Old 3rd February 2016, 20:00   #1341  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by GMJCZP View Post
A person called Case (foobar2000 forum) has continued to develop fhg aac:
Here and Here
I tried to LameXP but not working, why it is not compatible?
Edit: these are two files.
I have identified at leas three problems:
  1. LameXP checks the version string, using the "-help" option. This is working fine with the old "tmkk" version, but the new "Case" version just errors out. No version string is printed!
  2. LameXP checks that all required DLL's are present. The old "tmkk" version required libsndfile-1.dll, but the new "Case" version does not. It still needs the other ones though (enc_fhgaac.dll, nsutil.dll and libmp4v2.dll).
  3. LameXP requires at least version "20120806" of fhgaacenc, but the version from Foobar Encoder Pack reports "20120624" and additionally "20151024". LameXP only looks at the first one, which is too old.
Fix is underway...
Old 3rd February 2016, 21:09   #1342  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.14 Alpha 3
Changes between v4.13 and v4.14 [unreleased]:
* Fixed the location of temporary intermediate files for SoX-based audio effects
* Enabled the "built-in" resampler for QAAC encoder
* The "Algorithm Quality" slider now also effects the QAAC encoder
* Updated MediaInfo to v0.7.82 (2016-01-27), compiled with ICL 15.0 and MSVC 12.0
* Updated QAAC add-in to the to QAAC v2.58 (2016-01-05)
* Updated FhgAacEnc add-in to "Case" edition (2015-10-24)
* Updated ALAC decoder to refalac v1.58 (2016-01-05)
Be sure to grab latest FhgAacEnc add-in here:
http://sourceforge.net/projects/lame...3.zip/download
Old 3rd February 2016, 22:31   #1343  |  Link
GMJCZP
GMJCZP's Avatar
Thank you! When you can prove it.
Edit: I only see the file fhgaacenc.exe, the other file of Case is not necessary?
By law and justice!
Flea Market
GMJCZP is offline   Reply With Quote
Old 3rd February 2016, 22:55   #1344  |  Link
LoRd_MuldeR
Software Developer
You copy the required DLL's from the Winamp installation directory (or extract them from the Winamp installer via 7-Zip), as described in the included INSTRUCTIONS.txt file
Installing the Visual C++ 2008 Redistributable Package (x86) may be required too...
Old 4th February 2016, 03:36   #1345  |  Link
GMJCZP
GMJCZP's Avatar
One more thing: Avast is detecting a threat your last builds (include simple x264), LoRd_MuldeR.
By law and justice!
Flea Market
Old 4th February 2016, 14:22   #1346  |  Link
mariush
Go to http://www.virustotal.com and upload the application or the executable there. If it's just one or a few antiviruses (out of 20+) complaining there's a high chance there's no actual virus.
mariush is offline   Reply With Quote
Old 4th February 2016, 20:59   #1347  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.14 Alpha 4
http://sourceforge.net/projects/lame...6.exe/download
Old 4th February 2016, 21:00   #1348  |  Link
LoRd_MuldeR
Software Developer
Same old story
http://lamexp.sourceforge.net/doc/Ma...ti-virus-notes
BTW: Fixed yet another FhgAacEnc issue...
Old 20th February 2016, 16:42   #1349  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.14 Alpha 5
http://sourceforge.net/projects/lame...0.exe/download
* Added "AVX" (Advanced Vector Extensions) to CPU feature detection code
* Updated Opus encoder/decoder libraries to v1.1.2 and Opus-Tools to v0.1.9 (2016-01-12)
Old 20th February 2016, 16:59   #1350  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Thanks for continual support.
Win10 (x64) build 17134 | GPU Caps Viewer 1.40.1.0
NVIDIA GeForce GT 1030 (GP108) 2047MB/GDDR5 | (R417.22)
NTSC | DVD: R1 | BD: A
Old 21st February 2016, 15:19   #1351  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.14 Alpha 6
* Updated LAME encoder to v3.100 Alpha-2 (2016-01-29), compiled with ICL 15.0 and MSVC 12.0
Old 24th February 2016, 14:34   #1352  |  Link
real.finder
hi LoRd_MuldeR
I would suggest adding an option to choose between AAC encoders, and the auto choice act like the how lamexp do now except in low bit-rate/Quality or if the HE-AAC v2 is selected lamexp will prefer nero because it better than others in that
QAAC never encode in HE-AAC automatically, and support HE-AAC v1 only (did't support HE-AAC v2)
edit1: in tvbr mode in QAAC I can't encode in HE-AAC, and after I test more I see that QAAC in very low bit-rate (8 kbps) will encode HE-AAC v2 if I choose HE-AAC v1 or HE-AAC v2 ! and in the low (64 kbps) will encode in HE-AAC v1 if I choose HE-AAC v1 or HE-AAC v2 !
