24th November 2012, 17:16 | #20421 | Link |
@v0lt
Bug: Get a file with multiple embedded audio streams. Put an audio file with same name in the same folder. MPC-HC will then load that audio file as a dub. Play>Audio will correctly show all embedded plus the external audio track. The bug is that Navigate>AudioLanguage only shows the external audio track. Feature request: Play>Audio should show all embedded audio tracks even when the internal stream switcher is disabled. Listing the external one (if any) is not needed in this case, since that one can't be deselected anyway with stream switcher disabled. Feature request: Play>Subtitles should show both external and embedded subtitle tracks. (since most people don't know about the options in the Navigate menu)
MPC-HC 2.2.1 |
24th November 2012, 20:20 | #20422 | Link | ||
@clsid
24th November 2012, 20:43 | #20423 | Link | |
MPC-HC Developer
Yeah, I would like to see that "fixed" too Here is the ticket https://sourceforge.net/apps/trac/mpc-hc/ticket/1394 and here https://sourceforge.net/apps/trac/mpc-hc/changeset/4235 is reverted Aleksoid's attempt to improve that. There were problem with external track when using LAV splitter IIRC.
We should leave one track selection dialog. For example: embedded streams /separator/ external streams (if any) Of course separate menus for audio and subtitles. Last edited by kasper93; 24th November 2012 at 21:05. |
24th November 2012, 21:47 | #20424 | Link | |
The audio switcher is not needed when using LAV or Haali splitter.
MPC-HC 2.2.1 |
24th November 2012, 22:24 | #20426 | Link |
Yes, but not for embedded tracks. My reply was to v0lt who claimed it was always needed.
MPC-HC 2.2.1 |
24th November 2012, 23:13 | #20428 | Link |
People may choose to disable it because they don't need it, and avoid that data copy.
The point is that Play>Audio should also show the tracks from IAMStreamSelect when the audio switcher is disabled. That functionality does not depend on the switcher, so it should be irrelevant whether it is enabled or not.
MPC-HC 2.2.1 |
25th November 2012, 06:55 | #20429 | Link |
Fantasy Codecs writer
S.Chinese update
http://www.mediafire.com/?w8pu9xtalt2ezk9 |
25th November 2012, 09:41 | #20430 | Link | |
Is this a some scary power of two implementation? Last edited by 73ChargerFan; 25th November 2012 at 09:43. |
25th November 2012, 14:54 | #20432 | Link | |
Process Monitor MPC-HC + 1080P + Ctrl+J + next video file Process Monitor |
25th November 2012, 15:21 | #20433 | Link |
hello
I have the following problem maybe bug when I play a avi file with mp3 audio, it shuttering. After testing I found that the problem is when audio is mp3 with constant bitrate and sample rate different of 48000. Also when I disable all filters from player leaving splitters MPC-HC try to play audio with default MP3 codec of windows although I have LAV filters enable, and then it freeze in first frame, but player doesn't crash, you can close it. with all filters disabling including splitters play normally with LAV filters Last edited by tasi; 25th November 2012 at 15:25. |
26th November 2012, 02:41 | #20434 | Link | |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
26th November 2012, 16:02 | #20435 | Link |
Hi, I have a simple cosmetic request.
When using LAV Video Decoder, is it possible to have the status bar show "Playing [CUVID]" or "Playing [QuickSync]" if either those hardware acceleration methods is being used by the LAV video decoder? It already shows DXVA, even when using external filters, Like Cyberlink's video decoder, so maybe this can be done? |
26th November 2012, 17:59 | #20436 | Link |
here is a sample
http://www.mediafire.com/?9etgci76v0mf3v5 i don't know if is good. with avi splitter you hear the shutter. without play with lav splitter and has no problem. in the sample with avi splitter and all decoder filters of mpchc disabled doesn't play audio. in "bug" file freeze in 0:00 but not crash. after search the file i found that audio is actually mp2 audio file but somehow in avi appears as mp3, so i produce this sample. So the bug is in the avi file, its not a normal file. Last edited by tasi; 26th November 2012 at 18:03. |
26th November 2012, 19:56 | #20437 | Link | |
AVI Splitter (system) - bad sound VirtualDub - no sound LAV Splitter - no problem (wtf?) 1. Inside MP2 audio marked as MP3. 2. AVI does not support MP2 audio. File is broken. LAV Splitter is broken too. |
26th November 2012, 20:00 | #20438 | Link |
Playing a file properly is "broken" now?
27th November 2012, 08:36 | #20440 | Link |
Oh yes, AVI does support MP2. Technically. Easily. AVI likes audio streams with a constant frame size.
There are just so few ACM codecs or DS decoders recognizing and supporting the 2CC 0x0050 for MPEG1 Audio Layer 1 and 2 (Layer 3 has 0x0055). I remember there were commercial MP1/MP2 ACM codecs by QDesign; they have probably no use today. Sony ATRAC3 has 2CC 0x0270; its ACM codec (with rather low quality) has been traveling through the web as well... |
