12th April 2009, 20:12 | #2061 | Link |
Issue #1
Here's my 1st issue:
The log contains the following error "tsMuxer didn't like (). Skipping it...", without additional info. The full log is attached in my next post. I'm using build 515 Last edited by gordan; 12th April 2009 at 20:22. Reason: Attachment added |
12th April 2009, 20:21 | #2063 | Link |
Issue #2
... and the 2nd:
The error is "Important files missing (clpi/mpls/m2ts)... Possible tsMuxer failure to process your input file (I:\Video\Movies\movie.mkv)." The log and info on the movie are attached. In an ideal world, the message would be very specific. Is there something that can be done to explain what is wrong? THX! G Last edited by Guest; 13th April 2009 at 22:18. |
13th April 2009, 03:03 | #2069 | Link |
Home Theater Freak
Oh quick question...when I play the titles in the playlist (from beginning till the end)...when I press the NEXT CHAPTER button on my remote, why can't the title skip to the next playlist item? Is there a workaround instead of pressing the <Menu> or <Title> button on the remote whenever I want to go on to the next chapters towards the end? Likewise for PREVIOUS CHAPTER for cycling backwards...I though this is quite an important function for all authoring tools of DVD and Bluray :P
13th April 2009, 06:15 | #2071 | Link | |
http://acronyms.thefreedictionary.com/IIRC
Paul Ng |
13th April 2009, 06:54 | #2072 | Link |
Hi Dean, thank you for your amazing work with multiAVCHD.
I donīt know if this applies to the AVCHD format, i have a PS3 and i use a streaming app called Ps3 Media Server, i use it mostly to stream SD videos or music, anyway im telling you this because they managed to stream DTS without transcoding or converting to LPCM, they trick the Ps3 player by sending a supported audio file (AC3, i think), and after a second, the server changes it back to the original DTS stream, so your audio equipment notices this change and then it decodes the DTS stream. Maybe (or maybe not) this could be done with multiavchd to avoid transcoding the DTS MA/HRA to LPCM or AC3, with LPCM as you well know, we conserve quality but increase the file size a lot, and with AC3 we lose quality, so maybe its worthy to try this. Thanks again... |
13th April 2009, 08:25 | #2073 | Link | |||
Programmer (or just 教务长)
13th April 2009, 09:47 | #2074 | Link |
In build 518:
index.bdmv is generated in different way so now players will show proper title count (not always 40). There was an issue with PowerDVD when I did it in build 421, so please if anyone can - test PDVD with the latest build. Dean |
13th April 2009, 10:00 | #2076 | Link |
Home Theater Freak
I always experience auto-update function problem...I can see the script running with the pop-up box showing checking for newer fiirmware version - despite several attempts to update, the latest build just simply refuse to be updated...but other times its okay. Is the window period (time) to download the patch been too short? What gives?
13th April 2009, 10:11 | #2077 | Link |
Close multiAVCHD and execute multiUPDATE.exe. Does it show any errors? There are three mirror links to check - it should download from at least one.
A direct link to the exe: http://multiAVCHD.deanBG.com/multiAVCHD.exe |
13th April 2009, 10:38 | #2078 | Link | |
Home Theater Freak
