Old 30th January 2013, 01:26   #21  |  Link
mini-moose
Originally Posted by paradoxical View Post
Yeah it didn't take anywhere near that long and that's with quite a few things running at the same time.
here are the switches I used:
--palette-mode keep --resolution 720 --fps-target keep --filter mitchell
mini-moose is offline   Reply With Quote
Old 30th January 2013, 01:32   #22  |  Link
paradoxical
Posts: n/a
So it seems I was subtracting time wrong using my clock so I did one more test run after warming up the JVM so it can hotspot things:
Java version 5.1.1: 4 minutes 55 seconds.
Current 1.0.1 build of ++: 4 minutes 35 seconds.
So it's about a 7-8% difference once I warmed up the JVM. And again, this is on a 2.3ghz quad core i7 Ivy Bridge. So, I don't know why you got nearly 29 minutes. That's pretty insane. Maybe the difference is running it via CLI. I did my runs via the GUI. I can test that.
Old 30th January 2013, 01:36   #23  |  Link
mini-moose
yes pretty insane indeed. and there's nothing else running that
takes any cpu cycles. I did try the gui too for a bit and it reached about 15% after 5 mins so pretty much on track to the same processing time.
Old 30th January 2013, 01:40   #24  |  Link
paradoxical
Posts: n/a
Okay, so there is something weird going on on your end especially if you aren't running anything else. Just to give you an idea of my system at the moment, I'm playing CounterStrike: Global Offensive and running a Windows VM in Parallels that is doing some BD Reauthoring. So it's not a lightly tasked system while doing the tests.
Also, via CLI gave me a time about 5 seconds off from the GUI in the ++ version.
Old 30th January 2013, 10:39   #25  |  Link
Selur
Selur's Avatar
Thanks for the new binaries, btw. you might want to add a '(Mac OS X 10.7+)' or something to the mac to avoid confusion.
Old 30th January 2013, 11:19   #26  |  Link
mini-moose
yes indeed weird. I just tried again. Same thing. Tried the java and it did it in like 2-3 mins..
also the gui shows a very erratic behaviour for me. It's not unique to the latest version - maybe the 3rd one described below is, others were happening before too. I usually don't use the gui.
upon launch, console window flashes for a sec but I think that was discussed before.
when I try to load a sup I get this several times:
http://i.imgur.com/y5jIYos.jpg
and when I try to save/export this pops up several times:
http://i.imgur.com/zNT4cmj.jpg
I have to close this window and try save again quite a few times till I manage to get it working.
Old 30th January 2013, 14:46   #27  |  Link
Music Fan
Originally Posted by Music Fan View Post
Now it works with the long file name while I didn't change anything.
I had the same problem today with the same file : first it crashed, then I retried and it worked.
Music Fan is offline   Reply With Quote
Old 30th January 2013, 15:32   #28  |  Link
paradoxical
Posts: n/a
Done. Wish I could make it compile to 10.6 but the #ifdef effort would be enormous to allow that.
I don't know what to tell you. I ran it a few times again this morning with less system load and both are in the 2-3 min ballpark with the Java still about 10% slower.
Can't say I've ever seen anything like either of those screenshots on any OS I've run it on. And yeah, the console issue is something that can't be fixed in the application. I release the console as fast as is possible. It's purely a Windows issue with respect to Qt. Neither OS X or any of the *nix systems do it. Again, the only way to fix this is either on Qt's end or to make separately-compiled applications. Neither are very likely.
I opened it 20 times in a row and none of the times it crashed. Comparable link paths as I said yesterday. As I said, the application does nothing but pass the file path on to the QFile constructor. Any path length issues would come down to OS limits and on Windows that is 260 characters IIRC.
Last edited by paradoxical; 30th January 2013 at 16:36. Reason: Add more information about console flash
Old 30th January 2013, 17:06   #29  |  Link
paradoxical
Posts: n/a
So good news for you mini-moose. After more investigation, I've isolated the speed issue and it's a total facepalm moment on my part. That Windows binary was compiled with -O0, no optimization, and debug symbols and I forgot to revert these when I compiled it for posting. The binary has now been replaced with the proper release build. That was why you saw vastly different results than when I was testing on my Mac Mini. Now, it's still slower to output since neither the Java or ++ is not detecting the image area properly, it's saying the entire 1920x1080 area is the "image area" which is not right, which accounts for why it takes longer than other BDSups to convert and output that I've tested. That I will investigate and try to track down.
