25th April 2018, 23:08 | #50381 | Link | |
The problem with Kodi has to do, unfortunately, with too few Windows developers on board. Being open source, I hoped for quite a long while that somebody would fork it to something Windows only and be done with it. While I applaud the spirit behind some of Kodi's team decisions, for the longest time the Windows release has been reduced to something of an afterthought in many occasions. The software is free, so they are free to do whatever they want and, certainly, lack of developers is hurting the Windows release. After the whole DSPlayer debacle with aracnoz (the developer, I know you are familiar with him) being attacked for asking simple questions, I kind of lost faith in the whole thing. It's too bad that nobody is picking up the torch, really (save from aracnoz kindly providing updated builds from time to time). |
26th April 2018, 03:57 | #50382 | Link | |
Kodi DSPlayer doesn't really need a developer at the moment. It just needs someone to merge the Git to the latest Kodi master. I'll definitely try it myself if aracnoz doesn't provide an update this time. I just don't think I can move the player code around and still keep the player working. It depends on how many code conflicts there are in the already 6,000 new commits in Kodi master. It's more than just a simple merge. DSPlayer is already a mature player with all the features it needs with new features being added all the time by LAV Filters and madVR. You are one of the users that has been there from the beginning.
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 26th April 2018 at 04:36. |
26th April 2018, 04:02 | #50383 | Link | |
Seems like a poor decision from a company that used to be associated with the best image quality in its heyday, taking over the throne from Sony. But, like you said, maybe no one will notice.
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 26th April 2018 at 04:22. |
26th April 2018, 04:09 | #50384 | Link | |
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 26th April 2018 at 04:14. |
26th April 2018, 05:59 | #50386 | Link |
There is no knowing if anyone has reported these issues to Nvidia. Although, they seem to be so incompetent at not bug testing anything that I wonder if these issues have been reported several driver versions ago and not fixed due to neglect.
26th April 2018, 06:00 | #50387 | Link |
I think so, too. But choices like that make me wonder if they are trying to cut costs to improve margins. If so, I'm not impressed.
26th April 2018, 06:23 | #50388 | Link | |
It would be nice if this control accepted down to 50 Nits. edit: The other issue I notice is that SD resolution deinterlaced 25i > 50p content is being displayed at 1080p60, where as HD resolution deinterlaced 25i > 50p is displaying at 1080p75. Any idea why madvr uses is selecting the 1080p60 display mode for SD?
http://www.7-zip.org/ Last edited by Audionut; 26th April 2018 at 06:28. |
26th April 2018, 06:29 | #50389 | Link | |
Did it before? Last edited by ryrynz; 26th April 2018 at 06:31. |
26th April 2018, 06:57 | #50390 | Link |
I'm reasonably positive it did not (with 0.92.12).
http://www.7-zip.org/ |
26th April 2018, 07:54 | #50392 | Link | |
In this build diffuse white is set to 100nits. I guess you can't set target nits below diffuse white, which makes sense.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
26th April 2018, 08:46 | #50394 | Link |
Hi Madshi,
want to Report 2 (maybe)"Bugs". I am using Dvbviewer + Madvr + LAV.(all latest, LAV nightly) Win10 AMD RX560 latest Driver (Friend has same Problems with RX580) I am using the Madvr switching Option. Profiles are: 1080p23, 1080p24, 1080p50, 2160p23, 2160p50, 2160p60 I let Madvr scale to 1080, only 4K i let switch to native. First Problem: On LiveTv 1080i50 -> 1080p50 (OSD reports Source 1080 50fps) good . On records from LiveTv (1080) (OSD says Source 25fps) -> 2160p50 but it should be 1080p50. Second Problem: switching to 4K/60Hz On Hotbird is a 4K Demo Channel 60fps 30Mbit+... When i switch from 1080x to 2160p60 its working. When i switch from 2160p50 to 2160p60 its not working, stays on 50Hz(source info 60fps). Then i have seen another thing, maybe it helps you. I dont use FSE, because way longer switching Times and Problems with Ambilight(Ambibox does not work all the Time with FSE). When watching HDR Content, it works most of the Time.(enabling HDR) When its not work (switching to HDR) the following does the Trick(else only reboot helps). When playing content with HDR and switch to HDR was not working, i switch Player from Fullscreen to Window mode. Then i can see in Window mode its HDR.(enable Fullscreen its goes normal..) now open AMD Panel switch from RGB to YUV and back. # Now Window player is non HDR -> make Fullscreen Player -> HDR working wbr Alex |
26th April 2018, 09:10 | #50395 | Link |
I went from the latest version of the NVIDIA drivers to 385.28, after reading this your post, but as in the previous one I continue to have "1 frame repeated every 5 minutes" and I can not in any way go beyond 5 minutes, even changing the settings in LAV VIDEO or Madvr, any suggestions? I have a GTX1080, first an AMD RX480 and I did not have these problems.
