22nd December 2009, 01:47 | #2682 | Link |
Batch Processing and Temp Files
I've ripped my music video DVDs to separate chapter files. I want to use Staxrip to encode them to files of the same name in a certain target directory. When you batch process a bunch of files separately, how do you specific the target directory? Do you have to key the path/filename for each file manually?
22nd December 2009, 14:01 | #2684 | Link |
Hello! I want to encode some 720P50 H264-transport streams to MKV with 25fps. I use the command "SelectEven()" to convert 50fps to 25fps.
Question: StaxRip uses Directshowsource/Haali to open the transport stream. Which decoder is the best and fastest for the H264-decoding? DIVX H264-decoder, ffdshow, MPCVideoDecoder or CoreAVC? |
22nd December 2009, 17:48 | #2687 | Link |
An error occurred again in the conversion of multiple files. The message that these errors were placed below, did not appear crashlog of StaxRip, just know that the error was the beginning of the conversion of the 4th file, now the pictures:
In both images is saying, only the various object error, the first is the Staxrip.exe the second is the drwtsn32.exe "The StaxRip.exe/drwtsn32.exe encountered a problem and needs to close" Last edited by Havokdan; 22nd December 2009 at 17:53. |
23rd December 2009, 04:20 | #2689 | Link |
Transcode DTS?
I'm trying to transcode Queen Live at Wembley Stadium. I'm getting no audio. When I'm playing the mp4 that Staxrip generated it is showing the audio track as being encoded in DTS. Not sure what's going on. Is there a setting I need to change in Staxrip? The Audio is set to AAC 5.1 in Staxrip. There's no idea on my PC or my PS3. Shouldn't Staxrip transcode the DTS track to 5.1 AAC?
Thanks |
23rd December 2009, 06:46 | #2690 | Link | |
23rd December 2009, 14:51 | #2691 | Link |
@consultant
can you post a clip of the file you trying to encode so i can try to see if StaxRip is having trouble converting it sounds like just mux is set for audio you could use DGSplit to create a small clip you can upload it here @Havokdan dont pay attention to what others say so much if a forum mod said you breaking rules then thats different now if you would still like to get StaxRip working give us some more info on the files you trying to convert so we can try to help you |
23rd December 2009, 16:09 | #2692 | Link |
Nero AAC Codec 1.5.1.0 released
2009-12-17 - Version 1.5.1.0 - neroAacEnc: - Improved encoding of sample rates higher than 48kHz - Solved compatibility issues with some hardware devices - Write iTunes compatible gapless data - Enabled preserving of very quiet high frequencies at high bitrates - Write the encoder settings to metadata - Executable size reduction - neroAacDec: - Improved error handling - Speed up - neroAacTag: - Support 3GPP tags - Support Sony Memory Stick tags - Improved cover art support - Improved support for files with multiple tags in different formats (ND,iTunes,3GPP,Sony Memory Stick) - Writes iTunes tags by default, added switch to enable ND tags Last edited by MuLTiTaSK; 23rd December 2009 at 16:40. |
23rd December 2009, 18:35 | #2693 | Link |
I'll see about sending a clip on that Queen video.
But for now, I'm at wits end wondering why I'm not getting 5.1. My profile setup, the audio setting is AAC 5.1 200-250. I encoded a video that has both PCM stereo and Dolby Digital 5.1 tracks. If stick the DVD in my PS3 and select the 5.1 track, I get 5.1 indicator on my receiver. If I transcode it with Staxrip and play the MP4, it indicates Stereo PCM on both the PS3 and the receiver. If I look in the rip folder for the chapter their are two audio files, a .dts file and a .wav file. I didn't think .wav can do .dts. In Staxrip the Audio Track 1 filename is just blank (says double click) - to set this for each chapter would be a pain. I was assuming (without much documentation) that if I set the format to AAC 5.1, Staxrip would automatically transcode the Dolby Digital 5.1 track into AAC 5.1? I'm surprised at the lack of responses. Am I asking very basic stupid questions or does no one know the answers? I've already done about 50 hours of encoding and I think everything is stereo, so I'm afraid I'm going to have to go back and transcode everything over again - if I can figure out how to get 5.1 audio???? |
24th December 2009, 04:58 | #2695 | Link |
The Lazy One
Location: The TurokZone. Next Door are the heavens, hells, and on the backside the void
CoreAVC 2.0 has released and it fixed the bugs previously reported in 1.9.5 my question is will StaxRip support it now? Am I able to select it as decoder and whatnot? Also am I able to encode audio ONLY? I mean like the source being without Video and or if not source the Audio Dialog?
24th December 2009, 05:19 | #2696 | Link |
@turok
StaxRip will work with any decoder installed on your box choose DirectShow as source in filter setup with lastest preview you can choose to encode only audio using method i posted above |
24th December 2009, 08:51 | #2697 | Link |
The Lazy One
@ MuLTiTaSK
Just audio encoded with the new preview lol. I like what I am getting and it supports Dolby Digital (AC3) as well... Although the Audio profiles need tweaking, it looks good and the Interface is perfect. Thanks Stax76. thx MuLTiTaSK for helping me keep up to date with StaxRip's already great Capabilities. Wierd though after my first audio encode tried a 2nd one the encoding just stops :S. No error box or anything it doesn't even start :S. this question is directed at Stax76. Where did you get them profiles for the x264 section? To be specific the animation profiles? Just wondering as Since I do my own profiles I usually don't profiles already set. Well anywho after review it was best that I continue using my own lol. Where did u get them profiles from?
Decided this quote only lol. "Always try to understand the perspective of not only yourself but others as well" Am a fanboy of StaxRip |
24th December 2009, 11:20 | #2698 | Link |
Just made a 25€ Christmas donation, hope other StaxRip users have a little Xmas present for Stax's fantastic work too.
Merry Christmas Stax, and everyone elso too ! Last edited by Betsy25; 24th December 2009 at 11:22. |
24th December 2009, 18:29 | #2699 | Link |
@stax76
i wish you and everyone a merry christmas and a happy new year may we all see many more i thank you very very much for all your efforts on StaxRip it sure is second to none I cant say it enough EVERYONE please show stax76 your support sending a donation is the least we could do to show him we appreciate all he has done for us PAYPAL SourceForge HAPPY HOLIDAYS |
24th December 2009, 19:08 | #2700 | Link |
its a pity when u pick mp3 and you want vbr or abr its has to be 160kb/s more to be 48khz as for me i like a 128 abr/vbr with 48 khz, plus there is no option for this in the new audio editor as i am sure other people would like to pick what sample rate they when.
the settings i use in 1.1.2.2 is "%application:BeSweet%" -core( -input "%input%" -output "%output%" ) -ota( -hybridgain ) -azid( -c normal ) -lame( -h --abr 128 ) and bitrate set at 130 kbps and this is the setting i like to use with 48 khz same as the src file is Last edited by cegy; 24th December 2009 at 19:12. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
