26th January 2015, 21:43 | #4661 | Link |
Huge bug report:
Staxrip delete moves 4gb temp files to recylce bin which fullfills entirely soon C: . Please put force delete to your code to avoid moving to recycle bin. Also could you please add delete log files option also? Also couple features for audio tracks needed: - Remove second audio track option. At the moment it encodes automatically second audio track if source have mutliple audio tracks. Please add option to encode only single audio track to mp4 or mkv format. - Please add more audotracks possibilites. I have few video containing 6 audio tracks and would need quite many tracks to the encoder. Last edited by Jeroi; 26th January 2015 at 22:35. |
26th January 2015, 22:04 | #4662 | Link |
My drive is only 1 GB (2.5" is more silent) and I never had problems with the recycle bin, I don't know what Windows uses as default, I defined it to use 50 GB, default or customized there should be a sane upper limit and Windows shouldn't exceed it, I would like to help but don't understand where the problem is. I might add another option but it's not simple because for such specialized issues I consider to build a settings dialog similar to about:config in Firefox.
26th January 2015, 22:50 | #4663 | Link |
Feedback
Hi Stax ...
I've tested the new version with some audio formats. The result was good in this release. No matter what encoder I have chosen or what format and bit rate, the output file reflected the settings. The only problem was the conversion of some TrueHD audio tracks to AC3. For example, Dolby Atmos can only be converted with ffmpeg. If the selection of the encoder is set to automatic, then the conversion of some TrueHD audio tracks is displayed as an error, but the process goes on and is not interrupted. In TrueHD audio tracks ffmpeg should be preferred as the encoder when the setting is set to automatic. Greets Pat |
27th January 2015, 03:32 | #4664 | Link | ||
@Jeroi
I've added a setting at: Tools/Settings/System/Use recycle bin when temp files are deleted Log file will also be deleted by default (using recycle bin). Quote:
@Patman Thanks for testing, I got to look for a sample and info on Dolby Atmos then. Last edited by stax76; 27th January 2015 at 03:47. |
27th January 2015, 20:20 | #4667 | Link |
Are you sure it checks the output correctly? I am using your last version in post #4657 creating a new project and then open this project and changing some parameters to test different outputs (with x265).. and when Just mux in audio always merge the wav file but I choose the AAC output file...
27th January 2015, 20:53 | #4669 | Link |
Here is a build from today: https://www.dropbox.com/s/r1v4fp1kb2....01.27.7z?dl=0
I moved the audio and subtitle demuxing options from the project options dialog to Tools/Settings/Demuxing, it's now global and everything in one place. Audio had some bugs like when you load a audio profile the stream selection in the context menu was gone, if there are demuxed files the menu now always shows them. The audio textbox never shows a file name but always media info. The audio play feature plays now the correct stream when demuxing is disabled (default), this works only with FFVideoSource because it uses FFAudioSource for stream selection. If you use a audio encoder that handles delay (eac3to or BeSweet) StaxRip removes the delay from the output filename, when you later then open this file for muxing it won't extract the delay from the filename and pass it to the muxer like in previous versions. |
28th January 2015, 13:23 | #4670 | Link |
Little crash error using the version from your post Stax, although this same .avs file opens fine in the 1.2.0.1 beta, in 1.2.0.2 it crashes instantly when loading the .avs file
.avs file Code:
SetMTMode(5, 4) LoadPlugin("D:\dgindex\DGDecode.dll") DGDecode_mpeg2source("E:\Evanescence - My Immortal.d2v", info=3) SetMTMode(2) QTGMC( Preset="Slower", NoiseProcess=1, NoiseRestore=0.0, Denoiser="dfttest", DenoiseMC=true, NoiseTR=2, Sigma=4.0 ) SelectEven() crop(8, 58, -6, -60) #resize #denoise Code:
