8th November 2010, 18:31 | #401 | Link |
mpg.coruption.mpg
ffdshow-libavcodec - corruptions on begining ffdshow-libmpeg2 - crash while seeking mpc-hc MPEG-2 Video, Microsoft DTV-DVD Video Decoder (system) - no problem mpg.mpeg-1-not_working.mpg ffdshow-libavcodec - gray screen ffdshow-libmpeg2 - crash while seeking mpc-hc MPEG-1 Video, MPEG 1 Video Decoder (system) - no problem Last edited by v0lt; 8th November 2010 at 19:15. |
8th November 2010, 18:37 | #402 | Link |
Yeah, there is that crash bug in ffdshow libmpeg2 .. blame them, its their fault afterall!
I'll try to fix the libavcodec mode.
8th November 2010, 19:13 | #403 | Link |
But the MPC-decoder (rev. 2719) does not have this problem. And it also built from libmpeg2. Besides, with the MPC-splitter also no problem.
Sk08er_Boi_(sample).m2v LAVFSplitter ffdshow-libavcodec - corruptions ffdshow-libmpeg2 - crash while seeking mpc-hc MPEG-2 Video, Microsoft DTV-DVD Video Decoder (system) - no problem MPC - Mpeg Splitter (Gabest) ffdshow-libavcodec - corruptions ffdshow-libmpeg2 - no problem mpc-hc MPEG-2 Video, Microsoft DTV-DVD Video Decoder (system) - no problem Last edited by v0lt; 8th November 2010 at 19:31. |
8th November 2010, 20:08 | #405 | Link |
Almost the 1st one. MediaPortal's TsReader has had that supported for quite long time I guess same appliest to DVBViever's TS source filter. DVB applications need that since there are already many broadcasters using that audio format.
8th November 2010, 22:18 | #406 | Link |
Even if it technically is a DS filter, I don't think DVB Source can be used outside DVBViewer though. At least it didn't work in MPC-HC last time I tried it (set as a preferred external filter).
I know you're a.k.a. Tourettes (MP developer). Does TSReader work with MPC-HC? Do you have a link to a standalone TSReader filter? |
9th November 2010, 10:37 | #407 | Link |
nevcairiel,v0lt:
I have something for you: This MOV sample wont connect to FFDshow audio decoder. It is working fine if MPC MP4 splitter is in use. LAVF splitter output audio as: (wont connect to FFDshow audio decoder) subtype: Unknown GUID Name {1100736D-0000-0010-8000-00AA00389B71} MPC MP4 splitter: (working) subtype: Unknown GUID Name {00000011-0000-0010-8000-00AA00389B71}
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
9th November 2010, 13:35 | #408 | Link |
Stupid MOV and their collection of weird PCM variations.
9th November 2010, 16:05 | #409 | Link | |
Anyway, this is already off topic and should be discussed some other place (or at least in a separate thread). |
10th November 2010, 20:00 | #410 | Link |
Virtual_ManPL
@ nevcairiel - please reopen this bugs, because they are not fixed completely
https://github.com/Nevcairiel/LAVFSp...losed#issue/20 https://github.com/Nevcairiel/LAVFSp...losed#issue/26 |
10th November 2010, 20:05 | #411 | Link |
Oh but they are.
The TS file plays perfectly for me, and the fix for the other file is not supposed to enable subtitles by default, its supposed to allow you to configure what to do.
10th November 2010, 20:30 | #412 | Link |
Virtual_ManPL
Odd...
In my configuration with standalone MPC-HC and LAVFSplitter, player shows error like I posted on bug tracer about bug #26 And bug #20 now is not fixed, because I'm talking about enabling subtitles from fresh start (like in MPC-HC or Haali) without settings any prioritizes in language settings, now in some files subtitles are enabled, in some are not like I posted sauce on bugtracker ;p |
10th November 2010, 20:32 | #413 | Link |
Set it to full subtitles, and disable "only matching languages" or how i named the checkbox, and it should always activate some subtitle.
If not, then thats a new bug. For #26, you didnt post any error, just a file and a media type info.
14th November 2010, 23:12 | #415 | Link |
First 10 meg of a bluray remux. Full MKV and this split test clip cause MPC-HC to crash with this splitter. Haali plays back fine (Except I get a crash on seek bug sometimes).
http://hotfile.com/dl/82598375/dc86f5c/test.mkv.html |
16th November 2010, 05:44 | #416 | Link |
Thanks for the great work, I have been reading through this thread & trying the versions, but still cant figure it out.
