Go Back   Doom9's Forum > Announcements and Chat > News
Old 23rd January 2018, 15:11   #1  |  Link
sneaker_ger
"second" now replaced by new unit "flick".
https://github.com/OculusVR/Flicks
Flicks
Basics
A flick (frame-tick) is a very small unit of time. It is 1/705600000 of a second, exactly.
1 flick = 1/705600000 second
This unit of time is the smallest time unit which is LARGER than a nanosecond,
and can in integer quantities exactly represent a single frame duration for
24hz, 25hz, 30hz, 48hz, 50hz, 60hz, 90hz, 100hz, 120hz, and also 1/1000 divisions of each.
This makes it suitable for use via std::chrono::duration and std::ratio for doing timing work
against the system high resolution clock, which is in nanoseconds, but doesn't get slightly
out of sync when doing common frame rates.
In order to accomodate media playback, we also support some common audio sample rates
as well. This list is not exhaustive, but covers the majority of digital audio formats.
They are 8kHz, 16kHz, 22.05kHz, 24kHz, 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz, and 192kHz.
While humans can't hear higher than 48kHz, the higher sample rates are used for working
audio files which might later be resampled or retimed.
The NTSC variations (~29.97, etc) are actually defined as 24 * 1000/1001 and 30 * 1000/1001,
which are impossible to represent exactly in a way where 1 second is exact, so we don't
bother - they'll be inexact in any circumstance.
Details
  • 1/24 fps frame: 29400000 flicks
  • 1/25 fps frame: 28224000 flicks
  • 1/30 fps frame: 23520000 flicks
  • 1/48 fps frame: 14700000 flicks
  • 1/50 fps frame: 14112000 flicks
  • 1/60 fps frame: 11760000 flicks
  • 1/90 fps frame: 7840000 flicks
  • 1/100 fps frame: 7056000 flicks
  • 1/120 fps frame: 5880000 flicks
  • 1/8000 fps frame: 88200 flicks
  • 1/16000 fps frame: 44100 flicks
  • 1/22050 fps frame: 32000 flicks
  • 1/24000 fps frame: 29400 flicks
  • 1/32000 fps frame: 22050 flicks
  • 1/44100 fps frame: 16000 flicks
  • 1/48000 fps frame: 14700 flicks
  • 1/88200 fps frame: 8000 flicks
  • 1/96000 fps frame: 7350 flicks
  • 1/192000 fps frame: 3675 flicks
Motivation
When working creating visual effects for film, television, and other media, it is common
to run simulations or other time-integrating processes which subdivide a single frame of time
into a fixed, integer number of subdivisions. It is handy to be able to accumulate these
subdivisions to create exact 1-frame and 1-second intervals, for a variety of reasons.
Knowing that you should never, ever use floating point representations for accumulated,
simulated time (lest your temporal accuracy degrade over time), the std::chrono time tools
in C++ are ideal. However, the highest usable resolution, nanoseconds, doesn't evenly divide
common film & media framerates. This was the genesis of this unit.
Acknowledgements
This time unit began as a technical question posted publicly on Facebook by Christopher Horvath
in early 2017. Many people contributed and refined the unit, including Dan Goldman, Pascal Pincosy,
Simon Eves, Kearsley Higgins, Francisco De La Torre, Benjy Feen, Eric Landreneau and Sebastian Sylwan,
among others. Here's the post!
https://www.facebook.com/christopher...57292757692660
