Old 9th August 2018, 18:46   #4201  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
This is based on my observation when developing VS but it'd surprise me greatly if AVS isn't guilty as well.
At some point the frame requests end up out of order and then the source filter has to seek. This is very slow in most of them. I ended up adding logic and a flag to indicate which filters really benefit from linear access and extra logic to make requests in order more of the time. It resulted in significant speedups.
I don't understand how Avs+ multithreading works but it's most likely close to the truth...
Myrsloik is offline
Old 11th August 2018, 12:07   #4202  |  Link
manolito
manolito's Avatar
Short question for the AVS+ gurus:
I am aware that the "Prefetch(x)" command should be called last in the AVS script (except for a "Return()" call). All commands after "Prefetch" will not be multithreaded.
Right now I am in the process to migrate to AVS+, and of course I want everything to be automatic. In my older 32-bit StaxRip installation I added a "Prefetch" command as the last call in the script for all my templates. But as soon as I edit out commercials in the preview, StaxRip automatically adds a "Trim()" statement as the last command (after the "Prefetch" call).
My question: Does it matter at all? Can "Trim()" even be prefetched? I did a few tests with "Trim()" before and after "Prefetch()", but the speed was identical, and the output also had no artifacts for both cases.
Cheers
manolito
manolito is offline
Old 11th August 2018, 12:57   #4203  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
In ripbot264 I do trimming after prefetch
#MT
#VideoSource
#Deinterlace
#Decimate
#Crop
#Resize
#Tonemap
#Levels
#Colours
#Denoise
#Custom
#Prefetch
#Subtitles
#AudioSource
#Triming
#ColorSpace
#Return
Atak_Snajpera is offline
Old 11th August 2018, 14:04   #4204  |  Link
LigH
LigH's Avatar
Trim() is applied once to the whole clip, therefore it cannot be parallelized frame by frame. Practically, it will probably just set a "first output frame" and a "last output frame" attribute; done.
New German Gleitz board
LigH is offline
Old 11th August 2018, 19:39   #4205  |  Link
sausuke
Hello, I'm back again. I just want to say thanks again especially to Groucho2004 for his AviSynth installer and AVS meter. I'm the one who has Threadripper processor. Last February I believe I fixed my problem (low fps etc). Got 70fps (happy with that to be honest). But I've decided to reformat last 2 days and my FPS is back to 50fps. I did some googling and came to this forum again and fixed my problem.
I'm using old AviSynth+ version though. The latest versions have low fps too
Btw why the CPU Usage is always 0. The thread ripper is default and no overclock. This is the first time that the AviSynth script gives real FPS from the avsmeter (100+ fps in software too) unlike from my previous posts wherein avsmeter report 100 fps (70 fps in the same software). Thanks again
sausuke is offline
Old 11th August 2018, 19:46   #4206  |  Link
Groucho2004
1. Post the script that gives you 0% CPU usage.
2. Update AVSMeter to the latest version, run "AVSMeter avsinfo -log" and post the log file.
What is the CPU usage in Task manager when you run the test?
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 11th August 2018, 20:03   #4207  |  Link
sausuke
Script
MP_Pipeline("""
### platform: win32
AVISource("E:\2Encoded Files\sss.avi", audio=false)
ConvertToYV12(matrix="PC.709")
I updated it to the latest v2.8.1
Here's the cpu usage
Log:
https://pastebin.com/pLZiYyCd
sausuke is offline
Old 11th August 2018, 20:10   #4208  |  Link
Groucho2004
MP_Pipeline("""
### platform: win32
MP_Pipeline runs the script in a different process, that's why you get 0% in AVSMeter. Open the "Processes" tab in Task Manager and check the CPU usage for each process.
Old 11th August 2018, 20:14   #4209  |  Link
sausuke
oh, I see, here's my top CPU usage while using avsmeter
sausuke is offline
Old 11th August 2018, 20:49   #4210  |  Link
LigH
LigH's Avatar
Vegas is very busy, why do you run it at the same time you try to benchmark AviSynth?
What kind of AVI do you read, is it completely uncompressed, so reading from the disk consumes most of the time?
LigH is offline
Old 11th August 2018, 21:19   #4211  |  Link
sausuke
I'm frameserving after I edit my videos. That's why my issue is complicated (for me). I'm not just converting a video (e.g video to handbrake).
I think I need to move on with the software to maximize threadripper. I'm just too attached with Vegas because I'm used to it. But the 100fps from 70fps is okay for me. I've tried other NLE but it's pain to setup with frameserver and the quality to size ratio is not good compare to x264.
sausuke is offline
Old 12th August 2018, 12:19   #4212  |  Link
Atak_Snajpera
I'm curious how many fps do you get while exporting using UT Video codec (YUV420) in Vegas?
Old 13th August 2018, 19:13   #4213  |  Link
Selur
Selur's Avatar
Is there some known problem with 'AviSynth+ 0.1 (r2728, MT, i386) (0.1.0.0)' and DeGrainMedian ?
