April 2010, 23:51   #7620  |  Link
no.1_dark_knight
Snow White and the Seven Dwarfs undersized
Encoded this with my normal settings, keep English audio and subtitles, custom target size = 23800. Plenty of space on the drive, encoder high quality
final size after rebuild = 16.4 GB (17,625,186,304 bytes)
thanks
here's the log file
[20:21:39] BD Rebuilder v0.33.02 (beta)
  - Source:  SNOW.WHITE.AND.THE.SEVEN.DWARFS
  - Input BD size: 33.01 GB
  - Approximate total content: [02:14:21.553]
  - Target BD size: 23.24 GB
  - Windows Version: 6.1 [7600]
[20:21:42] PHASE ONE, Encoding
 - [20:21:42] Extracting A/V streams [VID_00054]
 - [20:21:44] Reencoding: VID_00054 (1 of 48)
 - [20:21:44] Collecting video information
   - Rate/Length: 23.976fps, 359 frames
   - Bitrate: 11,175 Kbs
 - [20:21:44] Reencoding: VID_00054, Pass 1 of 2
 - [20:21:57] Reencoding: VID_00054, Pass 2 of 2
 - [20:22:20] Video Encode complete
 - [20:22:20] Reencoding audio tracks (if req'd)
 - [20:22:20] Multiplexing M2TS
 - [20:22:21] Extracting A/V streams [VID_00094]
 - [20:22:22] Reencoding: VID_00094 (2 of 48)
 - [20:22:22] Collecting video information
   - Rate/Length: 23.976fps, 76 frames
   - Bitrate: 10,977 Kbs
 - [20:22:22] Reencoding: VID_00094, Pass 1 of 2
 - [20:22:25] Reencoding: VID_00094, Pass 2 of 2
 - [20:22:31] Video Encode complete
 - [20:22:31] Reencoding audio tracks (if req'd)
 - [20:22:31] Multiplexing M2TS
 - [20:22:32] Extracting A/V streams [VID_00095]
 - [20:22:33] Reencoding: VID_00095 (3 of 48)
 - [20:22:33] Collecting video information
   - Rate/Length: 23.976fps, 161 frames
   - Bitrate: 11,165 Kbs
 - [20:22:33] Reencoding: VID_00095, Pass 1 of 2
 - [20:22:40] Reencoding: VID_00095, Pass 2 of 2
 - [20:22:53] Video Encode complete
 - [20:22:53] Reencoding audio tracks (if req'd)
 - [20:22:53] Multiplexing M2TS
 - [20:22:54] Extracting A/V streams [VID_00121]
 - [20:22:55] Reencoding: VID_00121 (4 of 48)
 - [20:22:55] Collecting video information
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 23.976fps, 168 frames
   - Bitrate: 11,512 Kbs
 - [20:22:55] Reencoding: VID_00121, Pass 1 of 2
 - [20:23:03] Reencoding: VID_00121, Pass 2 of 2
 - [20:23:22] Video Encode complete
 - [20:23:22] Reencoding audio tracks (if req'd)
 - [20:23:22] Multiplexing M2TS
 - [20:23:22] Extracting A/V streams [VID_00122]
 - [20:23:33] Reencoding: VID_00122 (5 of 48)
 - [20:23:33] Collecting video information
   - Rate/Length: 23.976fps, 1,824 frames
   - Bitrate: 16,402 Kbs
 - [20:23:33] Reencoding: VID_00122, Pass 1 of 2
 - [20:25:14] Reencoding: VID_00122, Pass 2 of 2
 - [20:30:26] Video Encode complete
 - [20:30:26] Reencoding audio tracks (if req'd)
 - [20:30:26] Multiplexing M2TS
 - [20:30:30] Extracting A/V streams [VID_00123]
 - [20:30:31] Reencoding: VID_00123 (6 of 48)
 - [20:30:31] Collecting video information
   - Bitrate: 10,834 Kbs
 - [20:30:31] Reencoding: VID_00123, Pass 1 of 2
 - [20:30:38] Reencoding: VID_00123, Pass 2 of 2
 - [20:31:04] Video Encode complete
 - [20:31:04] Reencoding audio tracks (if req'd)
 - [20:31:04] Multiplexing M2TS
 - [20:31:05] Extracting A/V streams [VID_00124]
