Old 1st July 2018, 13:51   #61  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by SeeMoreDigital View Post
Perhaps I could try your samples?
Of course: https://www.sendspace.com/file/1aalin
Old 1st July 2018, 15:19   #62  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Many thanks...
EDIT: It would appear that the '768.dts -l -b 754.5' stream works fine. But for some reason the '1536.dts -l -b 1509.75' stream is garbled and crashes my OPPO
Old 2nd July 2018, 00:18   #63  |  Link
tebasuna51
tebasuna51's Avatar
Try this one: https://www.sendspace.com/file/uuj56b
Now encoded just at -b 1509 like the second, also 1509 but by DTS-HD Master Audio Suite.
Both work in my Yamaha
Old 2nd July 2018, 09:08   #64  |  Link
SeeMoreDigital
Morning,
The 'ffdcaenc stream' still sounds garbled and crashed/locked-up my Oppo.
By contrast, the 'DTS-HD Master Audio Suite' stream played perfectly!
Old 2nd July 2018, 13:33   #65  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Morning,
The problem is in your Oppo.
As tebasuna51 may confirm, all the DCA elementary streams generated by ffdcaenc receive the OK from the Verify Button of the application DTS-HD StreamTools. The decoder in your Oppo expects some, let's say, "details" that are present in the streams created by the licensed encoders but are absent from the streams created by ffdcaenc
Midzuki is offline   Reply With Quote
Old 2nd July 2018, 15:37   #66  |  Link
SeeMoreDigital
But that does not explain why DTS streams created by other DTS encoding softwares work perfectly fine...
Old 2nd July 2018, 18:11   #67  |  Link
Midzuki
Unavailable
Midzuki's Avatar
other DTS encoding softwares — please name them.
The Master Audio Suite is from DTS, Inc. themselves.
Minnetonka Surcode is licensed and certified by DTS, Inc. themselves.
The DTS plug-in(s) for Pro Tools: idem.
¿Am I missing something?
Old 2nd July 2018, 18:33   #68  |  Link
SeeMoreDigital
Commercial/payware ones!
Old 2nd July 2018, 19:55   #69  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Therefore......
Yes, it does.
1) quoting the author of the original source-code of dcaenc:
«this encoder uses only the most basic compression techniques defined in the DTS specification,
and thus cannot win any comparison with commercial DTS encoders.»
https://github.com/filler56789/ffdca...ING_ISSUES.TXT
Old 2nd July 2018, 20:21   #70  |  Link
SeeMoreDigital
Indeed... We already know all this.
It's a shame that development has gone quiet since the last release.
Old 15th March 2023, 01:21   #71  |  Link
WSC4
I am experimenting with this but only using 2 channels (stereo) for the moment. This is for a video DVD.
From post #46, there exist two more "DVD-compliant" bitrates.
(for 2.0 and 2.1 only)
503.25kbps and 377.25kbps
I'm also using Muxman to multiplexer/author to a VIDIO_TS folder.
Using: ffdcaenc -i Test_1.wav -o Test_1.dts -b 377.25 or ffdcaenc -i Test_1.wav -o Test_2.dts -b 503.25
I get this error when adding the DTS audio file in Muxman:
Is this a bug with Muxman or are my ffdcaenc parameters wrong?
WSC4 is offline   Reply With Quote
Old 15th March 2023, 02:39   #72  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
As I researched some years ago I had these bitrates listed, but greyed out.
Don't remember the reason anymore, but most of that information came from mpucoder,
and I believe he left these out for a good reason.
Old 15th March 2023, 11:04   #73  |  Link
filler56789
SuperVirus
filler56789's Avatar
Probably a "feature" of Muxman, not a bug (or a design flaw).
Have you ever tried other DVD-authoring tools such as dvd-author and DVD-lab PRO?
I suppose no real-world DVD-player supported those bitrates
«Your software patents have expired.»
filler56789 is offline   Reply With Quote
Old 15th March 2023, 11:28   #74  |  Link
tebasuna51
tebasuna51's Avatar
Recode the audio to AC3 (192/256 Kb/s is enough for 2.0) with ffmpeg.
Old 16th March 2023, 00:57   #75  |  Link
WSC4
ffdcaenc -h
-- NOTICE: the values 377.25, 503.25, 754.5 and 1509.75 AT _48kHz_ are exceptions.
Test_1.wav is 2 channel stereo.
ffdcaenc -i Test_1.wav -o Test_1.dts -b 754.5
ffdcaenc -i Test_1.wav -o Test_2.dts -b 1509.75
These did work and MuxMan accepted them. It does not bother me that 377.25, 503.25 are rejected. I would always use the higher bitrates.
As a coincidence, I just installed DVD-lab (their free version) and no problems with 377.25, 503.25 bitrates. I shall burn these to a DVD to see if they play - and sound correct - in DVD players.
Thanks for the suggestion, but the audio is important and the original is LPCM 1536 kbps.
Old 16th March 2023, 06:40   #76  |  Link
junh1024
Numbers aren't absolute. Free AC3 encoders are about 1.4x as efficient as pro DTS and pro AC3 encoders are about 1.8x as efficient as pro DTS at the same bitrate. I would go with 256kps AC3 as they said.
junh1024 is offline   Reply With Quote
Old 16th March 2023, 08:11   #77  |  Link
filler56789
SuperVirus
As I have already said so many times before ,
DCA at 1536 kbps is overkill even for 5.1 audio,
1344 kbps should be sufficient in this case.
For 2.0 or 2.1 streams (at 48 kHz),
the maximum bitrate should be 510 kbps.
But if one feels happy with "FM radio quality" ,
they don't have to go above 340 kbps.
