Old 26th March 2025, 17:07   #461  |  Link
erick
Originally Posted by taurusus View Post
It is necessary to change all files, m2ts, mpls, clpi.
I understand, I'll do the test and let you know if it works
Thanks
erick is offline   Reply With Quote
Old 26th March 2025, 20:05   #462  |  Link
erick
get it friend, now my other question in this case how to delete the blank spaces from the menu can you help me universal and different from sony
put the Portuguese name in second place below the English so as not to be far away
https://www.mediafire.com/file/59pz7.../menu.rar/file
Old 27th March 2025, 07:11   #463  |  Link
taurusus
Edited the classes.
Audio: sh.class, ETXletUSA.class, ql.class
Subtitle: il.class, ETXletUSA.class, ql.class
Top menu: bd.class, ETXletUSA.class
https://cloud.mail.ru/public/Qy9D/KbSEpbkzc
taurusus is offline   Reply With Quote
Old 27th March 2025, 11:32   #464  |  Link
erick
Edited the classes.
My friend, thank you very much for your support, you are very intelligent, gratitude for everything
Old 13th April 2025, 20:11   #465  |  Link
palestina
Hi.
Do I still need IGFix FE to edit a multiplexed menu?
Or is there another alternative?
Thank you.
palestina is offline   Reply With Quote
Old 14th April 2025, 22:02   #466  |  Link
ocean
Hi palestina, IGFix FE from Defsoft, I have the demo version, unfortunately the full version is no longer on the market:
If it won't be implemented in BDedit, from what I know it's possible to work on it with scenarist.
ocean is offline   Reply With Quote
Old 15th April 2025, 11:43   #467  |  Link
palestina
Yes, that's the demo version I have too. It's a shame I can't access the full version anymore.
Unfortunately, I've never worked with Scenarist. I have the program, but I've never used it.
It's a shame it hasn't been implemented in BDedit.
Best regards, and thank you.
Old 26th April 2025, 09:24   #468  |  Link
palestina
I'm working on a movie (Black Hawk Down) with two cuts (Theatrical and Extended Cut) and an IGS menu.
I'd like to know if it's possible to remove the option to select a cut from the start of the disc.
I'd like to have it go directly to the main menu when the disc starts (after the Sony title).
Thank you.
Old 26th April 2025, 11:26   #469  |  Link
taurusus
Hi, I don't know how to disable one version of a movie in BDedit. It worked several times after disassembling the disk in the Scenarist, and then editing the ies file in IGEditor.
Old 27th April 2025, 10:28   #470  |  Link
palestina
Thank you so much @taurusus
