4th July 2005, 08:39 | #1 | Link |
DVD Shrink Problem
I come back to the old "out of memory" question.
I am trying to burn a movie I created with DVDStyler (=DVDauthor). Because the movie will not fit on a DVD I am trying to use DVD Shrink to compress it slightly. DVD shrink opens the DVD ISO I created with no trouble, and peroforms the initial analysis. However, when I press the Analysis button, I get the message "out of memory The parameter is incorrect". This is an immediate response, and no processing was performed. I have 512 MB memory and enough space on my HD. I am using XP. I also tried this on a very small piece of video (68 MB) that I made into a DVD using the same process. So, this is not really a memory (or resources) problem. I had no luck with mock striping. Anybody tried this before? Any luck? Assistance would be much appreciated (e.g. if people are using a different process to shrink movies they authored to fit onto a DVD). Thanks, Gideon. Last edited by gideon_friedmann; 4th July 2005 at 10:04. Reason: Not to offend the community with downloaded files (legal) |
4th July 2005, 09:38 | #2 | Link |
Member
Hm... I smell problems of downloaded material. Whatever it is, legal or not, better read this announcement.
Greetings! |
4th July 2005, 10:02 | #3 | Link |
Everything Is Legal
1) All my actions are legal. I recorded a TV program for my personal use and would like to save it to DVD. This is completely equivalent to recording a TV program to VCR video.
2) The question applies in the same way to movies I created with my DV camera. 3) I adjusted the original posting as to not offend the community with legal downloaded material. Last edited by gideon_friedmann; 4th July 2005 at 10:06. |
4th July 2005, 10:17 | #4 | Link |
Member
Well, I'm not a moderator and certainly it's not in my hands to decide if that is right or not... I just wanted to inform you before you get into troubles.
However, you are trying to make the analysis directly from the ISO file, is that right? I'd try to do it from the files, and see what happen. Greetings! |
4th July 2005, 22:15 | #5 | Link |
I have just used DVDFab to backup the movie "CLOSER" to my HDD but when I tried to burn it using DVD Shrink I get the error "DVD Shrink can't continue, Out of Memory, Not enough Storage" Can anyone help me to fix this? or is there any other Prog that will let me do this?
5th July 2005, 07:41 | #6 | Link |
Check the error messages section of the DVD Shrink FAQ/Knowledgebase.
MultiMakeMKV: MakeMKV batch processing (Win) MultiShrink: DVD Shrink batch processing Offizieller Übersetzer von DVD Shrink deutsch |
5th July 2005, 15:17 | #7 | Link |
Chetwood. You have a friend for life.
I have no idea who you are but you have just prevented me from going insane! Thank you so much. I am no stranger to using DVDD or Shrink but let me tell you that this new Arccos had me driven mad. Even more so because I could get the movie to my HDD but no further. (Along came CHETWOOD)
As I am really a Newbie to all of this I found it A bit difficult to follow some of the instructions I was being pointed towards and was just about to give into my inability and give up when I received your post (what a lifeline). So I could not believe it when I saw the option to use Magic DVD Ripper and thought I had it cracked but really hit a downer when I discovered Shrink would not read the Video_VTS file either (I really thought it was a no go at that stage) Thin I spotted from your direction the Prog called IFO Edit so I decided to give it one more try, and guess what Chetwood? IT WORKED PERFECTLY! I very much hope we get to communicate again as my appetite for all of this is really growing. It was such a satisfying feeling to have achieved the successful burn. I guess "There's no gain without pain" Thank you again. |
5th July 2005, 17:42 | #8 | Link |
No biggy. I'm just trying to make ppl check the right places first. We've taken a lot of time to assemble all this info on the DVD Shrink forums so in most cases the answers are already there.
5th July 2005, 19:05 | #9 | Link |
Unadvanced Newbie
There is also a beta version of Magic DVD Ripper that solves the problem with the .VOB file problem in DVD Shrink. If you use that version - you don't need to use IFoEdit after the Magic rip - just open up the files in DVD Shrink.
http://forum.digital-digest.com/showthread.php?t=52051 |
7th July 2005, 01:20 | #10 | Link |
There is also a beta version?
