Old 2nd May 2023, 14:07   #1  |  Link
drunksunk
How to export videos
After you applied all your filters to a video, how do you export it?
drunksunk is offline   Reply With Quote
Old 2nd May 2023, 15:20   #2  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
I wrote to you that it's called "encode" and that you should ask "how to encode avs scripts".
VoodooFX is offline   Reply With Quote
Old 2nd May 2023, 17:03   #3  |  Link
coolgit
To which country?
Do you want to compress the your video using x265 or what?
Which software are you using?
coolgit is offline   Reply With Quote
Old 2nd May 2023, 17:30   #4  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
I use mostly MeGUI but that probably would be overcomplicated for him.
Does anyone know some very simple FFmpeg GUI?
Old 2nd May 2023, 18:16   #5  |  Link
drunksunk
Originally Posted by coolgit View Post
To which country?
Need classic x264 mp4 file as output, possibly keeping the same bitrate of the original video.
Old 2nd May 2023, 20:34   #6  |  Link
coolgit
Whatever software you use just click on save then choose x264 and type in bitrate.
Old 3rd May 2023, 01:26   #7  |  Link
kedautinh12
I think Megui is very simple than other
Old 3rd May 2023, 09:22   #8  |  Link
drunksunk
Where do you see this save button?
Old 3rd May 2023, 10:58   #9  |  Link
videoFred
videoFred's Avatar
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
Load your script in VirtualDub and hit F7
Fred.
About 8mm film:
http://www.super-8.be
Film Transfer Tutorial and example clips:
https://www.youtube.com/watch?v=W4QBsWXKuV8
More Example clips:
http://www.vimeo.com/user678523/videos/sort:newest
videoFred is offline   Reply With Quote
Old 3rd May 2023, 19:34   #10  |  Link
drunksunk
Fred.
it only asks for avi format, so i have to do a second encoding later.
Old 3rd May 2023, 19:50   #11  |  Link
drunksunk
I just created a 100GB file out of a 300MB file and can't even reproduce it because it's too heavy. So yeah, this avi thing won't work. Not sure if you can actually ingest an avisynth script into ffmpeg.
Old 3rd May 2023, 20:52   #12  |  Link
poisondeathray
Yes you can . Most public distributed ffmpeg binaries are compiled with avisynth support
Old 3rd May 2023, 21:03   #13  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
This program is first result from Google: clever FFmpeg-GUI
I guess that's because you didn't selected any encoder so VDub saved it uncompressed.
EDIt:
Btw, you can encode directly from AvsPmod but you need to know FFmpeg commands.
Old 3rd May 2023, 23:25   #14  |  Link
drunksunk
EDIt:
how to encode directly from AvsPmod? i was generally using the -c copy thing to have mp4 file in same quality as source. even if I were using the GUI, it would maybe be harder since i have no clue how you can pass an avisynth script as an input of an exe.
So i think just knowing how to run a ffmpeg command inside an avs script would be better. i don't need any fancy options, just encode h264 and dump into mp4 container and i'm done. worst case juse use CBR of 22k like the original video and call it a day so command shouldn't be hard.
Old 4th May 2023, 00:02   #15  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
That's not how video editing works, you can copy only non-edited video. Edited video you need to encode.
This is nonsense.
Use FFmpeg GUI I posted.
Old 4th May 2023, 02:11   #16  |  Link
drunksunk
This is nonsense.
FFmpeg GUI asks for a source video file, you can't pass an avs script as an input to my knowledge.
Old 4th May 2023, 10:20   #17  |  Link
lollo2
lollo2's Avatar
If you are familiar with a command line, you can simply open a command shell and type:
ffmpeg.exe -i <input>.avs -c:v libx264 -crf 17 -preset slow -aspect 4:3 -c:a aac -b:a 128k <output>.mp4
A channel on S-VHS / VHS capture and AviSynth restoration https://www.youtube.com/channel/UCMs...h1MmNAs7I8nu4g
lollo2 is offline   Reply With Quote
Old 4th May 2023, 14:37   #18  |  Link
drunksunk
This worked aside from the sound that didn't get exported somehow, but I can add it back manually without any issues.
Old 4th May 2023, 16:52   #19  |  Link
lollo2
lollo2's Avatar
Strange. The audio in the source file to the AviSynth script, if not wrongly processed, should be propagated to aac encoder by ffmpeg, and then written in the .mp4 output.
Could you post please your AviSynth script?
Old 12th May 2023, 00:21   #20  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
You don't need to add audio to avs scripts if you don't edit audio or change timeline of video.
Just mux it in with mkvtoolnix or other tool.
