Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD Rebuilder
Old 1st June 2018, 17:00   #27381  |  Link
jdobbs
Originally Posted by musiclover View Post
content of the AVS file when trying to do the conversion with "Assume PAL for DVD output" set
#Created by BD Master Toolkit - v0.50.25
DirectshowSource("G:\WORK\IMPORTS\BBC_BIGGEST_WEEKEND\BDMV\STREAM\00000.m2ts", fps=50, framecount=134854, audio=false)
BilinearResize(720,576)
ConvertToYV12().ConvertFPS(25000,1000)
content of the AVS file when trying to do the conversion with "Assume PAL for DVD output" NOT set
BilinearResize(720,480)
ConvertToYV12().AssumeFPS(50000,1000)
This makes no sense to me based on the code I looked at yesterday. The fist one is what I would expect to see with that setting... and I have no idea why it would generate an error. The second one should be impossible when your output is set to DVD.
I guess I'll have to grab me a 720p/50fps source and trace it to see how it can happen.
Website: www.jdobbs.net
Old 1st June 2018, 18:45   #27382  |  Link
MrVideo
MrVideo's Avatar
Well, 1280x720 16:9 progressive 50 fps is a legal BD format
Not for the image sizes under discussion.
My Total Eclipse 2017 Photos
Old 1st June 2018, 22:14   #27383  |  Link
jdobbs
@musiclover
Well at least I know why you are getting the error with "Assume PAL for DVD output" set. BD-RB was improperly using ConvertFPS(). In that instance is should have been using ChangeFPS() so frames would be dropped.
Old 2nd June 2018, 10:06   #27384  |  Link
musiclover
@musiclover
And shouldn't the same go for when "Assume PAL for DVD output" is NOT set?
musiclover is offline   Reply With Quote
Old 2nd June 2018, 13:57   #27385  |  Link
jdobbs
That is a different problem -- especially why it keeps it at 50fps. I just haven't looked at that yet.
Old 2nd June 2018, 22:04   #27386  |  Link
musiclover
There is no hurry. Thanks for the quick respons.
Old 3rd June 2018, 05:53   #27387  |  Link
Blurayhd
Dear Jdobbs please dont get me wrong with this I need to ask you and my English is not perfect but as you know Im doing my best. The other day I need to make a backup copy of one of my Bd50 Bluray movies so, BD rebuilder show me an error and I have to use a third program (I writing that correct?) DVDfab with GPU encode movie and that program do the job in almost 40 minutes and the image on my tv 55 was amazing, so because that I so wish to ask you if BD rebuilder could have the GPU encode option IŽll get the same best quality that if I encode with x264? Please Jdobbs if Im breaking any rules please let me know and forget this post I really appreciate Bd rebuilder, I use it and I really hope the next release. I so wish if you can answer me that
Please have a nice day!!
Blurayhd is offline   Reply With Quote
Old 3rd June 2018, 14:30   #27388  |  Link
jdobbs
I'll tell you... you are not getting the same quality from anywhere else that you can get from X264. Also, the generic term "GPU" could mean multiple things as there are more than one kind of GPU.
Now, if I understand correctly, you are asking me to change my Mercedes so it performs more like a Fiat because you tried the Fiat and it was good enough for you. Does that sum it up?
Old 3rd June 2018, 19:51   #27389  |  Link
Lathe
Lathe's Avatar
Lathe is offline   Reply With Quote
Old 4th June 2018, 01:46   #27390  |  Link
MrVideo
MrVideo's Avatar
I had to re-run a build because I needed to change the background menu image. But, for some reason it now fails:
BD Master Toolkit experienced an error 4000 (17:16:53)
Create Quick Menu() 00076 4000
During: Building menu structure [1]
Current progress 98.90%
I tried it twice. The reason for that is because I also keep getting Permission errors, which go away with a 2nd run. It would be nice to know why I keep getting permission errors.
UPDATE: BDRB is constantly getting BD Master Toolkit errors.
FOUND THE BUG:
MENU_ITEMS_PAGE=6
Kinda works. If there are 17 videos, only two menus are created, when there should have been 3 (6, 6, 5)
MENU_ITEMS_PAGE=4,3,2
Fails with the BD Master Toolkit error. There are 9 videos in the case, If I set it for 5/page, then it works.
I'm pretty sure that I've done a comma separated list before, but it was on the XP-64 box. This is on the Win7-64 box.
