25th April 2007, 17:23 | #301 | Link | ||
MKVToolNix author
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
25th April 2007, 18:12 | #302 | Link |
@Mosu: Interesting ideas... my idea is that it can behave just like Word, etc. in that the user won't have to do any renaming after muxing, if the path\filename is the same for input/output. This would save a lot of work, and be really handy!
However, I just realized that there's a big problem with my original request: what to do if there are errors reported in the muxing process? Some errors are trivial (ie. no definitive language ID from .ogm source tracks), while other errors may mean problems (xxx bytes of audio discarded... sync may be lost), and others definitely mean a useless output file. In some of these cases, mkvmerge ought to refrain from purging the original input file, but others it is safe to do so. So an errorlevel would have to be set in the preferences, above which no input file is purged... Last edited by Isochroma; 25th April 2007 at 18:22. |
25th April 2007, 19:28 | #303 | Link |
MKVToolNix author
Way too much work, Isochroma, sorry.
26th April 2007, 09:40 | #305 | Link |
MKVToolNix author
I'd implement everything you're suggesting instantly if I was actually earning a lot of money with mkvmerge It's not that I don't like your ideas, it's just that with my day time job being a programmer most of the time I'm rather unwilling to do more coding in the evening.
26th April 2007, 09:43 | #306 | Link |
MKVToolNix author
http://www.bunkus.org/videotools/mkv...20070426-1.rar
Another build for you guys. This one is able to remux the h.264 stream demuxed from George.Gently.2007.BBC-HD.1080p.H.264.AC3.2.0.ts. Technical explanation: The problem was that the h.264 stream did not contain any IDR slice, and mkvmerge used those for determining when to assign time codes (IDR slice = Matroska key frame). Now mkvmerge also uses type 6 SEI NALUs ( = recovery point indicators) as key frame indicators. On my Linux system mkvmerge is using up to ~65 MB memory if I mux both the h.264 and the AC3 track at the end of the process. This looks promising, but I don't have any other file that big, so testing is up to you
26th April 2007, 10:00 | #307 | Link |
I've a question about h264 support:
When I mux raw h264 files with either mp4box, mp4creator or mkvmerge, I sometimes have the problem that the resulting video file plays slightly shorter or longer than the original file (doesn't matter which of the 3 mentioned tools I use, they behave identical). In such cases the audio track loses sync. I've analyzed the problem and found that in some scenes the mkvmerge muxed video plays like slow motion for a second or so. Then I've tried to mux the Equilibrium HD-DVD h264 stream and it runs too quickly. I guess that the Equilibrium h264 stream doesn't contain "enough" frames and that e.g. static images are realized by using timecodes instead of throwing multiple frames on the same image. I was able to work around the problem by using Haali's Matroska Splitter + Muxer. Sync is perfect that way. Is it possible that this new "recovery point indicator" reading could improve the situation? Or is this likely to be just another problem which is still to be solved? Thanks! |
26th April 2007, 10:06 | #308 | Link | |
MKVToolNix author
What will bring an improvement is when I implement support for MPEG transport streams because then mkvmerge can handle the TS timecodes, too.
