Old 24th May 2023, 22:44   #561  |  Link
GHOSTWRiTAZ
GHOSTWRiTAZ's Avatar
Originally Posted by SeeMoreDigital View Post
Out of interest...
Which 100GB (triple layer BDXL) 4K UHD disc movies do you have?
List of 4K UHDs BD-100 Link
GHOSTWRiTAZ is offline   Reply With Quote
Old 24th May 2023, 22:46   #562  |  Link
GHOSTWRiTAZ
Originally Posted by dawid1991 View Post
Does anyone know if there is any bluray player 4k that plays 100gb r/rw discs?
Panasonic DP-UB9000/UB9004
Oppo UDP-203/205
Magnetar UDP800 (a.k.a. Oppo clones)
Reavon UBR-X100/X200 (a.k.a. Oppo clones)
Old 24th May 2023, 23:47   #563  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Oppo UDP-203/205: Can not confirm. I tried and had no success.
But I will repeat that sooner or later.
Old 25th May 2023, 04:58   #564  |  Link
TDS
Formally known as .......
TDS's Avatar
Originally Posted by GodzilaAvenger View Post
Triggering DV also depends on the playback device and video container. For example if I remember correctly DV playback on an LG TV's internal media player using .mkv is not possible and it has to be .mp4.
Thanks for that info, I had read somewhere that mkv didn't carry it..
The app I used to encode only output's x265 as an .mkv , I might have to run it thru DDVT to convert to mp4. Is there another way ??
Interesting side note, the couple of DV test samples I downloaded for an LG TV, where .ts files...(they display the Dolby Vision banner).
Cheers
Long term RipBot264 user.
RipBot264 modded builds..
TDS is offline   Reply With Quote
Old 25th May 2023, 05:29   #565  |  Link
GodzilaAvenger
GodzilaAvenger's Avatar
DDVT_MKVTOMP4 is probably your best bet, it uses FFmpeg under the hood but is a lot more intuitive.
GodzilaAvenger is offline   Reply With Quote
Old 25th May 2023, 05:40   #566  |  Link
GodzilaAvenger
hi how to convert dolby vision to hdr10+? i have a samsung and i would really need it?
Since DV is proprietary there is currently no (free) way of doing this.
I don't condone piracy but if you have bought a DV Blu-ray, especially if it's of a newer film, you can probably find a WEB-DL release of that film with HDR10+ metadata (look at the MediaInfo). Demux that metadata from the WEB-DL source and inject it into the Blu-ray file, just make sure the metadata frame numbers are aligned with the film (they're usually not, you have to look at the scene cut frame numbers and their corresponding value in the metadata to figure out how much (positive or negative) delay to use).
Old 25th May 2023, 07:20   #567  |  Link
TDS
TDS's Avatar
I will definitely give that a try, once I've done a bit more homework with the actual encoding side of things..got lots of different settings to try
Old 25th May 2023, 08:20   #568  |  Link
dawid1991
on my ub9000 too no support bd xl...
dawid1991 is offline   Reply With Quote
Old 25th May 2023, 21:18   #569  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Originally Posted by Arkana View Post
Hello, I have hundreds of DV video that need double checked for possibly wrong crop values. Some of them have correct values but many of them are wrong. Is there anything I can do to fix this and saving the time?
Simply use DDVT_DEMUXER. If you open a DV P8 with the Demuxer, you have a "CHECK RELEASE" option. With this option you can fix bad borders.
[spoiler]
[/spoiler]
-QfG- is offline   Reply With Quote
Old 26th May 2023, 06:07   #570  |  Link
TDS
TDS's Avatar
@ -QfG-,
As the risk of repeating myself (from back on the RipBot thread),
here
and this thread:-
and here
I have a few "Hybrid" DV clips that will not play via USB on my LG TV, and 1 clip that does.
See examples (MediaInfo info)
John Wick (mkv)
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 49 min
Bit rate : 23.7 Mb/s
Width : 3 828 pixels
Height : 1 592 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.162
Stream size : 28.1 GiB (95%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 2458 cd/m2
Maximum Frame-Average Light Level : 636 cd/m2
The Lord of the Rings.The Rings of Power (mkv)
Video
Format : HEVC
Format profile : Main 10@L5@Main
Duration : 1 h 5 min
Bit rate : 3 231 kb/s
Width : 3 840 pixels
Height : 1 600 pixels
Frame rate : 24.000 FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.022
Stream size : 1.48 GiB (94%)
Language : English
Default : Yes
Forced : No
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 173 cd/m2
Maximum Frame-Average Light Level : 171 cd/m2
The Old Guard (mkv)
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Duration : 2 h 5 min
Bit rate : 15.1 Mb/s
Height : 2 160 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.076
Stream size : 13.3 GiB (93%)
Default : Yes
Forced : No
Maximum Content Light Level : 738 cd/m2
Maximum Frame-Average Light Level : 287 cd/m2
LG Dolby Vision test sample (.ts format)
Video
Menu ID : 2 (0x2)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU
Codec ID : 36
Duration : 1 min 19 s
Bit rate : 29.6 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.149
Stream size : 282 MiB (92%)
So if you can't guess which one is the clip's plays & displays the Dolby Vision logo in the top right corner of the screen, it's the bottom one.