Edited to add:
mini-moose where did you get that file from?
Old 30th January 2013, 20:22   #30  |  Link
paradoxical
Posts: n/a
So I have a fix that will find the image area in the case of a pathological subtitle file like you sent me mini-moose. To find the image area doesn't increase processing time much more than not doing it. The best you can do with subtitles such as that is to load it, resave it without scaling, then scale. Or just accept that the time it takes to do the bounds checking and scaling.
Old 30th January 2013, 20:29   #31  |  Link
mini-moose
Edited to add:
ok I will reget it and test!
what file? the sup or the binary I used?
Old 30th January 2013, 20:34   #32  |  Link
paradoxical
Posts: n/a
That "english.sup" file that you posted in the other thread. That thing is something pathological. Looks like it was output incorrectly. It's got no data for image offset, etc so both the ++ version and Java see each subtitle image as the full 1920x1080 frame. That's why processing it is sooo slow.
And actually my post right above you was incorrect. Finding the image area before scaling reduces the time to save to about 24.5 seconds rather than it taking a couple of minutes. If you wait a few mins I'll post a new test version for you with the fix for that case in it.
Old 30th January 2013, 20:43   #33  |  Link
mini-moose
it's from some horror movie blu-ray. I find that those sort of odd sups are often found on horror movies (usually colored too, yellow in this case). If you load it on something like SupRip you will see the letters are very tiny. When converted to vobsubs they look the normal size.
Ran the sup again with the new version and it took around 4mins (resized to 1280x720 with Mitchel).
I'm quite relieved to see it wasn't my system to blame
thanks!
edit: tried the gui now too and at least on first try it didn't display the symptoms I described earlier.
Old 30th January 2013, 20:44   #34  |  Link
paradoxical
Posts: n/a
It'll take you far less than that once I finish compiling a new version with a fix for it. Went from ~3 minutes to ~24 seconds.
Old 30th January 2013, 20:46   #35  |  Link
paradoxical
Posts: n/a
Here is a test version with that fix. I checked some other BDSups to make sure nothing got regressed with the fix and I didn't see anything, but if you see that it broke anything please let me know. Won't compile another "official" version till I finish the other issues slated for 1.0.2 release on the issue tracker.
Old 30th January 2013, 21:02   #36  |  Link
mini-moose
nice one it took 22secs with resize to 720p and 12secs for 1080p (1080 is always faster).
one thing I want to ask - the last lines on cmd output is
Decoding frame 1145/1269 at offset 01ad769b
There were 144 warnings
There were 1048 warnings
As I said before I have 0 understanding but shouldn't it end with
1269/1269 ?
also a small request if possible. Can you tag the archive and binary with some sort of version number? It can get a little messy when there are several versions around.
Old 30th January 2013, 21:04   #37  |  Link
paradoxical
Posts: n/a
1269/1269 ?
I'll look into it. There was an issue like that with the GUI's progress bar stalling then immediately finishing even the processing was fine that I fixed a while back.
Yeah with 1.0.2 I'll put version in the archive name. The application itself always has the version number in the title.
Old 30th January 2013, 21:11   #38  |  Link
mini-moose
ok. I usually just rename them myself, cause if I have a few versions like in this case and I want to be able to compare their performance it's easier to have the exe tagged differently. This way I can have all of them running from the same location (since I use a .bat to call them).
another small note: the 101 fixed .sub is 6.2mb (like the java output) and the test version .sub is 4.4mb. Whether it means anything..I have no idea
Old 30th January 2013, 21:13   #39  |  Link
paradoxical
Posts: n/a
It's due to the fix I made. The test version crops the bitmap to the image area like would happen with any other SUP instead of it being the full 1920x1080 frame.
Old 30th January 2013, 21:15   #40  |  Link
mini-moose
ok cool, just pointing out differences in case they have some meaning. You will need feedback from the more advanced users regarding potential issues.
At the time it was discussed the ++ version will be able to eventually generate 3D subs too from 3D sourced sups. Is that something you're planning to look into ?
