6th March 2011, 22:10 | #801 | Link | |
Kid for Today
PS: It seems to be due to HMS indeed, everything's recognized as it should using your splitter PPS: You don't provide any option to change the "input buffer size" like in HMS? When seeking within a MKV on a DVD-R, it can be jerky...I can even completely lose the audio for a few secs. Also, HMS has good error resilience when seeking in broken MKV's..does yours too? Anyway, PotPlayer has a lot of options to have the audio/video bitrate/bitdepth/number of channels displayed on the skin...and very often all HMS had to tell PotP was "0", duh. Now I get my magic numbers each time, too cool Last edited by leeperry; 7th March 2011 at 01:45. |
7th March 2011, 11:43 | #802 | Link |
Input Buffer doesn't really help that much when seeking on a slow medium. Once the seek request finishes, LAV Splitter will immediately start demuxing again, and run the demuxer constantly until the buffer is filled again (around 100 packets), while another thread starts dispatching those packets to the decoders while the demuxer is still powering through the file to fill the buffer. I don't see how any buffer changes can reduce that latency.
I'm always open to improving seeking, as its usually one of the things a splitter either shines at, or is total crap. LAV Splitter supports key-frame/index seeking as used by MPC-HC, which greatly improved seeking performance in MKV (and some other formats). I've also got some feedback that seeking is really working well, at least with MKV. MPEG-TS seeking is always a bit weird, but it feels "ok" to me, at least on BluRay media, which is usually "good" MPEG-TS. DVB captures are most of the time just broken, because the capture apps have incomplete or broken muxing tools. :/ For the error resilience, thats all in the hands of ffmpeg. Feel free to throw some corrupted files at it, and see what happens.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 7th March 2011 at 13:21. |
7th March 2011, 20:47 | #803 | Link |
Kid for Today
I've enabled keyframe seeking in PotPlayer, it works like a charm w/ HMS and the built-in MKV splitter. Very fast seeking, no hiccup and I never lose audio. Lemme know if there's any way I could provide you w/ logs or something? I've encountered the problem when reading MKV(h264+1.5mbit DTS) from DVD-R, and I was using CDBremse to slow down the 16X Liteon XJ-HD166S drive to 6X(it becomes hardly audible).
7th March 2011, 21:25 | #804 | Link |
I can burn some MKV to a DVD-R and test with that, i guess. AnyDVD offers a slow-down option, i'll run it on the slow & quiet preset, not sure what speed that is effectively.
I should also add some logging for users to see, right now all logging is only with a proper debugger *shrug*
8th March 2011, 01:45 | #805 | Link | |
Kid for Today
So as I said, PotPlayer has an option for keyframe seeking:
Seeking in MKV(h264+448kbit AC3) w/ this option checked, I've got the exact same problems as when seeking from a DVD-R...I lose the audio for a few secs after seeking, it also stutters and sometimes stalls for a second or two. If I uncheck the option, I can easily get it to freeze PotPlayer completely. HMS works fine w/ both options, but seeking is slower if it's unchecked. I run XPSP3, and here's my active filter list: Quote:
I mentioned error resilience because HMS copes a lot better w/ broken MKV's than the built-in PotPlayer/KMP MKV splitters...the latters usually freeze the player when encountering broken frames, OTOH HMS allows you to reseek easily. Last edited by leeperry; 8th March 2011 at 01:53. |
8th March 2011, 08:00 | #806 | Link | |
As i mentioned earlier, alot of people confirmed these findings with MPC-HC. Not sure if its really a player thing. I'll test from a slow optical medium, and try that PotPlayer.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 8th March 2011 at 08:05. |
8th March 2011, 08:17 | #807 | Link |
Just a thought: Any splitter can issue a seek command through the graph interface methods. Maybe it would be a nice trick for the splitter to "fine tune" any user seek request by issuing a correction seek command to the nearest video key frame? The net effect should be similar to seeking in MPC-HC with Key-Frame seeking enabled. However, it should work with any media player.
8th March 2011, 08:20 | #808 | Link |
I actually had something like that planned for the future, but as MPC-HC is my main target, i didn't give it any high priority.
