Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD burning
Old 28th February 2013, 17:46   #1  |  Link
rbaron
DVD Styler Question
First, I am hoping this is the correct place for this question???
I am trying to learn DVDStyler. I am new to creating DVD's and throughout the threads it seems that everyone is happy with DVDStyler.
However, when I launch the program and do all the appropiate chosing of the menues etc, it seems like the initial process never stops.
I have enclosed a screen shot of the program doing what it is doing. The green bar never seems to finish.
I am loading on one movie file in .mkv format wheich is 2.2GB big.
Should I just let it do what it is doing? Will it ever stop and finish?
Thanks in advance for any help...
rbaron is offline   Reply With Quote
Old 3rd March 2013, 03:17   #2  |  Link
manolito
manolito's Avatar
If it stops right there in the middle of transcoding there is a good chance that your source file is corrupt...
DVDStyler uses libav (or ffmpeg) for transcoding. Maybe you should use a different ffmpeg GUI (e.g. WinFF) just to make sure that your source MKV can be transcoded at all...
Good luck
manolito
Old 3rd March 2013, 14:10   #3  |  Link
rbaron
Thanks I'll give it a try.