 - [20:31:26] Reencoding: VID_00124 (7 of 48)
 - [20:31:26] Collecting video information
   - Rate/Length: 23.976fps, 3,674 frames
   - Bitrate: 17,009 Kbs
 - [20:31:26] Reencoding: VID_00124, Pass 1 of 2
 - [20:34:14] Reencoding: VID_00124, Pass 2 of 2
 - [20:43:25] Video Encode complete
 - [20:43:25] Reencoding audio tracks (if req'd)
 - [20:43:25] Multiplexing M2TS
 - [20:43:32] Extracting A/V streams [VID_00125]
 - [20:43:33] Reencoding: VID_00125 (8 of 48)
 - [20:43:33] Collecting video information
   - Bitrate: 10,822 Kbs
 - [20:43:33] Reencoding: VID_00125, Pass 1 of 2
 - [20:43:41] Reencoding: VID_00125, Pass 2 of 2
 - [20:44:03] Video Encode complete
 - [20:44:03] Reencoding audio tracks (if req'd)
 - [20:44:03] Multiplexing M2TS
 - [20:44:03] Extracting A/V streams [VID_00126]
 - [20:44:16] Reencoding: VID_00126 (9 of 48)
 - [20:44:16] Collecting video information
   - Rate/Length: 23.976fps, 2,136 frames
   - Bitrate: 17,123 Kbs
 - [20:44:16] Reencoding: VID_00126, Pass 1 of 2
 - [20:46:02] Reencoding: VID_00126, Pass 2 of 2
 - [20:51:29] Video Encode complete
 - [20:51:29] Reencoding audio tracks (if req'd)
 - [20:51:29] Multiplexing M2TS
 - [20:51:33] Extracting A/V streams [VID_00127]
 - [20:51:44] Reencoding: VID_00127 (10 of 48)
 - [20:51:44] Collecting video information
   - Rate/Length: 23.976fps, 1,728 frames
   - Bitrate: 17,597 Kbs
 - [20:51:44] Reencoding: VID_00127, Pass 1 of 2
 - [20:53:05] Reencoding: VID_00127, Pass 2 of 2
 - [20:58:18] Video Encode complete
 - [20:58:18] Reencoding audio tracks (if req'd)
 - [20:58:18] Multiplexing M2TS
 - [20:58:22] Extracting A/V streams [VID_00129]
 - [20:58:43] Reencoding: VID_00129 (11 of 48)
 - [20:58:43] Collecting video information
   - Rate/Length: 23.976fps, 3,648 frames
   - Bitrate: 15,982 Kbs
 - [20:58:43] Reencoding: VID_00129, Pass 1 of 2
 - [21:01:39] Reencoding: VID_00129, Pass 2 of 2
 - [21:10:50] Video Encode complete
 - [21:10:50] Reencoding audio tracks (if req'd)
 - [21:10:50] Multiplexing M2TS
 - [21:10:57] Extracting A/V streams [VID_00130]
 - [21:11:04] Reencoding: VID_00130 (12 of 48)
 - [21:11:04] Collecting video information
   - Rate/Length: 23.976fps, 1,224 frames
   - Bitrate: 15,074 Kbs
 - [21:11:04] Reencoding: VID_00130, Pass 1 of 2
 - [21:12:02] Reencoding: VID_00130, Pass 2 of 2
 - [21:15:03] Video Encode complete
 - [21:15:03] Reencoding audio tracks (if req'd)
 - [21:15:03] Multiplexing M2TS
 - [21:15:05] Extracting A/V streams [VID_00131]
 - [21:15:19] Reencoding: VID_00131 (13 of 48)
 - [21:15:19] Collecting video information
   - Rate/Length: 23.976fps, 2,232 frames
   - Bitrate: 15,636 Kbs
 - [21:15:19] Reencoding: VID_00131, Pass 1 of 2
 - [21:17:00] Reencoding: VID_00131, Pass 2 of 2
 - [21:23:16] Video Encode complete
 - [21:23:16] Reencoding audio tracks (if req'd)
 - [21:23:16] Multiplexing M2TS
 - [21:23:20] Extracting A/V streams [VID_00132]
 - [21:23:34] Reencoding: VID_00132 (14 of 48)
 - [21:23:34] Collecting video information
   - Rate/Length: 23.976fps, 2,304 frames
   - Bitrate: 16,492 Kbs
 - [21:23:34] Reencoding: VID_00132, Pass 1 of 2
