20th September 2014, 17:07 | #12802 | Link |
Not sure it qualifies as a bug per se. Since the Atmos TrueHD stream is said to be fully backwards compatible (= can be played on regular players), I can only draw the conclusion, that they put the Atmos 'ceiling' channels into the metadata (which receivers are supposed to ignore; which is why this works, I presume).
So, all we really need is a knowledgeable coder (you?!) who will strip off the metadata, so we have a regular TrueHD stream again, right?
Gorgeous, delicious, deculture! |
20th September 2014, 17:37 | #12803 | Link |
imho it would be preferable being able to decode the entire stream completely.
20th September 2014, 17:50 | #12804 | Link |
When I use the command to extract the Dolby Atmos to mono wavs. I get this error:
eac3to v3.24 command line: eac3to.exe "trans.4.thd+ac3" Vie.wavs ------------------------------------------------------------------------------ The format of the source file could not be detected. <ERROR> |
20th September 2014, 17:51 | #12805 | Link | |
Regarding getting the original TrueHD stream out, its not that easy, its not just metadata you have to ignore, its properly integrated into the TrueHD codec itself, and will need proper fixing of the decoder. Its possible that it would work if we had an "official" TrueHD decoder or a specification, but since the ffmpeg/libav TrueHD decoder is practically reverse engineered, it lacks the ability to deal with those streams, for now.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 20th September 2014 at 17:56. |
20th September 2014, 17:59 | #12806 | Link |
Then I wonder how current receivers are able to play the Atmos-enhanced TrueHD stream just fine, if the Atmos data were really a part of the main TrueHD stream. There's obviously some 'easily' discardable info, or current receivers would not be able to pull it off cleanly.
20th September 2014, 18:44 | #12807 | Link |
Like I said, if we had the specification of TrueHD, it could tell us what is wrong, but since Dolby is not giving that out, its not that easy.
20th September 2014, 21:10 | #12808 | Link | |
maybe the guy knows who told madshi how to deal with the TrueHD track headers back then when there were those THD delay problems because madshi accidentally stripped too much from these tracks.
21st September 2014, 02:29 | #12809 | Link | |
Angel of Night
21st September 2014, 03:36 | #12812 | Link | |
And, even though I understand it's just temporary, I would *still* like ffmpeg/eac3to to retain the option to merely extract the TrueHD core (akin to extracting an AC3 core from the TrueHD stream), so as to have something playable/usable on my system. P.S. Thanks for the speedy patch!
21st September 2014, 04:36 | #12815 | Link |
Yeah, someone please tell us where this alleged patch resides: the 'posted' patch is just a mailing list post.
I tried the latest binary, and it says: Code:
c:\eac3to\ffmpeg -i "test.m2ts" -vn -ac 8 -acodec pcm_s24le -f wav c:\video\temp.wav [truehd @ 02bb57e0] major sync info header checksum error Last message repeated 42 times [NULL @ 02bb57e0] start time for stream 1 is not set in estimate_timings_from_pts [mpegts @ 02bb9080] Could not find codec parameters for stream 1 (Audio: truehd (AC-3 / 0x332D4341), 0 channels): unspecified sample format Code:
Mixing surround channels... Writing WAV... Creating file "c:\video\finak.wav"... Original audio track, L+R+C+LFE+SL+SR: constant bit depth of 24 bits Original audio track, BL+BR: no audio data. The processed audio track has a constant bit depth of 24 bits.
25th September 2014, 11:06 | #12819 | Link | |
http://ffmpeg.zeranoe.com/builds/
28th September 2014, 15:02 | #12820 | Link | |
the Interrogator
TIA Last edited by JimmyBarnes; 28th September 2014 at 15:19. |
eac3to |
