3rd May 2018, 13:32 | #22781 | Link |
MPC-BE - go Options -> Playback and uncheck "Default track preference".
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
3rd May 2018, 13:42 | #22782 | Link | |
https://s17.postimg.cc/eto7rx6i7/mpc.jpg
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM Last edited by steakhutzeee; 3rd May 2018 at 13:47. |
3rd May 2018, 16:09 | #22783 | Link |
Furthermore, there are containers where you can flag streams to be the default among several (or even force their use, e.g. for subtitles); MKV supports such flags, here you would have to edit their header.
3rd May 2018, 16:14 | #22784 | Link | |
What you can do is create a virtual AVI using the PISMO plugin (both AVS and Vapoursynth). This virtual file can be opened by anything using a AVI VFW from the system. It will not use LAV. Last edited by Pat357; 3rd May 2018 at 16:21. |
3rd May 2018, 18:10 | #22785 | Link | |
Thanks. So i can't use lav splitter "in automatic" with mpc be?
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM |
4th May 2018, 03:48 | #22786 | Link |
hey, mind testing this video sample... because it's seek weirdly in my player...
i use LAVf 0-71-34... for player, i use MPC-BE... at first i thought it was player bug, but when i try it with potplayer, it's still seek weirdly... when i uninstall LAVf splitter from 0-71-34 and reinstall LAVf splitter from 0-71, it's seek smoothly... and when i change the container to mkv, it's seek smoothly too... but when in mp4 container, it's seek weirdly... may i ask why ? is this bug ? note : # video sample i provide is : 720p h264 in mp4 container, i get it from some fansubs forum... this is the sample : https://drive.google.com/open?id=18e...NEe9SR84SGz6Ft |
4th May 2018, 09:59 | #22787 | Link |
What does "weirdly" mean? Are you using LAV Video as well? If so, what decoder (software, D3D11, DXVA etc.)? Can you pinpoint the exact nightly version it was introduced? (I don't see anything weird with 0.71.0.34 and MPC-HC nor MPC-BE.)
4th May 2018, 11:10 | #22794 | Link |
I'm using 1.5.2 build 3445 beta.
And lav filters 0.71 stable. I checked yesterday for updates but I think it search on sourceforge.net where the latest version is the one I use :/
4th May 2018, 11:16 | #22795 | Link |
I got mine from https://www.videohelp.com/software/MPC-BE . Not saying that is the cause, just checking to make sure you aren't using some 3 year old build but yours is pretty recent ..
4th May 2018, 13:25 | #22796 | Link | |
This is very strange, what could be the cause? I don't understand, i disabled la splitter source and lav splitter but when i load a file lav splitter is loaded... EDIT: ^This because i think lav starts automatically with mpc be. Now in fact i unistalled lav and reinstalled the latest nightly build, and without adding lav to external filters in mpc be, they starts automagically. Is this behavior normal? So with the clean installation of lav i tried to select No Subtitles in Lav Filters but still subtitles are loaded. So i don't know...
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM Last edited by steakhutzeee; 4th May 2018 at 14:09. |
4th May 2018, 23:39 | #22797 | Link |
got an odd problem with LAV audio.
I cant bit stream for some DTS movies if I use LAV as external filters, doesnt seem to be any reason for this, ive tried several versions all the the same issue, some DTS movies play fine which is odd. To give an example. If I install MPC-HC with stock settings and set it to bit stream using internal filters 0.71.25 everything plays ok if I then use LAV filters externally, regardless of version I lose sound on some movies, just cant work whats going on. Same happens in MPC-BE and KODI DS so its defo something with my PC or LAV filters. I've dropped back a few AMD RX driver versions and this made no difference either, no idea whats going on, anyone any ideas?, here is the media info of one of the movies that wont play. Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 2 h 14 min Bit rate mode : Constant Bit rate : 1 509 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossy Stream size : 1.42 GiB (13%) Language : English Default : Yes Forced : No I've also tried currently nightly. EDIT - I should also say that I can play these movies fine with VLC /bitstream so its just LAV filters. here is demo, I cant play this either - https://we.tl/rbkIeKMHj6 Last edited by mclingo; 5th May 2018 at 00:07. |
5th May 2018, 00:01 | #22798 | Link | |
I have installed lav and noted that without adding it to external filters, it runs on its own when I play something. How possible?
5th May 2018, 00:55 | #22799 | Link |
i suspect this wasnt LAV at all as I found several other issues also came back, I was getting HDMI loss coming in and out of 3D mode and blown out reds again with MADVR on 23p material. All issues now fixed with system restore.
suspect my GFX driver install got corrupted or something, I had a few pc crashes in the week caused by a faulty power adapter, I'm betting that caused it, I hadnt watched anything for a few days so I only spotted it today. |
5th May 2018, 18:25 | #22800 | Link |
@nevcairiel - i've found an issue i'd like your advice on. As stated I lost DTS bitstream playback on half my DTS collection, on further inspection it was all non DTS HD stuff which made me think of LAV filters again. I can reproduce this problem by ticking use DTS HD framing for all DTS types, i'm sure I usually have this ticked.
Should this be ticked, is this a bug, i've tried several LAV versions and all have the same issue, I also tried a few AMD drivers, of course this could be something wrong with my receiver or PC maybe. What do you think? |
