3rd April 2009, 09:23 | #1842 | Link |
Programmer (or just 教务长)
No... I meant that I've probably missed your question the first time
*** Another interesting find after playing a bit with uncropMKV. Playstation3 will use 576p output only with 720x480p@25fps 720x480p@30fps 720x480i@50fps 720x480i@60fps 720x576p@25fps 720x576p@30fps 720x576i@50fps 720x576i@60fps and it has to be true 25/30/50/60 fps not fractions. |
3rd April 2009, 11:24 | #1844 | Link |
I'll check the permissions but I can sometimes briefly see the multiUPDATE screen. I can stop multiAVCHD from continuing the loop (and use it as build 476) by telling my firewall to block all internet access. It's not a big problem for me and it will be a long time before Windows 7 64bit is in general use.
3rd April 2009, 11:27 | #1845 | Link |
You can open multiAVCHD.ini file and edit line 15.
1 - autoupdate 0 - no update The problem is that if you're a lot of builds behind - this option will be ignored and multiAVCHD will forcefully update. Of course you know that build 476 will expire really soon. Last edited by deank; 3rd April 2009 at 11:31. |
3rd April 2009, 11:36 | #1846 | Link | |
I use the latest (say build 490, 493, 494) but once it can't get the update, something must get deleted in preparation for the update because multiAVCHD reverts to saying it is build 476. |
3rd April 2009, 11:39 | #1847 | Link |
You can delete multiAVCHD.exe and execute multiUPDATE.exe
If it doesn't work you can always download the program yourself from this link: http://multiAVCHD.deanBG.com/multiAVCHD.exe It is possible that win7 somehow 'restores-previous-versions' - there is such option in Vista I think.. Last edited by deank; 3rd April 2009 at 11:43. |
3rd April 2009, 19:12 | #1850 | Link |
On drive M, I have a multiAVCHD created AVCHD output with 2 titles. Then I run multiAVCHD again, select the drive M AVCHD folder as input, and a bunch of other avchd folders from other harddrive, in order to add more titles to the existing multiAVCHD compilation. The Editor page correctly display all the existing and newly added titles entry. Then I click the "create multiAVCHD", and a error popup "(RT) Cannot rename file M:\AVCHD to M:\AVCHD-20090404-015718 - Line 6108."
System is WinXP, multiAVCHD build 495, output harddrive is FAT32. regards, Li On |
4th April 2009, 00:27 | #1855 | Link | |
chapter would popup after pressing DOWN button and tableview should popup after pressing UP button in coverflow User could return to cover flow by DOWN button I will upload avs script tomorrow
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 4th April 2009 at 00:32. |
4th April 2009, 06:48 | #1856 | Link |
Howdy Deank.
have used newest build 495.. under AVCHD Folder it creates as you knew. BDMV F details .txt detailsEXT .txt multiAVCHD .txt multiCHAP .txt multiMENU .txt But zero CERTIFICTE Folder??? What do you think.. Cheers |
4th April 2009, 08:04 | #1857 | Link | |
Some small glitch on mine side ..must have overseen something.. cheers |
4th April 2009, 16:04 | #1858 | Link |
I keep getting this error on 2 mkv files.
(RT) Floating point division by zero - Line 7796 Both have srt subtitles. If I remove the subs, it goes through without errors. Other mkvs with subs and everything don't have any problems, but I can't get past these 2. Any ideas? Great program BTW. Edit: Forgot to say I'm getting the error when preparing custom menu, XMB chapters part.
Welcome....to the real world. Last edited by matrix; 4th April 2009 at 16:21. |
4th April 2009, 16:27 | #1859 | Link | |
http://forum.doom9.org/showthread.ph...99#post1268499
Paul Ng |