Cynthia,
Where can I find a download link for the Beta version of MagicDVD Ripper? I looked at the link in your last post but it appears to be referring to specific movies only. OH! Thanks for your input on this |
29th July 2005, 02:13 | #14 | Link |
DVD Shrink problem
I have not had any problem DVD SHRINK but I am starting to have problems. I start the DVD shrink process and when it asked me to insert my blank disc it starts to burn and gets about 10 min. into burning and stops. I have thrown out DVD's that are half burned.
Help... Thanks YOYO Last edited by Yoyo; 29th July 2005 at 02:58. |
29th July 2005, 05:31 | #15 | Link |
Gold (Au) Member
DVD Shrink problem #2
YoYo, have you tried a different brand of media?
Did Shrink give you an error code? Check out the links above by Chetwood. Regards,
*********************************************************** Don't assume anything...Verify! It's as easy as 3.14159265 The Problem is Usually found between the Chair and the Keyboard! |
30th July 2005, 02:09 | #16 | Link |
Thanks FEEDBACK for your help.
Below is the error message I am reciving. It say this is a burn error....It starts to burn the DVD and it stops I am using DVD-R. I have burnt about 75 DVD's with this software and this media. ----------------------------------------------------------------------------- 1A22-0206-0530-1610-5715-1441* Windows XP 5.1 IA32 WinAspi: File 'Wnaspi32.dll': Ver=1, 0, 0, 0, size=36864 bytes, created 12/7/2000 7:00:00 AM ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/22/2004 6:33:44 PM Nero API version: 6.3.1.19 Using interface version: 6.3.1.4 Installed in: C:\Program Files\Ahead\Nero\ Application: ahead\Nero - Burning Rom Recorder: <SONY DVD RW DRU-710A> Version: BY03 - HA 1 TA 0 - 6.3.1.19 Adapter driver: <atapi> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI === Scsi-Device-Map === DiskPeripheral : MAXTOR 6L080J4 atapi Port 0 ID 0 DMA: On DiskPeripheral : Maxtor 6Y200P0 atapi Port 0 ID 1 DMA: On CdRomPeripheral : SONY DVD RW DRU-710A atapi Port 1 ID 0 DMA: On CdRomPeripheral : LITE-ON LTR-24102B atapi Port 1 ID 1 DMA: On === CDRom-Device-Map === SONY DVD RW DRU-710A D: CDRom0 LITE-ON LTR-24102B E: CDRom1 ======================= AutoRun : 0 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 511MB (523568kB) Free physical memory: 111MB (114380kB) Memory in use : 78 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 29.7.2005 NeroAPI 8:55:54 PM #1 Phase 112 File APIProgress.cpp, Line 273 DVD-Video files reallocation started 8:55:54 PM #2 Phase 114 File APIProgress.cpp, Line 273 DVD-Video files reallocation completed (no file modified) 8:55:54 PM #3 Phase 111 File APIProgress.cpp, Line 273 DVD-Video files sorted 8:55:54 PM #4 Text 0 File Reader.cpp, Line 118 Reader running 8:55:54 PM #5 Text 0 File AudioCompilationImpl.cpp, Line 817 DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1) DRM: Beginning burn process. 8:55:54 PM #6 Text 0 File Writer.cpp, Line 124 Writer SONY DVD RW DRU-710A running 8:55:54 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3899 First writeable address = 0 (0x00000000) 8:55:54 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3899 First writeable address = 0 (0x00000000) 8:55:55 PM #9 Text 0 File Burncd.cpp, Line 3173 Turn on Disc-At-Once, using DVD media 8:56:24 PM #10 Text 0 File DlgWaitCD.cpp, Line 247 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 1882079 (418:14.29, 3675MB) 8:56:24 PM #11 Text 0 File DlgWaitCD.cpp, Line 259 Write in overburning mode: NO 8:56:24 PM #12 Text 0 File DlgWaitCD.cpp, Line 2162 Recorder: SONY DVD RW DRU-710A, Media type: DVD-R Disc Manufacturer: CMC MA - G. AE1 Disc Application Code: 64, Disc Physical Code: 193 8:56:24 PM #13 Text 0 File DlgWaitCD.cpp, Line 420 >>> Protocol of DlgWaitCD activities: <<< ========================================= Disc not writeable. Insert writeable disc. (Medium in drive: unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW, DVD+R9 Double Layer.) 