20th November 2011, 15:58 | #13601 | Link | |
The source for the x264 tests was a single file on the SSD array. The source I use for my rebuilds are ISO files made with Anydvd that reside on a regular HDD. Last edited by Chuckwagon; 20th November 2011 at 16:01. |
20th November 2011, 16:28 | #13602 | Link | |
20th November 2011, 16:53 | #13603 | Link | |
Sometimes I just have to laugh at myself. I'll fix it for the next release. Thanks again for the report. Last edited by jdobbs; 20th November 2011 at 16:58. |
20th November 2011, 17:19 | #13604 | Link |
Currently I get a problem with CRF prediction for a multi-segment movie. For one of the segments the prediction converges in one single step from 22.48 (initial value) to the final value of 36.24 and the quality is accoridingly poor. Therefore I try to get around it by adjusting parameters.
According to hiddenoptions.txt the 2 params are: GROUP_SIZE= SAMPLE_SIZE= According to the original post here the 2 params are: SAMPLE_GROUP= SAMPLE_SIZE= Which syntax is the correct one? Edit: I understood that for "very short" segments BD-RB will fall back automatically to 2-pass. However it seems that it does a CRF prediction for short segments as well. Is there a parameter which defines the size of a "short segment" below which a 2-pass encode is automatically done in place of the CRF prediction? Last edited by Sharc; 20th November 2011 at 17:39. Reason: Added |
20th November 2011, 18:50 | #13605 | Link | |
The default SAMPLE_SIZE is 2x the source framerate and the default SAMPLE_GROUP is 200x the source framerate. So a 24fps source would be sampled every 4800 frames using a sample of 48 frames. If you set a fixed sample group/rate, however -- it uses what you've set regardless of the input frame rate. Last edited by jdobbs; 20th November 2011 at 18:55. |
20th November 2011, 20:08 | #13606 | Link | |
This means that by default any segment shorter than 4800 frames (for a 24 fps source) would be based on the first 48 frames for CRF prediction, correct? If these first 48 frames are of simple structure (e.g. fading from black) we could end up in very biased CRF prediction for this segment? Perhaps segments of <4800 frames should be automatically 2-pass encoded, or 4800 should be auto-reduced such that at least 2 groups of 48 frames are used for CRF prediction? Normally CRF prediction works very well , with occasional exceptions for segmented sources (small segments). Perhaps too complicated .... |
20th November 2011, 20:34 | #13607 | Link | |
Glad you were able to find it, and happy to be of help. And thank you for such an awesome tool. |
20th November 2011, 21:28 | #13608 | Link |
PIP with DTS-Express Seems To Work on PS3
FYI, as a test I just did a full BD25 backup of Let Me In using BD Rebuilder 39.03. Since it has PIP with DTS-Express secondary audio on the main feature, I set DTSX_ENABLE to 1. The burned disk worked flawlessly on my PS3.
20th November 2011, 22:29 | #13609 | Link | |
The default does a 1% sample -- but you could always make it 2% or even 3% (e.g. SAMPLE_GROUP=1200, SAMPLE_SIZE=48). Be careful with smaller sample sizes, you really don't want to get below GOP sizes as it can make prediction less accurate. Last edited by jdobbs; 20th November 2011 at 22:37. |
21st November 2011, 00:11 | #13610 | Link | |
Never mind, such cases should perhaps better be done using 2-pass a priori rather than 1-pass CRF predictive mode (I just like it and tried.... ). |
21st November 2011, 03:26 | #13611 | Link |
Isn't using 2-pass encoding on a movie in multiple pieces a bad idea since each piece has no visibility to any other piece and some parts could end up wasting bitrate that would be better used elsewhere netting inconsistent visual quality between the pieces? It seems like CRF would be the best way to maintain quality between the various pieces with the challenge being the determination of what CRF value to use (across all the pieces).
21st November 2011, 05:28 | #13612 | Link | |
21st November 2011, 06:47 | #13613 | Link |
hi...
i can confirm that the blurays are stopped to work in the latest versions in some players... i have a lg bd-370 and the titles (not all.. 90%) get black screen... but in my ps3 works fine... in the tv... i get a black screen.. and in the screen of player the counter is in 0:00:00:00 i will try to encode with 38.08... i will report tomorrow.. Last edited by santito; 21st November 2011 at 07:12. |
21st November 2011, 15:34 | #13614 | Link | |
This is a thread for reporting bugs... with necessary information to make fixes. How can I fix something when I have no idea what it is. Last edited by jdobbs; 21st November 2011 at 15:37. |
21st November 2011, 16:45 | #13615 | Link |
hi...
sorry i was not very specific... i use 39.03 ....full movie backup (bd-25)... i guess is not my encode machine (pc).. because others have reported the same issue... not working in that particular player (lg bd-370) and panasonic player |
21st November 2011, 17:09 | #13616 | Link |
I'm not sure where you're seeing the "others" -- because this is the bug thread and I don't see it here. It sounds like your player doesn't support the type of disc you're using. What make/brand is it? If using Imgburn, report what it says about the empty disc.
21st November 2011, 19:45 | #13617 | Link |
I have a LG bd-370 which I don't often use, but I have just checked a bd-25 disc I did with 39.03 and it was okay. However, the LG is a bit choosy and certainly on bd-9 only plays discs without jar files. It may be that it has problems with certain discs.
21st November 2011, 21:50 | #13618 | Link |
Hi there, i have a question , hope i dont bother anyone with this, is just a simpel question, how can i set bdrebuilder to work using dual-procesor, i mean, using 64 bit operating system, i found that in tool folder you have x264-64 and setacl_x64, is it a way to set those so i can rebuild movies faster? just a question, thanks
21st November 2011, 22:13 | #13619 | Link |
setacl is not an encoder. it is only used for setting ffdshow as preffered decoder in windows 7.
