26th September 2001, 13:21 | #1 | Link |
Posts: n/a
*** Very Small FAQ ***
Q: Where Can I download a new firmware to make my player region free ? A: www.firmware.fr.st Q: Do you have a link for the same thing but for Standalone player ? A: www.dvd-area.com or (french) www.dvdalliance.net Help me to update this FAQ plz =) |
28th September 2001, 05:37 | #2 | Link |
Posts: n/a
thought I updated this list the other day, must have been a server blip. I'll update again. Q: Can I play Divx on my Hollywood+ or Creative DXR3? A: Download Divx+ software on Download page and make sure you have current H+ drivers. Q: Why wont Divx+ work for me? A: Try opening Divx+ then Real Magic DVD player and choose adjust borders. Then try again... and again. Don't even bother trying if you have WinXP. Check news://news.sigmadesigns.com Q: Do I have to use the Real Magic DVD player with my Hollywood+ card? A: No, the only alternative available is called Eugene's DVD player found on the Download page. Q: Can I disable macrovision and/or region check on my Hollywood+? A: Yes, with Eugene's DVD player. edit: fixed the url, fixed it right |
3rd January 2002, 07:31 | #5 | Link |
drivers and software
Where do I get the latest Hollywood Plus drivers?
here Where do I get Creative PC-DVD ROM? here Where is Eugene's page? here Where can I find Divx+ player? here Last edited by macdaddy; 12th January 2002 at 23:41. |
22nd January 2002, 19:38 | #6 | Link |
New Options
You now have new options if you are a Hollywood+ owner.
Q: What is the most advanced way to play DVD's using my Hollywood+? A: Currenty Zoomplayer and the new H+ Directshow filter allows the most feature rich DVD Playback. Check here for more info. Q: What about playing AVI's with AC3 audio using my H+? A: This is now also possible using Zoomplayer and new directshow filters. Check here for more info. Q: Can my H+ output AC3 from avi's using above methods? A: Not yet but hopefully in the future. But you shouldn't worry if you have a digital output capable soundcard. Read macdaddy's method here. (ps: thanks macdad, jake... oh and blight!)
ChapterGrabber - add names to your chapters | AtomSite - open source AtomPub server Last edited by Emp3r0r; 23rd January 2002 at 17:44. |
24th January 2002, 03:55 | #7 | Link |
This info if fantastic...
Thanks for all the above...this goes a long way in helping me figure out how to play divx's on my (yet-to-be) new home theatre system.
With all this development on the Hollywood plus card, perhaps it's a must-have to output into my receiver....that remote looks mighty good though <grin>... Question I have is, should I get a separate 5.1 receiver or an all-in-one DVD player/5.1 receiver. (Thinking of the Sony DAV500 system). Comments? |
3rd May 2002, 20:24 | #8 | Link |
Seperate Components
I would definately use seperate components. Spend the extra money to get yourself what you really want!!!
Seperate components will always output BETTER than integrated. And when I say seperate I mean down to a seperate tuner for your amp. Not an amp with a built in tuner... Hope that this helps Mrafrohead
Gaww-DAMN - What's that SMELL??? |
30th November 2004, 18:16 | #9 | Link |
www.dvd-area.com doesn't work any more - are there any more sites like this?
4th June 2006, 12:24 | #10 | Link |
can any one tell me why recorded tv programs to disk on my sony RDR HX900 dvd recorder will not play on my pc or any other dvd player they never reconise the disk, i know the disks are ok. is there any software out there that can help. thanks
4th June 2006, 17:14 | #11 | Link |
Custom User Title
You may want to contact a forum moderator to request having this question moved to the proper forum in its own thread. You've not only posted it in a section completely unrelated to your problem, you've done so within a "sticky," and chances of anyone with helpful knowledge of seeing it here are almost nil.
