Old 15th July 2022, 01:03   #1  |  Link
RocketJet
RocketJet's Avatar
REQ: VirtualDub2 - beep at end of processing.
When saving a video in VirtualDub2, or saving a large range of frame images, I like to use other apps in the foreground, with VD2 running in the background.
It would be great to have VD2 beep when it finishes a long winded process, such as those I mentioned.
It would not need anything fancy, a MessageBeep would be sufficient.
RocketJet is offline   Reply With Quote
Old 19th July 2022, 16:36   #2  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Have you looked into AutoHotkey? You could probably write a simple script to do it - wait for the processing window to appear, then beep when it disappears.
wonkey_monkey is offline   Reply With Quote