26th April 2007, 12:56 | #309 | Link | |
What about EVO parsing? Are there timecodes in EVOs? If so, does mkvmerge make use of those timecodes? Because when I feed a h264 EVO to mkvmerge, sync is lost, too. Interestingly, with "TS -> raw h264 -> mkvmerge" usually the video is longer than the audio after muxing. While with "EVO -> mkvmerge" in my case the video was shorter than the audio after muxing. Does that make any sense to you? |
26th April 2007, 13:19 | #310 | Link | |
Emperor building empire
@Mosu
Is it possible to set the "Output filename" to something along the lines of ' c:\*.mkv ' ... where '*' is the original video filename (less the extension). After that ' c:\MuxedMovies\*.mkv ' and even ' c:\MuxedMovies\*.mux.mkv ' or simply ' *.mux.mkv ' becomes a possibillity... depending on user preference... I encode a lot of video-only MKV encodes (AutoMKV) and mux in the audio/subtitles manually and even knowing which is the final mux is sometimes usefull. A default setting is all good. Pascal *** NOTE *** I guess this is one of those 3-pillars of tank building problems... firepower vs protection vs mobility ... there is no 'one' solution... In the case of MkvMerge you choose ... either to rename, relocate or delete... a single path that is satisfactory most of the time... Last edited by delacroixp; 26th April 2007 at 15:56. Reason: Adendum |
26th April 2007, 13:27 | #311 | Link |
Pain and suffering
@Mosu
GREAT GREAT GREEEAT WORK! I demuxed Superstorm.E01.2007.BBC-HD.1080p.H.264.AC3.5.1.ts 8.04GB (even Haali's latest pre gdsmux.exe failed on this) I demuxed to .h264 and .ac3, muxed 5 minutes then play .mkv to set audio delay in MPC, then muxed the whole thing. Everything went OK! Now..... i can not wait for .ts support, same as Haali, get ready for Hell! |
26th April 2007, 14:10 | #312 | Link |
MKVToolNix author
EVOs and VOBs may contain timecodes, but mkvmerge does not use them. VOBs are really cool things, you know... For example there are a lot of files out there in which the timecodes simply reset in the middle of the file.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. Last edited by Mosu; 26th April 2007 at 14:14. |
26th April 2007, 14:15 | #313 | Link |
Hmmmm... Then I think there's probably a bug somewhere in mkvmerge, cause sync is definitely lost with the h264 Equilibrium EVO. I've tried to create the MKV by dropping the EVO into mkvmerge and only muxing the video track. The audio track was demuxed externally. The audio track is in sync, when directly playing the EVO + external audio track through the Haali filters with Media Player Classic. But the sync is lost when throwing the EVO into mkvmerge. I'll upload a h264 test EVO for you.
26th April 2007, 14:30 | #314 | Link |
MKVToolNix author
I'll just call it a missing feature that'll be implemented one day. The thing is... Timestamps in EVOs are optional. Meaning that for e.g. the Departed trailer there are 3600 video frames and only 315 MPEG PS packets have a timestamp. I'm not sure how I should re-create the timestamps for the missing frames, nor am I sure how I can actually tell which timecode belongs to which frame, especially with the kind of caching mkvmerge does in order not to slow down too much.
26th April 2007, 14:41 | #315 | Link |
Yeah, agreed. If you intentionally don't make use of VOB/EVO timecodes (yet), then that's not a bug.
VOB files with resetted timecodes in the middle of the file were probably originally two separate VOB files which were just joined. If you search through the internet about how to join VOB files, some people claim you just need to join the binary files without any further changes. And funnily many splitters seem to cope with such joined VOB files quite well. But it's probably technically incorrect to join VOB files that way. |
26th April 2007, 15:29 | #316 | Link | |
@madshi
Pascal |
26th April 2007, 23:46 | #317 | Link |
Pain and suffering
@Mosu
I have some good news! To my supprise, i captured something of BBC-HD tonight, and everything was changed, they fixed AR signalling (old bbc.ts = mpc saying: 1964 x 1080, new bbc.ts = mpc saying: 1920 x 1080). The bitrate is set a bit lower too (hopefully encoder update to compensate for quality ) Now, muxing with Haali's gdsmux.exe stalled at 87%, i have had more files doing this, hopefully Haali can fix this. So i demuxed the .ts to .ac3 and .h264. Load them into your latest mkvtoolnix, and voila a proper working The.Quatermass.Experiment.2005.BBC-HD.1080p.H.264.AC3.2.0.mkv on my HDD. Good job! EDIT: Haali's next splitter release, will be able to mux the BBC-HD.ts files directly to .mkv also, Haali has fixed 2 issues that prevented muxing. Now lets hope i can create some more dirty .ts files!! Raw .ts mux directly to .mkv, split with timecodes and boom, result file there, is .mkv actually getting workable??? Last edited by bob0r; 27th April 2007 at 09:38. |
27th April 2007, 16:54 | #318 | Link | |
@bobOr
Pascal |
