Old 26th January 2018, 19:56   #21  |  Link
pikaczu
Posts: n/a
Oh, let's be a programmer
Old 27th January 2018, 10:26   #22  |  Link
feelingblue
tks clsid for your work.
A little question, there is a way to store Lavfilters settings into a file INI inside the same foder of the standalone version?
Sorry for my english
feelingblue is offline   Reply With Quote
Old 27th January 2018, 11:13   #23  |  Link
MokrySedeS
I am the one who knocks
MokrySedeS's Avatar
If you can provide a proper patch.
I was hoping that kasper93 would still have this patch. I've asked him about it but he's ignoring me for some reason Can you (or anyone else) reach him?
MokrySedeS is offline   Reply With Quote
Old 27th January 2018, 18:04   #24  |  Link
polarhei
Good start.
polarhei is offline   Reply With Quote
Old 29th January 2018, 18:04   #25  |  Link
clsid
No. Those settings are stored in the Windows Registry.
HKEY_CURRENT_USER\Software\MPC-HC\MPC-HC\Internal Filters
No.
Old 30th January 2018, 00:55   #26  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
I have tried several times but without the luck unfortunately.
MPC-HC Links: official nightlies | Trac | GitHub | git log | IRC | Twitter | Facebook
vBm is offline   Reply With Quote
Old 31st January 2018, 13:53   #27  |  Link
PCU
is it possible to make a deblocker shader (deblock.hlsl)?
how do i force mpc-hc to use lav filter wma decoder?
PCU is offline   Reply With Quote
Old 31st January 2018, 20:55   #28  |  Link
clsid
Block "WMAudio Decoder DMO" in external filters.
Old 31st January 2018, 23:31   #29  |  Link
Plutotype
Thanks for this activity
System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver
Plutotype is offline   Reply With Quote
Old 1st February 2018, 04:41   #30  |  Link
mrmarioman
mrmarioman's Avatar
Time to try this.Thanks a lot.
mrmarioman is offline   Reply With Quote
Old 1st February 2018, 13:45   #31  |  Link
Schwartz
Thanks for the new build first of all.
However I'm having issues watching VODs that are passed through to MPC-HC. Occasionally the playback will get very choppy in an area where - if you freshly open the VOD and skip to the same time - playback will be smooth. This is most easily reproduced if you pause the VOD and return to it at a later time. Could be a LAV Filter issue. Stable MPC-HC with the older LAV Filters works okay. Might try 1.7.14 with stable LAV Filters to double check.
Edit: This is an issue with LAV Filters which has been resolved with version 0.71.0.34-git.
Schwartz is offline   Reply With Quote
Old 1st February 2018, 15:09   #32  |  Link
PCU
thanks, tried lav filters wmv wma decoder but with microsoft asf splitter (lav asf splitter is unstable) & every windows media works fine.
also, it's so weird that all devs of mpc-hc suddenly decide to stop working on mpc-hc.
Old 2nd February 2018, 14:53   #33  |  Link
dipje
not really suddenly.. the project has been going slow for quite some time and there have been multiple calls for coders who want to help out, but no one really stepped up.. clsid is doing what he can to maintain the source , but judging from the amount of people who ask 'can you fix...' or 'can you add feature ...' they don't really seem to get what 'no development' means
dipje is offline   Reply With Quote
Old 2nd February 2018, 17:00   #34  |  Link
PCU
clsid
i really latest update of mpc-hc: looks stable.
Old 4th February 2018, 22:32   #35  |  Link
runner
I tried to play ISO BDUHD, but it does not work. the main film is not correctly identified
runner is offline   Reply With Quote
Old 5th February 2018, 17:09   #36  |  Link
clsid
LAV Splitter selects the longest title by default in case of BD(UHD). You should be able to select the other titles through the navigate menu.
Old 7th February 2018, 09:57   #37  |  Link
nevcairiel
I fixed UHD BD title selection in MPC-HC code, it was trying to do this instead of letting LAV do it. There is a PR against the official mpc-hc repo, you can pull it into your own as well:
https://github.com/mpc-hc/mpc-hc/pull/199
Old 7th February 2018, 10:42   #38  |  Link
madshi
Probably this PR will fix dragging UHD "Index.bdmv" into MPC-HC? Doing that works for me with MPC-BE, but currently fails with MPC-HC.
Old 7th February 2018, 11:04   #39  |  Link
nevcairiel
Indeed, thats what its supposed to fix.
Old 7th February 2018, 11:06   #40  |  Link
madshi
Great - thanks!