8th March 2011, 08:45 | #810 | Link |
In theory it shouldn't even be needed to issue another seek request. The IMediaSeeking::SetPosition call is not guaranteed to end up on that spot exactly, i could just change the target position before doing the actual seek, and the player would then receive the new current position either through the argument it put in (its a pointer for a reason), or by calling GetCurrentPosition afterwards.
I hope the filter graph is smart enough to fix the reference clock in this case. Something to test. This of course depends on the player being developed sanely.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 8th March 2011 at 08:50. |
8th March 2011, 09:02 | #811 | Link | ||
FWIW, I rather doubt it will work, but it might be worth a try. If it does work, I would recommend to test it in all OSs, just to be safe... |
8th March 2011, 09:07 | #812 | Link | |
In any case, dispatching a new seek request would work as well.
8th March 2011, 09:14 | #813 | Link |
Yes yes, that's correct. What I meant to say is that AM_SEEKING_ReturnTime is the only thing in the documentation that mentions modifying the position values. When AM_SEEKING_ReturnTime is not set, the doc does not mention that you could/should change the position values.
8th March 2011, 09:58 | #814 | Link |
You're right, its not really documented like that.
Oh well, i'll just do it with another seek request, just have to be careful to not create a loop there.
8th March 2011, 10:28 | #815 | Link |
guys,
I might be guessing here but would this change from "precise seek" to "key frame seek" break the frame by frame stepping that ZoomPlayer and other players have? Excuse my ignorance if this has nothing to do with your conversation. |
8th March 2011, 10:30 | #816 | Link |
Yes it would. But i wouldn't have it always on, but offer an option to enable/disable it.
8th March 2011, 12:50 | #818 | Link |
Kid for Today
Well, to me the point of using your splitter is rather clear...here I get the AC3 bitrate right on the PotPlayer transport bar(as I've always dreamed about):
HMS simply says "0": I've spoken to Haali about those problematic samples, and his splitter simply repeats verbatim what's written in the MKV itself. If I demux/remux those 2 samples using mkvtoolnix 4.0, then they're both properly detected as 5.1 These 2 samples were muxed by 2 different ppl using different versions of mkvmerge, so I dunno wth is going on(even MediaInfo sees them as stereo)....anyway, it's only a side effect of the fact that HMS simply repeats what's written in the container header, when OTOH your splitter actually checks for the bitrate/number of channels of the streams...which provides all the right infos about bitrate/number of channels to the DS graph filters. I would very much appreciate if you could bring the seeking operations(using PotPlayer) to the foolproof status of HMS. PS: HMS tells the bitrate of FLAC soundtracks(using madFlac), but your splitter simply says "0". I can make a sample. PPS: humm yeah, I've seeked in a MKV(h264+20bit 7.1 FLAC, authored w/ mkvtoolnix 4.0) a few times, and then seeking didn't work anymore...no picture/no sound. PotPlayer hadn't locked up, though. Last edited by leeperry; 8th March 2011 at 13:04. |
8th March 2011, 14:07 | #819 | Link |
Bitrate info is purely cosmetic and not really my main concern. Some ffmpeg codecs don't export bitrates, maybe flac is one of those. I can check if it somewhere stores the container supplied bitrate value, though.
8th March 2011, 16:26 | #820 | Link |
Okay, i tried alot of my files with PotPlayer (all from local HDD or my network storage), and seeking is as smooth as it is in MPC-HC, no issues whatsoever.
This was with ReClock, madVR, ffdshow audio and video. Switching to CoreAVC for decoding, its still fast, but takes maybe half a second after seek to produce an image - does not matter if i have ffdshow raw video processor in there, or not. I would guess flushing the hardware pipeline could possible be slightly slower. Vanilla PotPlayer settings, except filter choices (decoders mostly set to system default instead of internal, renderers to reclock and madvr respectively) I could not produce any freezes, or anything of that sort. Seeking was a pleasure as i know it from MPC-HC. I can try from an optical media on the weekend, but seeking in BluRays was working just fine the last times i tried.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 8th March 2011 at 16:30. |
