24th December 2009, 19:36 | #2702 | Link | |
24th December 2009, 21:16 | #2704 | Link | |
the encoding uses the same sample rate as source file which is what i like in the new audio dialog it doesn't have such a option nor can a use pick what sample rate they want to use. 1.1.2.2 Last edited by cegy; 24th December 2009 at 21:25. Reason: added more stuff |
24th December 2009, 21:48 | #2706 | Link |
my source file is from my dvb-t using dvb dream which is saved into mpeg format with the sample rate at 48 khz anyway, am not to bother about it as its still needs a few more things adding to it to make it more user friendly before i start using it myself also i do find it kind of crap for the user where it resets your profile and settings pity there isn't something to upgrade or update it to the latest version without need to REDO it again as this does my head in.
24th December 2009, 22:05 | #2707 | Link |
@ Multitask
I'm wondering if maybe I'm just unclear on how the program works. Can you confirm that I can select a profile I created with my video and audio settings. When selected the audio track 1 says AAC 5.1 on the side. I select a folder of chapter VOBs from a DVD I ripped that has a Dolby Digital surround sound track (in addition to stereo, you select which one in the DVD menu). I then start the batch transcode for all the files. If I load an individual file and look at the settings, it still says AAC 5.1 next to it but there is no filename for the audio (just says double click). So if I don't select an audio file, and it is set to AAC 5.1. How does the program know which audio track to encode? It seems it always encodes to 2-channel stereo when I do this. There also seems to always be a .dts in addition to a .wav file even if there is no DTS track. Is there a setting I need to change? |
24th December 2009, 22:07 | #2708 | Link | |
p.s here's screenshot of the src file and the output file of what sample rate i get.. also i have uploaded both the sample of what i have used and encoded sample file. p.s how do i added blend=false ? < src file > http://www.filedropper.com/eastenderssample < encoded file > http://www.filedropper.com/eastenderssample_1 on the output file i want the mp3 settings to be something like: Codec ID/Hint : MP3 Bit rate mode : Variable Bit rate : 121 Kbps Nominal bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Writing library : LAME3.98 Encoding settings : -m j -V 4 -q 2 -lowpass 17 --abr 128 i hope this helps and thanks for the help and i am sorry if i wasn't so kind before :/ Last edited by cegy; 24th December 2009 at 22:42. Reason: added more info on the file and url to files |
25th December 2009, 00:10 | #2709 | Link | ||
setup settings you want for all files encoded without loading any files then choose file batch or directory batch for source and load up all the files you want encoded Quote:
can you create a clip of the source with DGSplit |
25th December 2009, 16:28 | #2710 | Link |
Merry Christmas everybody and thanks Betsy25 and MuLTiTaSK for supporting me.
26th December 2009, 06:19 | #2712 | Link |
Merry Christmas Everyone.
I just downloaded the latest beta version of Staxrip(I am ripping after a long time almost a year I guess). I was not able to find the 3pass setting for MP4. Before anyone takes my query and turns into a 3pass is useless discussion I want to tell you that I want to encode really low bitrate mp4 files. Around 250kps for a dvd. I have found that only in 3pass I get an almost dvd quality and a very small size. So is there any profile that I can download. Or can someone guide me on how to create a 3pass profile Thanks |
26th December 2009, 06:40 | #2713 | Link | |
x264 developer
26th December 2009, 09:07 | #2714 | Link | |
I tried two pass with the highest setting possible did not get the quality and the filesize I used to get with 3 pass. So please someone either give me the 3 pass insane profile or give me a 2 pass profile/setting that will work the same. I got around 120 mb for an hour of DVD video. Almost dvd quality. If a 2 pass can get me the same size and same quality I really dont mind going in for 2pass(it is going save me a hell a lot of time I would love that) |
26th December 2009, 18:07 | #2717 | Link |
There are a lot more setting than that.
I cannot change the bitrate??? Why is that In the older version I remember I could change the bitrate to anything. Here I Even if select the bitrate option it does not show me an options to change the bitrate. This is totally changed!!!! I remember there used to be a dvd profile where I could convert a dvd. I would then select the bitrate. |
26th December 2009, 18:25 | #2719 | Link |
Yes, that's it, you don't need to select more options, preset placebo is highest possible quality for x264. But it is very slow, so if you want more speed you can also try presets "veryslow" and "slower".
26th December 2009, 18:58 | #2720 | Link |
Thanks I checked that again I got it.
I would always cancel the setting window after i could not find the bitrate option in that. That is why in the main window I was not getting the option. I think Now I can get something ripped Thanks multitask and firebird. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