 - [21:25:37] Reencoding: VID_00132, Pass 2 of 2
 - [21:32:43] Video Encode complete
 - [21:32:43] Reencoding audio tracks (if req'd)
 - [21:32:43] Multiplexing M2TS
 - [21:32:48] Extracting A/V streams [VID_00133]
 - [21:33:02] Reencoding: VID_00133 (15 of 48)
 - [21:33:02] Collecting video information
   - Rate/Length: 23.976fps, 2,448 frames
   - Bitrate: 16,828 Kbs
 - [21:33:02] Reencoding: VID_00133, Pass 1 of 2
 - [21:35:38] Reencoding: VID_00133, Pass 2 of 2
 - [21:43:40] Video Encode complete
 - [21:43:40] Reencoding audio tracks (if req'd)
 - [21:43:40] Multiplexing M2TS
 - [21:43:45] Extracting A/V streams [VID_00134]
 - [21:43:50] Reencoding: VID_00134 (16 of 48)
 - [21:43:50] Collecting video information
   - Rate/Length: 23.976fps, 768 frames
   - Bitrate: 16,932 Kbs
 - [21:43:50] Reencoding: VID_00134, Pass 1 of 2
 - [21:44:30] Reencoding: VID_00134, Pass 2 of 2
 - [21:47:11] Video Encode complete
 - [21:47:11] Reencoding audio tracks (if req'd)
 - [21:47:11] Multiplexing M2TS
 - [21:47:12] Extracting A/V streams [VID_00137]
 - [21:47:57] Reencoding: VID_00137 (17 of 48)
 - [21:47:57] Collecting video information
   - Rate/Length: 23.976fps, 11,156 frames
   - Bitrate: 11,572 Kbs
 - [21:47:57] Reencoding: VID_00137, Pass 1 of 2
 - [21:58:38] Reencoding: VID_00137, Pass 2 of 2
 - [22:29:02] Video Encode complete
 - [22:29:02] Reencoding audio tracks (if req'd)
 - [22:29:02] Multiplexing M2TS
 - [22:29:29] Extracting A/V streams [VID_00138]
 - [22:30:12] Reencoding: VID_00138 (18 of 48)
 - [22:30:12] Collecting video information
   - Rate/Length: 23.976fps, 5,146 frames
   - Bitrate: 18,112 Kbs
 - [22:30:12] Reencoding: VID_00138, Pass 1 of 2
 - [22:34:37] Reencoding: VID_00138, Pass 2 of 2
 - [22:50:12] Video Encode complete
 - [22:50:12] Reencoding audio tracks (if req'd)
 - [22:50:12] Multiplexing M2TS
 - [22:50:33] Extracting A/V streams [VID_00139]
 - [22:51:20] Reencoding: VID_00139 (19 of 48)
 - [22:51:20] Collecting video information
   - Rate/Length: 23.976fps, 12,574 frames
   - Bitrate: 11,110 Kbs
 - [22:51:20] Reencoding: VID_00139, Pass 1 of 2
 - [23:01:26] Reencoding: VID_00139, Pass 2 of 2
 - [23:28:37] Video Encode complete
 - [23:28:37] Reencoding audio tracks (if req'd)
 - [23:28:37] Multiplexing M2TS
 - [23:29:02] Extracting A/V streams [VID_00207]
 - [23:29:08] Reencoding: VID_00207 (20 of 48)
 - [23:29:08] Collecting video information
   - Rate/Length: 23.976fps, 1,537 frames
   - Bitrate: 10,937 Kbs
 - [23:29:08] Reencoding: VID_00207, Pass 1 of 2
 - [23:30:35] Reencoding: VID_00207, Pass 2 of 2
 - [23:33:55] Video Encode complete
 - [23:33:55] Reencoding audio tracks (if req'd)
 - [23:33:55] Multiplexing M2TS
 - [23:33:58] Extracting A/V streams [VID_00211]
 - [23:33:59] Reencoding: VID_00211 (21 of 48)
 - [23:33:59] Collecting video information
   - Rate/Length: 23.976fps, 77 frames
   - Bitrate: 11,356 Kbs
 - [23:33:59] Reencoding: VID_00211, Pass 1 of 2
 - [23:34:03] Reencoding: VID_00211, Pass 2 of 2
 - [23:34:13] Video Encode complete
 - [23:34:13] Reencoding audio tracks (if req'd)
 - [23:34:13] Multiplexing M2TS
 - [23:34:13] Extracting A/V streams [VID_00214]