BUG UPDATE:
I wanted to look at the menus for the run that only created 2 with 17 items. But, the overall size was too large for the media, so I re-ran it with one less video (16 total) and it created 3 menus.
I've been testing all morning and it is hit-n-miss. Sometimes the comma separated page list works and sometimes it doesn't. I've not found a pattern. Need more info in the log as to why it is failing. I'm hoping that it isn't my W7 that is the issue.
It just might be. I copied all of the files for one of the discs to the XP-64 box and it ran to completion.
Old 4th June 2018, 15:14   #27391  |  Link
Mark_Venture
I have to agree, I'm very happy with your "Mercedes" as it is.. don't change it!
I've tried other apps to back up my blurays... but I keep using BD-Rebuilder... the others use "GPU acceleration" like Cuda or QuickSync, etc.. so while they are much faster (especially if I've already ripped the bluray to my hard drive)... their resulting video quality isn't as good.
For example, one other tool I can convert a 2D Movie Only MKV in 15 minutes or less from hard drive, where as BD-RB it takes about an hour. No matter what settings I use, while it make take a little longer, the MKV produced by BD-RB always looks better, so the wait is worth it!
If you ever feel the desire to add "GPU", please make it an option, so we can select/deselect it...
Mark_Venture is offline   Reply With Quote
Old 4th June 2018, 15:48   #27392  |  Link
Sharc
@musiclover
Would it perhaps make sense to make an interlaced DVD out of the 1280x720 50fps progressive source, instead of dropping every 2nd frame?
Old 4th June 2018, 17:32   #27393  |  Link
jdobbs
You'd essentially be doing the same thing -- as you'd have to drop every even or odd line of alternating frames during encoding if you made it interlaced. Personally I'd rather have a 25fps progressive souce than an interlaced one.
Old 4th June 2018, 20:28   #27394  |  Link
Sharc
Yes, but I was thinking of preserving the temporal resolution for high motion scenes. The bobbing deinterlacers of TVs are pretty good these days.
A matter of the source and personal preference, probably.
Old 5th June 2018, 00:10   #27395  |  Link
MrVideo
MrVideo's Avatar
But, you will lose the temporal resolution when the two fields are joined into one. You have to display the interlaced video as interlaced in order to keep it. But, no TV does interlaced these days.
Old 5th June 2018, 02:07   #27396  |  Link
Blurayhd
Jdobbs you are amazing buddy I so appreciate your sense of humor, you make me laugh and I never change your Bd rebuilder, like I said I had to use that other program with GPU mode because and error and because that my question.
Bd rebuilder is the only think that I really trust on quality terms and if you can tell when you spect to relese next release?
PS: could you add the option to extract the audio/subtitle files so I dont need other program else? I mean, I so wish to use Bd rebuilder for all
Old 5th June 2018, 05:02   #27397  |  Link
Jake802
Originally Posted by varekai View Post
I will! Thanks!
Jake802 is offline   Reply With Quote
Old 5th June 2018, 06:45   #27398  |  Link
Sharc
The monitors are progressive, yes, but the TV or player will deinterlace (bob-deinterlace) interlaced content (broadcasted or from DVD or BD) without just throwing one field away and loosing the temporal resolution. How it is exactly done depends on the (smart) playback device.
Many TV station broadcast HD at 1080i, means interlaced, and the TV takes care of smart deinterlacing and playing it back at double rate (or even higher) without disregarding the temporal information which is available in the source.
So if the temporal resolution is available in a source, one might be interested in preserving it (at the cost of spatial resolution in motion scenes), which would eventually mean encoding as interlaced in the case of DVD.
Just a thought, not a request for BD-RB, as there are pros and cons.
Old 6th June 2018, 00:34   #27399  |  Link
MrVideo
MrVideo's Avatar
I didn't say it would throw a field away. The two fields are combined into a single frame, reducing the temporal info in half.
Not many, but all broadcast TV, in the states anyway, is 720p or 1080i. No 1080p. It depends on the TV. those that do not do 60, 120, or more, will do as I mentioned, and combine the two fields into a single frame.
Old 6th June 2018, 06:38   #27400  |  Link
MrVideo
MrVideo's Avatar
I've run into an issue of text vertical placement. I only have two lines that I want to place starting at 950, but BDRB refuses to place the text there. Instead it is placed around 200. Is there a lower limit?