I started with:
LoadPlugin("I:\Hybrid\32bit\avisynthPlugins\DGDecode.dll")
LoadPlugin("I:\Hybrid\32bit\avisynthPlugins\TDeint.dll")
LoadPlugin("I:\Hybrid\32bit\avisynthPlugins\TMM.dll")
LoadPlugin("I:\Hybrid\32bit\avisynthPlugins\MosquitoNR.dll")
LoadPlugin("I:\Hybrid\32bit\avisynthPlugins\RgTools.dll")
LoadPlugin("I:\Hybrid\32bit\avisynthPlugins\masktools2.dll")
LoadPlugin("I:\Hybrid\32bit\avisynthPlugins\degrainmedian.dll")
Import("I:\Hybrid\32bit\avisynthPlugins\Dehalo_alpha_mt.avsi")
SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE)
# loading source: VTS_01_1.VOB
#  input color sampling YV12
#  input luminance scale tv
MPEG2Source(d2v="E:\Temp\vob_3b6af15ddd3b19a201adf2536e9a8f23_41.d2v")
# current resolution: 720x576
# deinterlacing
TDeint(slow=2)
# cropping to 720x550
Crop(0,12,0,-14)
# current resolution: 720x550
# filtering
# deringing using MosquitoNR
MosquitoNR()
# dehaloing
DeHalo_alpha_mt()
# grain handling
DeGrainMedian(mode=2,norow=true)
# CUSTOM SCRIPT PART - position: Resize - START
function CustomResize(clip clp) {
  last=clp
  DeGrainMedian(limitY=3,limitUV=5,mode=2,norow=true)
# CUSTOM SCRIPT PART - position: Resize - END
CustomResize() # loading custom script content
# scaling
Spline36Resize(720,384)
# current resolution: 720x384
PreFetch(8)
return last
and when AVSMeter crashed and reported:
Exception 0xC0000005 [STATUS_ACCESS_VIOLATION]
Module:   C:\Windows\SysWOW64\KERNELBASE.dll
Address:  0x76C7DDC2
commenting out 'CustomResize', I tried with:
# deinterlacing
TDeint(slow=2)
Crop(0,12,0,-14)
# filtering
MosquitoNR()
# dehaloing
DeHalo_alpha_mt()
# grain handling
  last=clp
#CustomResize() # loading custom script content
# scaling
PreFetch(8)
return last
and I got the same crash, but once I also commented the other DeGrainMedian call out too and tried:
# deinterlacing
TDeint(slow=2)
Crop(0,12,0,-14)
# filtering
MosquitoNR()
# dehaloing
DeHalo_alpha_mt()
# grain handling
#DeGrainMedian(mode=2,norow=true)
  last=clp
# scaling
PreFetch(8)
return last
the script isn't crashing anymore.
Memory usage is around 220MB all the time.
So I'm wondering:
a. is there a newer verison of degrainMedian ? (using v0.8.2 from 2006 atm.)
b. is this a known problem?
c. is there a fix for this?
Cu Selur
Ps.: The script itself works fine with normal Avisynth MT 32bit. (minus the Prefetch and SetFilterMTMode call and adding distributor(), SetMTMode(),..)
Selur is offline
Old 13th August 2018, 23:27   #4214  |  Link
Groucho2004
Originally Posted by Selur View Post
So I'm wondering:
a. I'm not aware of a newer version
b. I can reproduce the problem. It may be that many of the inline ASM MMX functions in DeGrainMedian are missing the EMMS instruction. See here for some info.
c. I made a new build with the EMMS instructions included, let me know if it works for you (it does for me).
Old 13th August 2018, 23:38   #4215  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Is this thread a good place to mention errors on the Wiki? I spotted this:
If the input clip is field-based, the DoubleWeave filter operates like Weave, except that it produces double the number of frames: instead of combining fields 0 and 1 into frame 0, fields 2 and 3 into frame 1, and so on, it combines fields 0 and 1 into frame 0, fields 1 and 2 into frame 1, and so on. It does not change the [...] frame count.
http://avisynth.nl/index.php/DoubleWeave
wonkey_monkey is offline
Old 13th August 2018, 23:43   #4216  |  Link
Groucho2004
Probably the worst place.
If it's not too much hassle, why don't you create an account on avisynth.nl and fix it yourself? That's what I do (and many others) when I spot a mistake.
Old 14th August 2018, 00:03   #4217  |  Link
wonkey_monkey
Oh! I automatically assumed it wasn't open to registrations for some reason.
Old 14th August 2018, 04:33   #4218  |  Link
Selur
Selur's Avatar
@Groucho2004: Thanks! Did a quick test and it seems to fix the problem, will do some more testing and report in case I run into problems.
Selur is offline
Old 15th August 2018, 16:15   #4219  |  Link
manolito
manolito's Avatar
Another (probably stupid) question from an AVS+ noob:
If MT is enabled by the "Prefetch(x)" command at the end of the script then all of the plugins before the Prefetch command will run in MT mode. Which of the 4 different MT modes gets used is specified by an explicit SetFilterMTMode() command or by a "SetMTMode.avsi" in the autoload folder. If none of the MT modes is specified then the default MT mode 2 (MT_MULTI_INSTANCE) will be used. Everybody agrees on this?
Now I found this about ColorMatrix as a comment in the current "SetMTMode.avsi":
#note2: tried multiple files, seems to corrupt video even when it is the only filter in a script.
#tried mode 1, 2, and 3, none worked. however it works fine if MT isn't enabled.
So I would like to tell AVS+ to use ColorMatrix in "Single Threaded" mode while I still have a "Prefetch(x)" command at the end of the script. How would I do this? Is there any SetFilterMTMode() command which forces ST mode for a specified filter?
Cheers
manolito
manolito is offline
Old 15th August 2018, 17:17   #4220  |  Link
videoh
Useful n00b
E.g.:
SetFilterMTMode("FFVideoSource", MT_SERIALIZED)
videoh is offline