edit2: with 48000 Hz even in 8 kbps QAAC will encode HE-AAC v1 if either HE-AAC v1 or HE-AAC v2 chosen
edit3: 8 kbps in QAAC made the output in 32 kbps in 44100 Hz stereo, and in another test I see that in 40 kbps QAAC will encode HE-AAC v1 and in 32 kbps will encode HE-AAC v2 if either HE-AAC v1 or HE-AAC v2 chosen, if I didn't choose HE-AAC v1 nor HE-AAC v2 QAAC will encode in LC
My Avisynth Stuff
Old 1st April 2016, 21:39   #1353  |  Link
von Suppé
Hi LoRd_MuldeR,
First, awesome program, thank you.
I found out that when I convert flac files into mp3, the <track> and <Album Artist> tag info from the flac files are not properly copied to the mp3 tags.
The <track> tag automatically gets 1, 2 3, etc. The <Album Artist> tag stays empty.
I checked the Meta Data and Advanced Options tabs but can't find anything about those.
Cheers
von Suppé
Old 1st April 2016, 22:26   #1354  |  Link
LoRd_MuldeR
Software Developer
As explained various times before, this is not a simple matter of "copying" the meta tags
It requires to detect the meta tags from the original input file, store them in an internal data structure, and finally re-embed them into the re-encoded file.
And all this needs to work with 17 different decoders and 11 different encoders (187 combinations), which all store different tags in different ways.
Therefore, the internal "meta data" model was designed as the "the lowest common denominator" of what the various different audio formats (encoder/decoders) support.
At this time, the "Album Artist" is not maintained as a separate field in the internal "meta data" model, sorry!
About the "track number" issue: I think you probably have "Position" set to "Generate from list position" on the "Meta Data" tab. If so, then the result is as expected.
Old 2nd April 2016, 11:56   #1355  |  Link
von Suppé
Thanks for the explanation, it be so.
Indeed it was. Doh, I feel stupid. Simply didn't know that "Position" meant track #. Changed it to "Unspecified (copy from source file)" and it works like a charm now :-)
Thank you
von Suppé
Old 7th April 2016, 20:38   #1356  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.14 Alpha 8
https://sourceforge.net/projects/lam...8.exe/download
* Upgraded build environment to Microsoft Visual Studio 2015 with Update-2
Old 16th April 2016, 09:29   #1357  |  Link
Yonah
Problem with Ogg Vorbis tags
I'm having an issue with Vorbis Comment tags on Ogg files encoded with LameXP. My source files are FLAC files and have all been properly tagged. However, after encoding with LameXP, all the tags are duplicated with 2 backslashes (\\) except for the year.
For example, if the artist tag in the FLAC file is "Disturbed", the encoded Ogg file is tagged as "Disturbed\\Disturbed." The comment contains "Encoded with LameXP\\", followed by the original comment from the source FLAC file.
This bug does not occur if the Normalization Filter is enabled.
Yonah is offline   Reply With Quote
Old 16th April 2016, 10:53   #1358  |  Link
LoRd_MuldeR
Software Developer
Hello, Yonah.
If the selected encoder is capable of reading the input file format directly (and if no filters are enabled!), then LameXP takes a "shortcut" and just invokes the encoder directly on the input file – instead of going the usual "decoder → filters → encoder" route with intermediate WAV files. Now my guess is that, when OggEnc2 (i.e. the Ogg/Vorbis encoder) is reading your input FLAC file directly, then it keeps the meta tags found in the original FLAC and also appends the tags specified explicitly by LameXP – rather than "replacing" redundant tags. Not sure whether this is a bug or a feature. Enabling the "normalization" filter probably fixes this, because the "shortcut" can no longer be used when filters are enabled
[EDIT]
Okay, I think it's a feature and we need to use the --discard-comments command-line switch of OggEnc2 to get the desired result. A new version is underway...
Old 16th April 2016, 11:47   #1359  |  Link
Yonah
Thanks, Lord_Mulder! The command-line switch is just what I needed. Before I moved overseas I ripped my entire CD collection to FLAC. Since I use Vorbis exclusively on my phone this tag issue was problematic for me. No more manual tag editing after I encode an album.
Old 16th April 2016, 12:55   #1360  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.14 Alpha 9
https://sourceforge.net/projects/lam...0.exe/download
* Fixed embedding of meta tags with OggEnc2 when reading directly from OGG/FLAC input file
* The "Algorithm Quality" slider now also affects the QAAC encoder
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis
