23rd October 2006, 10:47 | #161 | Link |
My sympathy to DeathTheSheep and CronoCross. By the way, Bond, I presume that you have a car. Do you know, that its engine was described in 1509 and industrially implemented in 1823? Since that time the only progress was associated with new metals, bigger cylinders, some electronics and polished surface. More or less the same about ships, trains, planes, electricity and encoding with VfW. Does this mean that you reject all the above items because of their obsolete technology? I am encoding since appearance of DivX slow/fast motion (was it 1998-1999?) and your position looks pretty bizarre to me.
23rd October 2006, 12:53 | #162 | Link |
phjbdpcrjlj2sb3h
The comparison of vfw to an engine is misleading - while the petrol engine has not yet been replaced with a newer version, vfw has. You would be better to compare it to the phase out of leaded petrol in favour of unleaded petrol.
23rd October 2006, 13:46 | #163 | Link | |
I've spoken with Haali himself on the topic. To sum up: atm he is not quite interested in the development of either MP4Source() or MKVSource() (or HaaliSource() to handle them all, as I suggested :P) (But I guess if you beg him he might change his position :P) He reminds ppl of his tool called mkv2vfr which from recent versions supports AVC video streams as well. N.B. the reason avc is not quite suitable for VfW is "b-pyramide", this feature, to my knowledge, can't be correctly implemented on VfW. Last edited by Egh; 23rd October 2006 at 13:49. |
23rd October 2006, 13:47 | #164 | Link | ||
Mr. Sandman
Pretending is the right way to get just nothing. Quote:
However as i said thousands of times, you can use the Vdub frameserving capability to feed the frames to x264 CLI (or even to megui), so you can get the best of both "worlds".
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 23rd October 2006 at 13:50. |
23rd October 2006, 15:09 | #166 | Link |
Mr. Sandman
actually if avidemux doesnt open it, you cant. try splitting the file with mp4box then edit it. When you're done, rejoin the files.
However the problem exists also with AVI files (cant be bigger than 4 gigz) but that's an AVI limitation.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 23rd October 2006 at 15:12. |
23rd October 2006, 15:17 | #167 | Link | |
x264 & XviD rules! ;-)
He's talking about large MP4 files.
x264 with mb-tree is kicking my ass!! :o Recommended Codec : Latest x264 revision build for everything. Unrecommended Codecs: everything else. |
23rd October 2006, 15:40 | #168 | Link | |
And the other case: Not everybody is from a country where English is the native language. So the "want" thing you are on about just might be some form of translational error, expressing my wish for some workable form of H264 encoding-posibillities in VDmod. About VD(mod); I just like to work with those tools. They work just fine with my avisynth scripts & XviD encodings, because XviD encoding is the biggest bulk of stuff I do. And there was a new release of VDmod not to long ago, so it's not THAT old. Last edited by G_M_C; 23rd October 2006 at 15:48. |
23rd October 2006, 16:23 | #169 | Link |
Retired, but still around
G_M_C, take a look at this and let us know if that is a possible solution for you. We still need to update the information about whether colormatrix comes in to play as frameserving is rgb. Anybody that has a good grasp of that subject can update the wiki (correct, check?) Frameserving from VDM to x264 cli, or one of the GUI's, is a lot simpler than it might sound.
How to Optimize Bitrate for CCE multipass |
24th October 2006, 08:05 | #170 | Link |
G_M_C, just go to the site
http://gabextreme.googlepages.com/x264vfwunited download x264 VfW and do whatever you wish with the codec and VDub. A comment. Many inventors often forget about COMPATIBILITY with previously available technique (obsolete but customary). If something was started and became widespread, it is practically impossible to change the habitual way of things. Example: the letters on our keyboards are situated in the most stupid order just because the original typewriters had mechanical problems in typing, let us say, “the”. Yet, none of the attempts to make a more convenient layout succeeded. |
24th October 2006, 08:19 | #171 | Link | ||
But enough about this pro vs. con argumenting; I'm gonna make some time of in the next few weeks to set up one of my computers to work with X264/H264. Maybe even try stuff like nVidia's PureVideo decoder and such (on my 7800GS plus). See if I can find out what works best, but from the standpoint that I have to be able to keep using AviSynth and all its filter-possibillities. Thx all for the insight |
24th October 2006, 11:25 | #172 | Link | |
phjbdpcrjlj2sb3h
As to the second prong of your argument (change is hard), you forget that examples - by themself - prove nothing. Last edited by check; 24th October 2006 at 13:44. |
24th October 2006, 11:40 | #173 | Link | |
24th October 2006, 13:36 | #174 | Link | |
Mr. Sandman
Think before you speak.
24th October 2006, 15:20 | #177 | Link |
Mr. Sandman
True, but AFAIK vdub(mod) isnt able to edit them.
24th October 2006, 15:27 | #179 | Link |
Mr. Sandman
it may be. it has been... well, a lot of time since i dont use vdub.
however i clearly remember it had problems with huge AVIs. Maybe things have changed with new versions.