------------------------------------------------------------ Environment ------------------------------------------------------------ StaxRip version: 1.2.0.2 OS Name : Windows 8.1 Pro OS Version : 6.2.9200.0 OS Type : 64-bit OS Culture : English (United Kingdom) ------------------------------------------------------------ .NET ------------------------------------------------------------ v2.0.50727 : 2.0.50727.4927 v3.0 : 3.0.30729.4926 v3.5 : 3.5.30729.4926 v4\Client : 4.5.51650 v4\Full : 4.5.51650 v4.0\Client : 4.0.0.0 ------------------------------------------------------------ Source file MediaInfo ------------------------------------------------------------ E:\Evanescence - My Immortal.avs General Complete name : E:\Evanescence - My Immortal.avs File size : 436 Bytes ------------------------------------------------------------ Exception ------------------------------------------------------------ System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index at System.ThrowHelper.ThrowArgumentOutOfRangeException() at System.Collections.Generic.List`1.get_Item(Int32 index) at StaxRip.AudioProfile.SetStreamOrLanguage() in C:\Daten\Projekte\VS\VB\StaxRip\General\AudioProfile.vb:line 83 at StaxRip.MainForm.AudioTextChanged(TextBox tb, AudioProfile ap) in C:\Daten\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:line 2672 at StaxRip.MainForm.tbAudioFile0_TextChanged() in C:\Daten\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:line 2723 at StaxRip.MainForm._Lambda$__108(Object a0, EventArgs a1) in C:\Daten\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:line 0 at System.Windows.Forms.Control.OnTextChanged(EventArgs e) at System.Windows.Forms.TextBoxBase.OnTextChanged(EventArgs e) at System.Windows.Forms.Control.set_Text(String value) at System.Windows.Forms.TextBoxBase.set_Text(String value) at System.Windows.Forms.TextBox.set_Text(String value) at StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean autoMode) in C:\Daten\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:line 1758
The Internet: where men are men, women are men, and children are FBI Agents |
28th January 2015, 17:14 | #4671 | Link |
@Carpo
Thanks for posting, it happened with all sources not containing audio. @all I fixed Dolby Atmos handling which again resulted in heavy editing of the audio processing, there were bugs with TrueHD, EAC3, various issues with muxing, avs decoding uses now ffmpeg instead of VirtualDubMod. Previously StaxRip would just abort if any audio processing fails, now it tries a alternative method in most cases, it now ignores delay when DirectShowSource is used, the audio text box shows better media info now, there are so many different formats, tools, and things to handle like delay, cutting, many special cases. I feel it's getting into a good shape. https://www.dropbox.com/s/8tclme8xy6....01.28.7z?dl=0 |
28th January 2015, 22:32 | #4673 | Link |
I might add it or make a simple demuxing GUI with mkvextract, mp4box and ffmpeg support.
If you like this GUI you might want to forward to the author to use code like this: Application.EnableVisualStyles() Application.SetCompatibleTextRenderingDefault(False) SetProcessDPIAware() Application.Run(New MainForm()) Right now the app operates in a compatibility mode in High DPI environments making it look blurry. The app wasn't designed for High DPI so the window manager puts it into a compatibility mode doing bitmap based upscaling and this causes the blurry look. The cure for this is declaring the app as High DPI aware and fix the layout if it wasn't built for High DPI to start with, for such a small app it's easy, for large apps it can be work. Some other popular .NET based encoding GUI has room for improvements in this department as well... |
30th January 2015, 23:39 | #4674 | Link |
Update
Hello,
here is a link to a small update package for some apps and avisynth-plugins. Apps and Plugins Last edited by Patman; 31st January 2015 at 20:49. Reason: Link |
31st January 2015, 12:13 | #4676 | Link |
Problem with DTS-ES
Hello Stax,
I've found another audio format, which makes problems with the conversion to AC3. Eac3to and besweet produce an incorrect audio file. The audio format which causes these problems are DTS-ES (6.1) audio tracks. Only ffmpeg produced a correct audio file (AC3 5.1 448 kbit/s) without a "peep" tone. The easiest way to fix that problem is to set ffmpeg as default for DTS-ES audio. I hope you can check this and change that. Greets Pat Last edited by Patman; 31st January 2015 at 14:43. Reason: more infos |
31st January 2015, 13:11 | #4677 | Link |
I don't have a disc to test, did you use MakeMKV or another ripper?
I uploaded a release however, hopefully without too many bugs. 1.2.0.2 beta (2015-01-31)
https://www.dropbox.com/s/0i2zmsovra...2_beta.7z?dl=0 https://sourceforge.net/projects/sta...StaxRip%20beta |
31st January 2015, 16:17 | #4680 | Link |
just to point out support for aac (just mux using aac-lc (adts) in this case) in a mkv/mp4 container is fully supported yet this says other wise... encoding to aac it doesn't kick up a fuss
also why can't i see nor read the file name of the audio file any more another great option took away which means the user could end up muxing/encoding the incorrect file due to not being able to see/read it a game of blind guessing anyone ? |
gui, h.264, h.265, hevc, mkv, x264, x265 |
