Old 12th September 2020, 12:15   #241  |  Link
Selur
Selur's Avatar
Ah, okay I feared something like that.
Old 12th September 2020, 13:36   #242  |  Link
l33tmeatwad
l33tmeatwad's Avatar
Yeah, I wish I had the means to host this all with direct links. I've considered other free services too, but Google Drive has soft rolling bandwidth caps on the server side & Mega has bandwidth caps on the user side for their entire service. If anyone has any better ideas for sharing locations or would like to host just let me know.
Github | AviSynth 101 | VapourSynth 101
l33tmeatwad is offline   Reply With Quote
Old 12th September 2020, 14:34   #243  |  Link
shph
How about archive.org ? It provides direct links.
There is also direct links in Dropbox. Just replace "www" to "dl" and remove "?dl=1" in the end and you will get pure direct link to file. https://www.dropboxforum.com/t5/Drop...ile/td-p/91934
shph is offline   Reply With Quote
Old 12th September 2020, 15:19   #244  |  Link
l33tmeatwad
Archive.org is not a file sharing host and Dropbox does not provide enough free space to host everything.
Old 12th September 2020, 15:29   #245  |  Link
shph
3 GB on Dropbox is not enough? On my computer extracted plug-ins folder is about 70 MB. VapourSynth installer also about 75 MB. Or i miss some storage concept?
Old 12th September 2020, 15:31   #246  |  Link
l33tmeatwad
Between applications, installers, plugins, and source code I'm currently using more than 4GB. That is only going to increase with time.
Old 12th September 2020, 15:33   #247  |  Link
shph
There are a lot of ways to extend free space in Dropbox https://trendblog.net/get-free-dropbox-space/
Install Dropbox.app, get additional free space, delete app if you don't need it. And so on...
Old 12th September 2020, 15:34   #248  |  Link
l33tmeatwad
If you would like to mirror the plugins on Dropbox feel free to.
Old 12th September 2020, 15:43   #249  |  Link
shph
I mirror plugins in VapourSynth + QTGMC Deinterlace + Hybrid UI FAQ for macOS package https://forum.doom9.org/showthread.php?t=181299 It is more less always updated ans includes all filters from your Mediafire shares. Or is it some requirement for some tasks to download filters one by one from direct links?
Old 12th September 2020, 15:46   #250  |  Link
ChaosKing
I could host it on my server. But you could also put everything on github for free... and with macOS binaries on github, vsrepo could be extended with macos support. Maybe it already works in portable mode.
Old 12th September 2020, 17:04   #251  |  Link
l33tmeatwad
I haven't looked into the terms of service enough on GitHub, but I know for the most part it's expected that you're hosting the source project there. That said I don't feel like managing so many repositories, the ones already on GitHub are easier, but that's just a mess I haven't been interested in organizing up to this point. It would be nice to work with someone on maintaining everything.
Old 12th September 2020, 21:33   #252  |  Link
l33tmeatwad
Added the following:
AdaptiveGrain
AreaResize*
ASharp
Average
NoiseGenerator*
TBilateral
TemporalSoften2
Warpsharp Single Precision
*Crashes VapourSynth Editor when preview window is closed or refreshed.
Last edited by l33tmeatwad; 13th September 2020 at 02:26. Reason: Updated Information.
Old 13th September 2020, 14:09   #253  |  Link
shph
Seems AdaptiveGrain-0.3.1 archive contains some random files and folders instead of .dylib plug-in
Old 13th September 2020, 14:41   #254  |  Link
l33tmeatwad
I mean technically that is the plugin...but clearly I mixed up the source code and compiled compressed files. Files are now in their correct directory.
Old 13th September 2020, 15:29   #255  |  Link
shph
How about add description to the filters list about namespaces conflict and warning description at the bottom of the list about do not put filters with same namespace to autoload folder? Something like this:
EdgeFixer (uses ContinuityFixer namespace)
SangNomMod (uses SangNom namespace)
Focus (uses TemporalSoften namespace)
Also maybe add "8-bit only" warning to filters list?
I done bit depth filters tests in Hybrid here https://forum.doom9.org/showthread.p...87#post1922287
DeGrain -> MLDegrain
DeGrain -> TemporalDegrain
Artefacts -> DeCrawl -> DotKill (R1 and R2 versions)
Artefacts -> DeCrawl -> DeDot
Artefacts -> DeRainbow -> BiFrost
Artefacts -> DeRainbow -> SSIQ
Artefacts -> DeCross
Line -> AntiAliasing -> SangNomMod
Old 13th September 2020, 15:43   #256  |  Link
l33tmeatwad
Or, ya know, just download plugins you need instead of everything that exists. There is no need to have two different versions of the same thing, some of these I'm compiling partially for archival purposes.
Old 13th September 2020, 20:20   #257  |  Link
l33tmeatwad
Just added FFTSpectrum & VMAF, with these there are now 100 external plugins available for macOS! Other updates:
Currently Investigating:
Damb - Needs libsndfile which needs other dependancies.
SRMD - Need to test with AMD GPU.
vs-placebo - Needs libplacebo.
Plugins with Issues:
MVTools-Float - Needs C++20, not implamented in macOS yet.
tc2cfr - No Timecodes Work
Currently Windows Only:
DelogoHD
DGHDRtoSDR
DGMVSource
vcfreq
vcm
VSFilterMod
xy-VSFilter
Other:
bilateralgpu - Depreciated, use CuPy.
Old 14th September 2020, 13:06   #258  |  Link
AdamCarter
Selur needs these
got tools which are used in Hybrid which I can't update:
rav1e, used for AV1 encoding
mencoder/mplayer, used for DVD Input and the normal Preview
opusenc, used for opus audio encoding
oggenc2, used for ogg vorbis audio encoding
AdamCarter is offline   Reply With Quote
Old 14th September 2020, 14:45   #259  |  Link
l33tmeatwad
Originally Posted by AdamCarter View Post
Selur needs these
Please keep things on topic for VapourSynth support.
Old 14th September 2020, 17:45   #260  |  Link
AdamCarter
Hey don’t shoot the messenger. If this type of work Is too complicated we Can always Teach shph how to compile.
meatwadismagical, meatwadthegreat
