14th September 2013, 10:10 | #1802 | Link |
Not sure what you want, I guess you wanted to ask which is better, MeGui or Hybrid.
Since they both use the same encoder, there shouldn't be much of a difference. Surprise! Personally I prefer Hybrid, but I'm the author. *gig* MeGui: - Windows only (afaik) - always uses Avisynth (scripts need to be adjusted to use Avisynth MT) - allows the user to manipulate the avisynth scripts - easier to use, but has less options Hybrid: - Crossplattfrom - uses Avisynth only if the AvisynthExtension is used (always uses Avisynth MT unless told otherwise) - does not allow the user to manipulate the avisynth scripts - more options -> more complicated to use, no One-Click-Mode Cu Selur |
14th September 2013, 20:08 | #1805 | Link |
I may confirm it:
YES, selur does answer the questions and solves bugs very quickly. Furthermore, Hybrid is natively cross-platform. Very interesting for us Linux users. I just miss in Hybrid support for avisynth in Linux... but MeGUI also doesn't. And it is not Hybrid's fault. Maybe someday Vapoursynth... |
15th September 2013, 18:30 | #1807 | Link | |
You're right. Certainly it seems to be good than Megui. but I found some of bugs. for example After I finished an encoding from DVDISO source, as I input same DVDISO again. Hybrid is crased. I always have to reinstall for re-work I don't know why the program is crashed. |
15th September 2013, 18:35 | #1808 | Link |
I suspect I probably fixed that problem a while ago but didn't release a new public version yet, since (a. still waiting for feedback regarding another bug b. got some problem connecting to my mac build environment atm.)
-> if you tell me which OS you are using, I can send you a link to a development version, if that version also doesn't help see: http://selur.de/support regarding what infos are needed for me to reproduce and fix a problem |
16th September 2013, 19:20 | #1809 | Link |
Hybrid rev 2013.09.16.1:
*changed*
-> downloads: http://www.selur.de/downloads Cu Selur |
17th September 2013, 03:21 | #1810 | Link |
Selur
Hybrid rev 2013.09.16.1: Experimental! DivX265 Info: Your Mp4Box version seems to be too old to handle MPEG-4 AVC content! Excuse my ignorance on the subject, but I searched and tested some versions of MP4Box and still the same message? Could indicate MP4Box.?? Thank's Last edited by Marchand; 17th September 2013 at 03:35. |
17th September 2013, 07:12 | #1811 | Link |
Damn, that is what I forgot to add to the package, an updated MP4Box Version. Version needs to be 4524+.
Current MP4Box nigthly versions should be fine. (http://gpac.wp.mines-telecom.fr/downloads/gpac-nightly-builds/ you would need the mp4box binary and the supporting libraries) -> will update the Hybrid download -> new Installer and Win32 package is uploaded Last edited by Selur; 17th September 2013 at 07:37. |
17th September 2013, 13:58 | #1812 | Link |
Hybrid rev 2013.09.17.1:
*changed*
-> downloads: http://www.selur.de/downloads Cu Selur Ps.: Starting with Thursday, I'll be offline and on holidays, so don't wonder if I don't reply to messages/posts. Last edited by Selur; 17th September 2013 at 22:49. |
18th September 2013, 00:49 | #1813 | Link | ||
Selur.
Your new encoder is very good. After some tests and with the exchange of 03 executable files, the file got Hevc-MKV (AUDIO AND VIDEO), which works perfectly in DivXPlayer 10 with the same final file size. Test Video Hybrid.v2.Run.DivX.Player.mkv: https://shared.com/zzeapv260h Quote:
Test Video Hybrid.v1.Run.Osmo.Player.mp4: https://shared.com/qjzje10b17 Quote:
Finally, follow the link 03 zipped executable files to their final tests in Hybrid and exchange if they want and if you can enable the option we can save the configuration of testing HEVC (. Xml) would be good for us. Link 03 files zipped: https://shared.com/zjdbv1ohlc Thanks for your project and your commitment to provide us with this great encoder. Last edited by Marchand; 18th September 2013 at 00:56. |
18th September 2013, 00:57 | #1814 | Link |
Hybrid does not support hevc inside mkv since mkvtoolnix does not support it atm., the only way to save HEVC inside mkv is using some by DivX/Rovi modified mkvmerge&Co versions, which Hybrid does not support because the version is based on 6.2.0 (current is 6.4.1) and I'm not sure how future proof these versions are.
19th September 2013, 12:56 | #1815 | Link |
just a quick question really, does this program convert Bluray to Xvid without going through a Indexing process of any kind (i use XMedia Recode which does realtime converting, like handbrake does), I'm looking for something a little better than XMedia Recode, it's good for what it is, but one small thing that has always plagued this program is the way it crops, and the resolution aspect ratio downscaling functions.... it quite often gives me a really low height resolution which is much lower than what MeGUI would give, or handbrake for that matter, i have emailed the developer three times, with no answer!
Handbrake does now support ASP output (with the right advance command you can make a compatible ASP Xvid output, then just change the container for AVI), however it is not powered by Xvid itself, but rather a generic version of it (inside ffmpeg), which after many tests is far inferior to Xvid ( Code:
profile=15:level=5:trell:mbd=2:mv0:v4mv:cbp:dia_size=2:pre_dia_size=2:last_pred=3:cmp=2: \ precmp=2:subcmp=2:bf=2:b_strategy=1 any suggestions would be great, i just hate having to go through the indexing part with bluray films because it takes ages, and really puts a lot of strain on hard drives, also with ffmpeg and mencoder now being so mature in development, i'm still surprised how many converters still need to index stream first before encoding??? mediacoder is good on paper, but it's so slow, and very buggy, i can never get it to use more than 40% of my cpu no matter what settings i use (3770k) any feedback i'll appreciate, looking for some insight aswell too. Last edited by Guest; 19th September 2013 at 13:11. Reason: readability/formatting |
19th September 2013, 13:14 | #1816 | Link |
DGDecNV can index a bluray in about 5 minutes. Is that really so onerous? Indexing isn't a useless thing, you know. It allows for accurate and robust random access, which is critical for the proper operation of many Avisynth scripts.
19th September 2013, 13:37 | #1817 | Link |
but to index a bluray stream, you have to demux first, i didn't say that part "demuxing", when i rip a bluray it creates a MKV or a .ts file, this can't be indexed without causing serious issues... so MeGUI for example will have to demux first, then index, then it can start the job, then it has to remux the final output..... 30 to 40minutes if not more has been wasted just on demuxing, indexing and remuxing alone. this is what i am trying to get around.... like handbrake does (but no Xvid support)
i understand the need for anysynth, but it would be nice to have a option to bypass that if needed (speed) |
19th September 2013, 13:46 | #1819 | Link | |
if my MeGUI setup is wrong, please tell me, everytime i load a bluray into MeGUI, it first demuxes the streams i want from the MKV or .ts file, then it indexes the actual video stream, then it does the encoding job i want, but of course now it needs to remux the video and audio stream into a AVI container. so that is not true, so please, tell me where i can forego, the need to demux, remux, and go straight to the encoding in realtime. |
