18th April 2008, 16:45 | #1061 | Link |
There has to be a difference between AVCHD and BD. Does a "normal" BD structure (from a BD disk) work on a DVD ? (with a m2ts file fitting within a DVD9), with menues, etc....
I believe the PS3, after fw 1.8, changed something because in past fw versions DVDs were identified as BDMV (and maybe supporting "full BD specs") and now they either do not load (disks made with tsremux at that time do no longer work) or load as AVCHD... |
18th April 2008, 16:46 | #1062 | Link | |
My results: I Am Legend: Works with True-HD down converted to AC3. Walk Hard: Works with True-HD down converted to AC3. Juno: Works with AC3 track selected for muxing. AVP2: Works with Fra/Spa AC3 track selected, English DTS-HD does not work no matter what settings I use. Before The Devil Knows You're Dead: Works with DTS-HD selected. I will continue to post results for different films as I back them up. Hopefully it might save some people some time and frustration. |
18th April 2008, 16:50 | #1063 | Link | |
18th April 2008, 16:56 | #1064 | Link | |
Try leaving tsMuxers settings at default, and also checking "no chapters" under the Blu-ray tab. Last edited by wakebrder; 18th April 2008 at 16:59. |
18th April 2008, 17:52 | #1065 | Link |
List index out of bounds (0)
I just upgraded to 1.7.6 and I keep getting this pop-up.
"List index out of bounds (0)" I am adding the first (Main) m2ts file when this happens. Can anyone tell me what I am doing wrong? Thanks, Duramaximus |
18th April 2008, 23:35 | #1066 | Link |
Want to say thanks to you Roman, this program is wonderful and I have been doing many things with it. However there is a bug with the MPLS feature. When I added the MPLS for Walk Hard it adds the proper .m2ts files as it should and combines them. However when I click 'Start muxing' and try to output it as a .ts, m2ts, or demux it I get this error message: "Can't find MPLS file for stream I:\BDMV\STREAM\00000.m2ts"
There doesn't seem to be a way around it and it says this for every .MPLS I try. |
18th April 2008, 23:39 | #1067 | Link | |
I did have problems running the output of Walk Hard through Ripbot. Ripbot only encoded half the movie then stopped. |
19th April 2008, 02:28 | #1068 | Link |
ERROR: Alexander The Final Cut Blu-Ray
I'm getting the message "Bitstream exception. It does not have to be! Plase contact the application support team for more information." when I try and remux Alexander The Final Cut BD.
The file is in fact the m2ts from disc's one and two merged using "copy /b" because this on two discs in Blu-Ray is shocking and lazy so I wanted a one Blu-Ray solution. Hope you can fix this, and amazing program |
19th April 2008, 03:31 | #1069 | Link |
I have made Blu-Ray playable from USB HDD formated in fat32, I remuxed Predator (MPEG2, DTS HD MA and subtitles), I checked split every 4GB(fat32), I have renamed nessecary files and put it in AVCHD folder in root directory of HDD. it played perfekt
19th April 2008, 08:55 | #1073 | Link | |
Caped Crusader
Cheers. |
19th April 2008, 10:10 | #1075 | Link |
Caped Crusader
As simple as that. ( well don't I feel foolish )
Thats what I was doing wrong. I just put the BDMV folder at the root of my drive and it didn't work. Now putting it inside a 'AVCHD' folder in the root works. Just did Ronin with DTS audio and 2 subtitle tracks. Cheers to jagaskywalker, Warrex and americanpsycho. This should save quite a few hours/days re-encoding. Last edited by B4tm4n; 19th April 2008 at 10:30. |
19th April 2008, 10:47 | #1076 | Link | |
J |
19th April 2008, 12:14 | #1077 | Link |
streaming 7.1 LPCM from PC to PS3 corrupted
Hi, I have successfully created videos using this great program, Tsmuxer with 5.1 LPCM and streamed them from my Vista 64 PC to my latest version 2.3 PS3 80gb with no problems. When I try 310: to Yuma using the 7.1 track I get a corrupted data file when trying to stream it. Is 7.1 not supported or am I doing something wrong? I do have a receiver that will handle the 7.1, Integra 7.8. Also, I am using Tversity as the media server. Thank you for all the great work on the terrific program Roman. Thank you for any help.
20th April 2008, 18:48 | #1079 | Link | |
Similarly I'm still having problems converting my HD-DVD collection to the TVIX 6500. The only was to get a clean conversion is to use evodemux, vc1conv and the tsmuxer to put it all back together. I get various problems using tsmuxer alone ranging from 'please resync' messages to tsmuxer encountered an error and had to end messages. Thanks. Mike. |
20th April 2008, 19:46 | #1080 | Link |
Custom chapter list is not working for me when creating a Blu-ray disk. When I go to the next chapter, PowerDVD or PS3 skips to the end of the movie and start over. Insert chapter every X minutes works fine.
Update: Custom chapter list is now working fine. I was putting in 00:00:00:000 instead of 00:00:00.000 (period instead of colon on the left) Last edited by SCSI; 21st April 2008 at 00:35. |
tsmuxer |
