13th June 2007, 01:12 | #542 | Link |
Avisynth Developer
@Zep,
As I said it's the ASF splitter not the decoder. You are lucky if your default ASF splitter works correctly (desirably ), many peoples do not. I am just pointing out that there is (was?) a known problem and they may need to look at which splitter they have. DirectShow is such a bag of worms. |
13th June 2007, 03:20 | #543 | Link | |
r607 | pengvado | 2006-12-16 00:03:36 +0100 (Sat, 16 Dec 2006) | 13 lines New threading method: Encode multiple frames in prallel instead of dividing each frame into slices. Improves speed, and reduces the bitrate penalty of threading. Side effects: It is no longer possible to re-encode a frame, so threaded scenecut detection must run in the pre-me pass, which is faster but less precise. It is now useful to use more threads than you have cpus. --threads=auto has been updated to use cpus*1.5. Minor changes to ratecontrol. New options: --pre-scenecut, --mvrange-thread, --non-deterministic |
13th June 2007, 04:55 | #544 | Link |
Angel of Night
It's megui's fault, actually. The command line will say --threads auto, but the command it actually uses will be --threads x, where x is the # of detected cpus. That's a pretty nasty bug.
Edit: Ah, you can work around it by removing "automatically set number of threads" in options, until I get a patch in. Last edited by foxyshadis; 13th June 2007 at 05:42. |
14th June 2007, 12:44 | #546 | Link | |
second as foxs pointed out There is a bug JUST LIKE I SAID here let me repeat what I said "something is borked" and now we know what it is. so just admit I was right and move on |
14th June 2007, 13:05 | #547 | Link | |
graphedit didn't show the splitter per se'. it just showed RAW AUDIO 1 and RAW VIDEO 2 being spilt from and unnamed splitter and no info on the splitter in the main graph but I looked just now to see what splitter has highest merit and it is indeed the m$ one. I disable everything else and ran it again to make sure the m$ splitter was being used and it ran full speed. Now I'm pretty sure when you install WMP 11 you get the latest splitter and decoders so maybe those fixed that very bad cough feature cough |
15th June 2007, 04:08 | #548 | Link | |
15th June 2007, 12:33 | #549 | Link |
yes I saw your reply to fox. Not exactly the same thing as replying to me Anyway, because you use CLI doesn't mean we all do so your post about going auto actually triggered the bug for Lele-brz if he is using MeGUI. yuck! lol
15th June 2007, 20:51 | #550 | Link |
warpsharpened
Trying to MT a script:
LoadPlugin(... Import(... SetMemoryMax(768) movie = mpeg2source("C:\VTS_04_1.d2v",info=3) function getOrder(clip c) { order = GetParity(c) ? 1 : 0 Return order } movie = tfm(movie,d2v="C:\movie.d2v").tdecimate() last = movie crop(4,0,-4,-0) #Resize Spline36Resize(704,396) #Filters Combination of: Removegrain, hqdn3d, LimitedSharpenFaster, aSharp, aWarpsharp, LineDarkenMOD Any suggestions how to do it? Last edited by TheRyuu; 15th June 2007 at 23:10. |
16th June 2007, 06:23 | #551 | Link | |
I hardly get crashing, but I always get the effect which was described the above links: if one file is playing, then I try to play another, mpc doesn't play it: Failed to query the needed interface. |
18th June 2007, 04:02 | #552 | Link |
warpsharpened
BTW, on the script I posted above that I'm trying to get working with MT, I know that whenever you have "source" you have to use SetMTMode() right?
But why would adding it right in the beginning be causing xvidencraw to crash on me? Or is that just because this "MT Mode" isn't stable? |
18th June 2007, 08:43 | #553 | Link | |
ffdshow/AviSynth wrangler
Graphedit crashes right out as soon as you hit "File > New" after rendering a media file that uses ffdshow and AviSynth...
now playing: [artist] - [track] ([album]) |
18th June 2007, 10:52 | #554 | Link |
Leak:
Do you get any usefull debug/error output when running a debug build of ffdshow with my version of avisynth MT?? I have tried a debug version of avisynth MT but that doesn't produce any obvious indication of where the error is.
Get my avisynth filters @ http://www.avisynth.org/tsp/ |
18th June 2007, 11:00 | #555 | Link | |
Oh, and is there perhaps a chance of your MT code being included into AviSynth 2.5.8? (Just being curious there...)
18th June 2007, 22:36 | #557 | Link | |
Deinorius: try the mediawiki page:
The MT code will first be included in avisynth 2.6 to preserve stability in the current 2.5 release