8:56:24 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 1882080 (1882080) = #1882080/418:14.30 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1882080 blocks [SONY DVD RW DRU-710A ] -------------------------------------------------------------- 8:56:24 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 984 Prepare recorder [SONY DVD RW DRU-710A ] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3854499840, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ 0 | lead-in | 0 | 0x00 | 0x41 0 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 1882080 | lead-out | 1 | 0x00 | 0x41 8:56:25 PM #16 Phase 24 File APIProgress.cpp, Line 273 Caching of files started 8:56:25 PM #17 Text 0 File Burncd.cpp, Line 4183 Cache writing successful. 8:56:25 PM #18 Phase 25 File APIProgress.cpp, Line 273 Caching of files completed 8:56:25 PM #19 Phase 36 File APIProgress.cpp, Line 273 Burn process started at 8x (11,080 KB/s) 8:56:25 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2344 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 8:56:26 PM #21 Text 0 File DVDR.cpp, Line 1932 Recording mode: Sequential Recording Mode 8:56:26 PM #22 Text 0 File Mmc.cpp, Line 20464 Set BUFE: Power-Burn -> ON , Generic write control : ON 8:56:26 PM #23 Text 0 File DVDR.cpp, Line 2073 Start write address at LBA 0 DVD high compatibility mode: Yes 8:56:26 PM #24 Text 0 File Cdrdrv.cpp, Line 8128 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 5 Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 0 h End Sector Number in Layer 0: 0 h Data in Burst Cutting Area (BCA) does not exist Start sector number of the current Border-Out: 0 h Start sector number of the next Border-In: 0 h Media Specific [16..63]: 00 30 00 10 20 00 00 00 - 00 00 00 21 00 00 00 00 .0.........!.... 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 8:56:26 PM #25 Text 0 File DVDR.cpp, Line 4817 Drive: SONY DVD RW DRU-710A Book Type request: DVD-ROM Changing the book type was finished with error code: 0 8:56:52 PM #26 Text 0 File Cdrdrv.cpp, Line 1294 20:56:52.525 - SONY DVD RW DRU-710A\H1 T0 : Queue again later 9:00:00 PM #27 SCSI -1046 File Cdrdrv.cpp, Line 1442 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x00CA0000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x2A 0x00 0x00 0x00 0x11 0x60 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x30 0x05 9:00:00 PM #28 CDR -1046 File Writer.cpp, Line 304 Illegal disc 9:00:00 PM #29 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 9:00:00 PM #30 Text 0 File ThreadedTransfer.cpp, Line 223 conversion idle, stopping reader 9:00:00 PM #31 Text 0 File DVDR.cpp, Line 2315 EndDAO: Last written address was 4447 9:00:00 PM #32 Phase 38 File APIProgress.cpp, Line 273 Burn process failed at 8x (11,080 KB/s) 9:00:00 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 828 DRM: DRM burn session terminated. 9:00:00 PM #34 Text 0 File AudioCompilationImpl.cpp, Line 857 DRM: Closing entire DRM handling. Bye. Existing drivers: File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 4:07:32 PM File 'Drivers\CDRALW2K.SYS': Ver=5.10 (103), size=22713 bytes, created 10/11/2001 12:53:06 PM File 'Drivers\PXHELP20.SYS': Ver=2.03.18a, size=20576 bytes, created 7/3/2005 11:26:41 AM (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) |
30th July 2005, 07:26 | #17 | Link | ||
Gold (Au) Member
They outsource to other companies. TDK uses CMC Magnetics, Ty Yuden, and of course their own TDK at this time. They may change to other manufacturers in the future. Use this free tool DVD Identifier Here to determine a disk that will work for you. Regards, P.S. You may want to update your burner firmware.
31st July 2005, 00:23 | #18 | Link |
DVD Shrink problem
Thanks FEEDBACK for all your help and good info. I have a bad drive. I am using a Sony DVD drive and I went to there web site and saw a DVD drive checker. It did find a problem and I also called Sony's support. They said it sounds like a bad drive. The drive is only 3 months old. I guess I have been burning alot......anyway Sony said they will replace the drive...
I hope this fixes my problem I realy like DVDshrink... Again thanks, YOYO |
31st July 2005, 02:02 | #19 | Link |
Gold (Au) Member
il n'y a pas de quoi
Regards,