I am using Zoom Player for years, I have tried configuring the player to use LAVFSplitter as a source /splitter, to no avail. In fact, This is the first time I ever used a source/splitter filter that doesnt work in Zoom Player However manually building a graph in Graphedit does work. Can anyone please give me a tip? Am I missing something? I am on XP pro. |
16th November 2010, 09:11 | #417 | Link |
Hello,
I've been using LAVF Splitter with MPC-HC for some time and am very happy with it. The splitter will not load under MPC-HC for the following file, I'll try to upload a sample later. Code:
General Format : Matroska File size : 7.32 GiB Duration : 1h 37mn Overall bit rate : 10.7 Mbps Encoded date : UTC 2010-10-15 01:09:09 Writing application : mkvmerge v4.3.0 ('Escape from the Island') built on Sep 5 2010 10:30:51 Writing library : libebml v1.0.0 + libmatroska v1.0.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Format settings, GOP : M=1, N=36 Codec ID : V_MPEG4/ISO/AVC Duration : 1h 37mn Bit rate : 10 000 Kbps Width : 1 920 pixels Height : 816 pixels Display aspect ratio : 2.35:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.266 Stream size : 6.69 GiB (91%) Writing library : x264 core 105 r1732 2b04482 Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=tesa / subme=10 / psy=1 / psy_rd=0.80:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=10000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.60 Language : English Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 1h 37mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 448 MiB (6%) Language : English Audio #2 ID : 3 Format : Vorbis Format settings, Floor : 1 Codec ID : A_VORBIS Duration : 1h 37mn Bit rate : 64.0 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Stream size : 44.8 MiB (1%) Title : Filmmakers' Commentary Writing library : libVorbis (Everywhere) (20100325 (Everywhere)) Language : English Text #1 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : English Text #2 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Arabic Text #3 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Bulgarian Text #4 ID : 7 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Chinese Text #5 ID : 8 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Croatian Text #6 ID : 9 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Czech Text #7 ID : 10 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Danish Text #8 ID : 11 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Dutch Text #9 ID : 12 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : French Text #10 ID : 13 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Greek Text #11 ID : 14 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Hebrew Text #12 ID : 15 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Indonesian Text #13 ID : 16 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Korean Text #14 ID : 17 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Persian Text #15 ID : 18 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Polish Text #16 ID : 19 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Portuguese Text #17 ID : 20 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Romanian Text #18 ID : 21 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Serbian Text #19 ID : 22 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Slovenian Text #20 ID : 23 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Spanish Text #21 ID : 24 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Swedish Text #22 ID : 25 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Vietnamese Text #23 ID : 26 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : Filmmakers' Commentary Language : English Text #24 ID : 27 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : Filmmakers' Commentary Language : French Text #25 ID : 28 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : Filmmakers' Commentary Language : Portuguese Text #26 ID : 29 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : Filmmakers' Commentary Language : Spanish Menu 00:00:00.000 : en:CHAPTER01 00:08:39.811 : en:CHAPTER02 00:11:31.983 : en:CHAPTER03 00:15:11.035 : en:CHAPTER04 00:21:57.107 : en:CHAPTER05 00:27:41.702 : en:CHAPTER06 00:33:14.201 : en:CHAPTER07 00:39:07.136 : en:CHAPTER08 00:43:28.731 : en:CHAPTER09 00:47:08.367 : en:CHAPTER10 00:49:47.193 : en:CHAPTER11 00:59:55.801 : en:CHAPTER12 01:04:47.383 : en:CHAPTER13 01:09:28.164 : en:CHAPTER14 01:12:38.187 : en:CHAPTER15 01:23:26.043 : en:CHAPTER16 01:28:54.496 : en:CHAPTER17 |
18th November 2010, 00:32 | #418 | Link |
zipi,
I'm in the same situation. LAVFSplitter won't work with ZoomPlayer. A few months ago there was a brief discussion between the authors of the two programs but they didn't reach to a solution. I didn't understand what was the problem so I too will be glad if nevcairiel or someone else can explain why this is the only splitter that doesn't work with ZoomPlayer. I'm not saying that the problem is in the splitter but obviously there is something different in it that prevents it from working in ZP. |
18th November 2010, 09:48 | #419 | Link |
There was a discussion? I don't particularly remember it, oh well.
I have never used ZoomPlayer, so i have no insight in its operations, really.
18th November 2010, 10:54 | #420 | Link |
Hi nevcairiel - nice splliter! FYI I've posted a guide a on how to use this with the Arcsoft TMT filter for DTS-HD (and other Blu-ray Audio decoding) in MKV's etc in JRivers Media Centre (http://yabb.jriver.com/interact/inde...8875#msg408875). It works really well with the excpetion of files with subs in them. They either fail to load or need a seek to start playing but even then I don't see the subs.
Thanks nathan |