Surely there has to be a way to "transform" this :-
which falls back to HDR10 on playback.
to this, which DOES display Dolby Vision on playback :-
If DDVT could remove that HDR10 compatibility "function", I think the job's done
What do you think, is that something that could be done ??
Apologies if this has been explained before
Old 26th May 2023, 08:21   #571  |  Link
GodzilaAvenger
I don't know why I have to repeat this but .mkv files don't trigger Dolby Vision on LG TVs, but .mp4, .ts, and .m2ts do. Converting the Rings of Power file to .mp4 will only take minutes even on a laptop (don't pirate BTW). It almost certainly has nothing to do with the DV profile or HDR10 backwards compatibility.
I look forward to -QfG-'s response, but as far as I know, the answer is no. In dovi_tool (which is the backbone of DDVT) conversion to Profile 4 is not possible. I encourage you to read up on HDR10 and Dolby Vision Profiles and Levels, that should clarify a lot of things.
Old 26th May 2023, 09:43   #572  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
It really is like banging your head against a brick wall
Essentially, Matroska will need to develop an entirely new file parser to handle Dolby Vision.mkv muxes as the current parser (built into all our televisions and many other playback devices) doesn't understand them!
Old 26th May 2023, 09:48   #573  |  Link
TDS
TDS's Avatar
Well, you won't have to repeat yourself again (hopefully)
I am VERY, VERY new to this process, so don't be too harsh
I have learnt that LG's DO only work off the format's you mentioned, I have converted a couple of the "hybrid" types to .mp4, but instead of test playing them on the LG, I check the MediaInfo, and see the HDR Format is still unchanged, so I don't bother to go any further, and what confuses me more is the MediaInfo of the LG DV test file (despite it's low DV Profile).
So if I convert these .mkv's to .mp4 with DDVT, regardless of the HDR Format, if' it's .mp4 it should play & display the Dolby Vision logo on the LG TV...
I will definitely go that one more step after the conversion, to do a test play.
Thanks & sorry.
UPDATE
I just converted this one to .mp4 using DDVT, and guess what, it still plays in HDR10
John Wick (mkv)
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Language : English
Default : Yes
Forced : No
After conversion..
I think it might need to be changed to DV Profile 5...
SORTED, (see below)
Thanks for your help.
Old 26th May 2023, 09:53   #574  |  Link
TDS
TDS's Avatar
Don't you mean like this ....
Give me a break, I'm new at this DV stuff...
And what, you didn't have to keep asking "dumb" questions when you started your doom9 journey some 20 years ago ??
Old 26th May 2023, 12:10   #575  |  Link
Gabu
I have both an HDR and DV file. DV has more bitrate than HDR, but frames, length are the same, same source.
Can anyone tell me how to put the HDR metadata into the DV file with bigger bitrate to make a hybrid?
Gabu is offline   Reply With Quote
Old 26th May 2023, 15:24   #576  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Very exotic DV Profile. Recommended to convert this to profile 8 (BL+RPU) for maximum compatibility.
You cannot Change Profile 4/7/8 to Profile 5, because the BL Colorspace of P5 is BT.2100 and P8 BT.2020.
Remove HDR10+ Metadata with the remover. Some HDR10+ files dosn't work correctly (No Solution yet)
@TDS:
--level 6.2 --profile main10 --hdr10 --hdr-opt
Why using h265 level 6.2 instead of 5.1@High?
The line i used for UHD compatible Encodes is:
--crf 16 --preset veryslow --profile main10 --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --level-idc 5.1 --rd 6 --rd-refine --rdoq-level 1 --psy-rdoq 4 --psy-rd 2 --tu-intra 1 --tu-inter 1 --limit-tu 0 --sar 1 --aq-mode 1 --qcomp 0.7 --ref 4 --bframes 4 --selective-sao 0 --rskip 0 --no-open-gop --no-info --no-sao --no-rect --no-amp --hme-search umh,umh,star --hme --repeat-headers --aud --uhd-bd --min-keyint 1 --keyint 24 --hrd --vbv-bufsize 80000 --vbv-maxrate 90000 --hdr --output-depth 10 --hdr-opt
Old 26th May 2023, 15:31   #577  |  Link
TDS
TDS's Avatar
@TDS:
I just cracked it, I simply (after days of fiddling) used tsmuxer, remuxed to .m2ts file, and it's displaying Dolby Vision the LG TV.
Old 26th May 2023, 15:37   #578  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Nice that m2ts works correctly with HDR10+ Profile B Metadata. I know that any files with included HDR10+ metadata in mp4/mkv container will not work correctly.
But i never found out why, some files works other not.
Old 26th May 2023, 15:50   #579  |  Link
TDS
TDS's Avatar
Yes, I'm pretty happy that it worked...I just happened to stumble onto a thread ,(somewhere)..this guy said he'd tried everything, almost gave up, then tried good old tsmuxer......and he had an LG TV as well.
Is this something that could be incorporated into DDVT ?
Old 27th May 2023, 03:45   #580  |  Link
TDS
TDS's Avatar
So for my next stupid question(s)..
I'm sure this has been asked here or somewhere a LOT, but is there a way to convert HDR10 to HDR10+, and then use that "new" HDR10+ to create a Hybrid DV video ??
Also, are there any plans to have all the DDVT options as Drag 'n' Drop (like the new Hybrid option) ??, makes it SO much easier
Question about the Hybrid option, it asks for a HDR & DV file ???
What's that about ??
