17th March 2023, 16:31 | #3 | Link |
17th March 2023, 19:40 | #4 | Link | |
SuperVirus
Well, some years ago I told someone @ Videohelp to get in touch with Maxim Anisiutkin... and apparently Maxim found a way to decrypt+decode the contents of a Cinema-DTS disc. https://forum.videohelp.com/threads/...s-%5BSOLVED%5D TL;DR just go to the last post in that thread :-|
«Your software patents have expired.» |
18th March 2023, 11:54 | #6 | Link |
If the decoded audio (now in PCM samples) is not in sync with video from BD, the procedure is the same no mather the source is dtsc or any: use a audio editor like Audacity or equivalent.
And after recode to a format more compatible with players.
18th March 2023, 16:51 | #7 | Link |
SuperVirus
I wish that there existed a software APT-X encoder.
Muxing APT-X streams into the AVI container would be trivial, but Matroska support would depend on Mosu's interest, of course.
18th March 2023, 23:12 | #8 | Link |
IIRC you can encode in APT-X100 using the same FooBar plugin that decodes it... but, what's the point? Unless you are producing DTS CD-ROM to use in theaters - and, in that case, you will also need to produce the DTS.EXE file with syncs etc.
18th March 2023, 23:36 | #9 | Link | ||
SuperVirus
According to the changelog: Code:
11/22/2019: Version 0.1.6 - *.AUD file encoder added. Quote:
It should work straightforward with NON-encrypted streams, at least.
19th March 2023, 12:40 | #10 | Link | |
If you're thinking OMG!!! I'm listening to the original Cinema DTS audio this is what that creators intended!!!111!! there are some issues with that. 1. The bitrate of Cinema DTS is low 882kps that I wouldn't be surprised if DD 448kps beats it since AC3 is based on the more efficient MDCT, not ADPCM. Also, it requires a bunch of processing until it's in the correct "consumable" state. 2. The home environment is different to the cinema environment, the Acoustics are different due to factors like bass buildup. There is usually a dedicated home theatre mix created which is QC'd & approved for home listening environments, and bass buildup etc is compensated. Conclusion: Unless the Cinema mix is significantly different, I would recommend listening to the consumer Mix as it's HQ and optimised for the home environment. Case study: The Matrix. I've discussed with someone on AVS forums, comparing Dolby Atmos vs previous DD/THD vs the cinema DTS mix. In addition to being higher quality/bitrate, the Dolby Atmos mix is closer to the cinema DTS mix then the previous mixes. How can this be true? They probably went back to the original ProTools project and reworked it for Dolby Atmos. |
20th March 2023, 08:47 | #11 | Link |
I'm well aware of what you wrote, still...
1) the APT-X100 used ADPCM divided in four bands; compared to the original, the only downside is more noise - at the contrary of different problems of other psychoacoustic codecs; now, it may be true that DD 448kbps sounds better, but Cinema DTS sounds good, and sounded better than theatrical DD 320kbps IMHO. 2) true; but a simple "Cinema EQ" setting on an HT amplifier (if present, of course) resolves the problem. Speaking of which - and adding The Matrix CDTS as a bonus: https://forums.audioholics.com/forum...zation.124985/ |
cinema dts, datasat, dts 6-track, dts disc, theatrical dts |
