Old 27th January 2008, 02:18   #41  |  Link
roman76r
M2TS muxing is ready. Look the first post.
roman76r is offline   Reply With Quote
Old 27th January 2008, 02:28   #42  |  Link
The1n
Great stuff, but im only getting a 404 when trying to download.
Thx
The1n
The1n is offline   Reply With Quote
Old 27th January 2008, 02:31   #43  |  Link
The1n
Now it worked... thank you Roman.
Old 27th January 2008, 02:33   #44  |  Link
survivant001
@roman76r
next step is the subtitle or avchd output, chapters ?
really nice of you for your program. Didn't took you so long to add m2ts feature.
oh ya.. you can add the feature : multiple sources in the input text box. instead of choosing the video, after that choosing the audio
survivant001 is offline   Reply With Quote
Old 27th January 2008, 02:39   #45  |  Link
puppydg68
This is because your mkv was encoded with b-pyramid.
can a b-pyramid encode be converted losslessly to work on ps3, or does it require a totally new encode?
puppydg68 is offline   Reply With Quote
Old 27th January 2008, 02:50   #46  |  Link
It requires a new encode.
Old 27th January 2008, 02:58   #47  |  Link
The1n
Correct me if i am wrong but x264 from version 721 onwards does work with b-pyramid for dxva and ps3 ?
The1n
Old 27th January 2008, 03:11   #48  |  Link
The1n
@roman
Any idea why your program says "AC3 bad frame detected. Resync stream." when im trying to remux a bluray m2ts, it works if i demux the ac3 track first and mux it into the avc stream.
The1n
Old 27th January 2008, 03:49   #49  |  Link
jamos
Hey Now!
works great for the ps3 using ts. the 4.1 lvl set does not seem to work correctly though I had to use h264info on the elementary stream first but no big deal. After that remuxed the 4.1 elementary video and audio streams into a ts file. really quick program muxed 4.6 gig in like 5 minutes. Plays fine on ps3 with ff/rw working. PS3 owners should love ya Roman!
Now with m2ts support we can make mini bluray discs also using dvds that will play on the ps3..
jamos is offline   Reply With Quote
Old 27th January 2008, 04:00   #50  |  Link
Bigmango
Same problem here.
Bigmango is offline   Reply With Quote
Old 27th January 2008, 09:09   #51  |  Link
Zow
roman76r, his is just beautiful.
Please, consider adding subtitles sooner rather than later.
Thanks!
Zow is offline   Reply With Quote
Old 27th January 2008, 09:21   #52  |  Link
yonta
Thank you for the quick update!
DTS/DTS-HD tracks in EVO are now correctly recognized.
VC-1 in m2ts(NIN Live) is also working now.
yonta is offline   Reply With Quote
Old 27th January 2008, 12:17   #53  |  Link
kleen
Any chance to have demux option (enabled) as well?
kleen is offline   Reply With Quote
Old 27th January 2008, 13:19   #54  |  Link
ultratoto14
Problem with the new version.
Same AC3 + H264 muxed to ts with 1.1.5 is seekable with mpc and vlc but is seekable only with vlc when muxed with the 1.2.0 version.
ultratoto14 is offline   Reply With Quote
Old 27th January 2008, 15:06   #55  |  Link
roman76r
ultratoto14
Try this version
Old 27th January 2008, 15:15   #56  |  Link
ultratoto14
Same problem with this version. VLC ok MPC ko
Another little requirement, is it possible to take audio delay from the source (ts, vob(ps3), mkv) and directly use it during the mux process ?
Old 27th January 2008, 15:29   #57  |  Link
survivant001
just for the info.. I try a movie 264+ac3 encoded in 4.1. It work well on the PS3. ff + rw work. but it take like 2 sec after the ff to start playing.
but it works.. really happy
Old 27th January 2008, 16:04   #58  |  Link
zAndy1
Looks like a useful app but not 100% sure what this does to be honest (sorry I'm a noob!). Can I just take a 720p .mkv file with AC3 audio and select that as the input file and the resulting output file should play on my PS3? Or do I need to do anything with the file before I use the tsMuxer GUI on it?
Thanks
Andy
zAndy1 is offline   Reply With Quote
Old 27th January 2008, 16:22   #59  |  Link
survivant001
Thanks
Andy
no
check this post : http://forum.doom9.org/showthread.php?t=133192
and
http://forum.doom9.org/showthread.ph...45#post1091845
if your not familliar with encoding process.. just download ripbot264 or automkv.
if you need more help.. just PM me.
Old 27th January 2008, 16:29   #60  |  Link
lance79
Dude... thx alot for this tool, i just tried it on a wmv 720p sample and vc1 seems to work
I only had to convert wma to ac3 and muxed it to m2ts, after that i used tsremux to create blu-ray output plays fine on my ps3.
One question, a lot of movies come in 1280x544 or simular, it is not possible to create blu-ray/avchd with this without reencode to 1280x720
Isnt it possible to have a tool that edit,resize the images/frames of a movie asf,wmv or h264 that only ads black borders to it so it become a hd standard.
That would be a fast convert without quality loss...
greetz,
lance
lance79 is offline   Reply With Quote
tsmuxer