 - [23:34:14] Reencoding: VID_00214 (22 of 48)
 - [23:34:14] Collecting video information
   - Rate/Length: 23.976fps, 73 frames
   - Bitrate: 11,761 Kbs
 - [23:34:14] Reencoding: VID_00214, Pass 1 of 2
 - [23:34:18] Reencoding: VID_00214, Pass 2 of 2
 - [23:34:27] Video Encode complete
 - [23:34:27] Reencoding audio tracks (if req'd)
 - [23:34:27] Multiplexing M2TS
 - [23:34:28] Extracting A/V streams [VID_00217]
 - [23:34:29] Reencoding: VID_00217 (23 of 48)
 - [23:34:29] Collecting video information
   - Bitrate: 11,599 Kbs
 - [23:34:29] Reencoding: VID_00217, Pass 1 of 2
 - [23:34:33] Reencoding: VID_00217, Pass 2 of 2
 - [23:34:42] Video Encode complete
 - [23:34:42] Reencoding audio tracks (if req'd)
 - [23:34:42] Multiplexing M2TS
 - [23:34:43] Extracting A/V streams [VID_00220]
 - [23:34:43] Reencoding: VID_00220 (24 of 48)
 - [23:34:43] Collecting video information
   - Rate/Length: 23.976fps, 72 frames
   - Bitrate: 11,234 Kbs
 - [23:34:43] Reencoding: VID_00220, Pass 1 of 2
 - [23:34:47] Reencoding: VID_00220, Pass 2 of 2
 - [23:34:57] Video Encode complete
 - [23:34:57] Reencoding audio tracks (if req'd)
 - [23:34:57] Multiplexing M2TS
 - [23:34:57] Extracting A/V streams [VID_00223]
 - [23:34:58] Reencoding: VID_00223 (25 of 48)
 - [23:34:58] Collecting video information
   - Bitrate: 11,580 Kbs
 - [23:34:58] Reencoding: VID_00223, Pass 1 of 2
 - [23:35:02] Reencoding: VID_00223, Pass 2 of 2
 - [23:35:11] Video Encode complete
 - [23:35:11] Reencoding audio tracks (if req'd)
 - [23:35:11] Multiplexing M2TS
 - [23:35:12] Extracting A/V streams [VID_00226]
 - [23:35:13] Reencoding: VID_00226 (26 of 48)
 - [23:35:13] Collecting video information
   - Bitrate: 11,409 Kbs
 - [23:35:13] Reencoding: VID_00226, Pass 1 of 2
 - [23:35:17] Reencoding: VID_00226, Pass 2 of 2
 - [23:35:26] Video Encode complete
 - [23:35:26] Reencoding audio tracks (if req'd)
 - [23:35:26] Multiplexing M2TS
 - [23:35:27] Extracting A/V streams [VID_00229]
 - [23:35:27] Reencoding: VID_00229 (27 of 48)
 - [23:35:27] Collecting video information
   - Bitrate: 11,485 Kbs
 - [23:35:27] Reencoding: VID_00229, Pass 1 of 2
 - [23:35:32] Reencoding: VID_00229, Pass 2 of 2
 - [23:35:41] Video Encode complete
 - [23:35:41] Reencoding audio tracks (if req'd)
 - [23:35:41] Multiplexing M2TS
 - [23:35:42] Extracting A/V streams [VID_00232]
 - [23:35:42] Reencoding: VID_00232 (28 of 48)
 - [23:35:42] Collecting video information
   - Bitrate: 11,561 Kbs
 - [23:35:42] Reencoding: VID_00232, Pass 1 of 2
 - [23:35:46] Reencoding: VID_00232, Pass 2 of 2
 - [23:35:56] Video Encode complete
 - [23:35:56] Reencoding audio tracks (if req'd)
 - [23:35:56] Multiplexing M2TS
 - [23:35:56] Extracting A/V streams [VID_00235]
 - [23:35:57] Reencoding: VID_00235 (29 of 48)
 - [23:35:57] Collecting video information
   - Bitrate: 11,656 Kbs
 - [23:35:57] Reencoding: VID_00235, Pass 1 of 2
 - [23:36:01] Reencoding: VID_00235, Pass 2 of 2
 - [23:36:10] Video Encode complete
 - [23:36:10] Reencoding audio tracks (if req'd)
 - [23:36:10] Multiplexing M2TS
no.1_dark_knight is offline   Reply With Quote
