23rd March 2014, 13:13 | #21 | Link | |
(default is 4) Code:
int target_usage = 4; if (!strcmp (preset, "placebo")) target_usage = 1; if (!strcmp (preset, "veryslow")) target_usage = 2; if (!strcmp (preset, "slower")) target_usage = 2; if (!strcmp (preset, "slow")) target_usage = 3; if (!strcmp (preset, "fast")) target_usage = 5; if (!strcmp (preset, "faster")) target_usage = 6; if (!strcmp (preset, "veryfast")) target_usage = 6; if (!strcmp (preset, "superfast")) target_usage = 7; if (!strcmp (preset, "ultrafast")) target_usage = 7; |
23rd March 2014, 14:42 | #25 | Link |
Hmm... This has now happened twice: I've tried to re-encode a Blu-ray 3D title into full 3D MVC .ISO, but for some reason BDtoAVCHD attempts to output 2D. I double-checked that "3D MVC" was selected in 3D Mode Selection, but the encode failed. Here's the error log and other data:
-[23/03/2014 - 11:49:28]-------------------------------------------------------------------------------- LAST CMD LINE => "C:\Program Files (x86)\BDtoAVCHD\x264\x264.exe" --preset "veryslow" --tune "film" --bluray-compat --level "4.1" --vbv-bufsize 30000 --vbv-maxrate 40000 --bitrate 30537 --stats "F:\_TEMP\SPIDERS [2D+3D].ISO.job_0.stats" --keyint 24 --open-gop --slices 4 --frame-packing 14 --qpfile "F:\_TEMP\SPIDERS [2D+3D].ISO.job_0.qpfile" --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 1 -o NUL "" EXIT CODE => -1 (0xFFFFFFFF) -------------------------------------------------------------------------------------------------------- Code:
ffms [error]: could not create index lavf [error]: could not open input file raw [error]: raw input requires a resolution. x264 [error]: could not open input file `' via any method! update: After some testing, it looks like I need to close and restart BDtoAVCHD after every encode to avoid this problem. Last edited by colinhunt; 23rd March 2014 at 19:08. |
23rd March 2014, 17:44 | #26 | Link |
While testing 3D output from BDtoAVCHD I came up with a couple of feature requests:
1) the program should keep a database of source bitrates, so I wouldn't have to scan them every time when running several backups of the same title 2) also, for several backup runs, demuxed source files should not be deleted automatically like they are now; the program should be able to use previously demuxed files to speed things up |
23rd March 2014, 19:07 | #27 | Link |
Ran a quality=3 backup of Gravity, and it looked fine. Ran another backup, this time with "placebo" (quality=1) and it came out garbled. Base view is fine, but dependent view is messed up. Did another run with quality set for 2, and that came out garbled as well.
23rd March 2014, 23:18 | #28 | Link |
Heh. I tried to make a 3D MVC backup of "3 A.M.", a Thai horror movie, and the process seems to have stopped at 100%, just before remuxing. Status line has read "MVCenc [100.00%] 136060/136079 frames, 65.54 fps, eta 0:00:00" for a couple of hours now, and nothing happens.
The very last line of MVCenc_log.txt is: "fps, eta 0:00:46 MVCenc [97.8%] 133089/136079 frames, 65.59 fps, eta 0:00:45 MVCenc [97.9%] 133155/136079 frames, 65.59 fp" Last edited by colinhunt; 23rd March 2014 at 23:21. |
24th March 2014, 11:35 | #29 | Link |
I made a conversion, GRAVITY with target_usage = 1, i7-3770k same grahic drivers and result are perfect, so seems that cause of "garbled" is other than target usage = 1.
For everything you mention seems that your system is unstable and fail randomly. I cannot reproduce anything you mention. I have also checked the source code and for example the x264 command line --frame-packing 14 cannot generated by my program and no sense Code:
KODI 19 Matrix HDR Windows API BDtoAVCHD - One Click Blu-Ray to BD5/BD9/BD25/MKV MVCsource – MVC 3D Avisynth Source Plugin MVCenc – MVC 3D Encoder Last edited by pistacho; 24th March 2014 at 11:39. |
24th March 2014, 11:56 | #30 | Link | |||
24th March 2014, 12:14 | #31 | Link | |||
24th March 2014, 12:27 | #32 | Link | |||
About the garbled output: I've only tried playing the output on Stereoscopic Player so far. I haven't burned the data on a BD-R to test on a stand-alone, because target_usage=3 output plays perfectly on Stereoscopic Player, but u:1 and u:2 do not. I'll have to find a BD-RE disc to try the output on a standalone player. Quote:
25th March 2014, 09:42 | #33 | Link | ||
KODI 19 Matrix HDR Windows API BDtoAVCHD - One Click Blu-Ray to BD5/BD9/BD25/MKV MVCsource – MVC 3D Avisynth Source Plugin MVCenc – MVC 3D Encoder Last edited by pistacho; 25th March 2014 at 09:59. |
25th March 2014, 10:47 | #34 | Link | ||
Hmm. Can I force BDtoAVCHD into using software decoding and hardware encoding, or vice-versa? I remember a while back, when testing FRIMEncoder, I got garbled output when decoding was done in hardware. Image corruption went away when I switched to software decode + hardware encode. |
25th March 2014, 11:50 | #35 | Link | |
MVCenc uses HW decoding + HW encoding (if available) and since uses only one loop (common for encoding + decoding) is not easy to do one process in SW and other in HW. But, for testing proposes, you can force SW decoding + SW encoding renaming Intel Media SDK path to something: Code:
C:\Program Files\Intel\Media SDK => C:\Program Files\Intel\Media SDK__ Also I think that root cause of your Quick Sync HW problems may be in BIOS video memory settings. For example select a greater value of video memory size 128MB or 256MB or more. (this is just an example image that I found on google. Another time I will look like I have it on my system)
KODI 19 Matrix HDR Windows API BDtoAVCHD - One Click Blu-Ray to BD5/BD9/BD25/MKV MVCsource – MVC 3D Avisynth Source Plugin MVCenc – MVC 3D Encoder Last edited by pistacho; 25th March 2014 at 11:54. |
25th March 2014, 14:04 | #36 | Link | |||
4th October 2014, 16:49 | #37 | Link |
New version 2.2.1
Version 2.2.1 (10/04/2014) - Updated to Intel Media SDK 2014 R2. - Added Kb/s written to disk on progress/eta status message. - Fixed: in some cases, last four or six frames of input stream are not encoded. |
3d blu-ray encoder, mvc encoder, mvcenc |
