Old 23rd September 2014, 16:39   #61  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Cool! Is it completely native now I thought there were some functions unported yet.
...desu!
Mystery Keeper is offline
Old 23rd September 2014, 16:51   #62  |  Link
HolyWu
Of course not. Only filters that listed at https://github.com/dubhater/vapoursy...1.1/readme.rst get changed.
HolyWu is offline
Old 24th September 2014, 10:30   #63  |  Link
Mystery Keeper
Beyond Kawaii
Can you please give a link for r9 too? So far VS MVTools is buggy, and QTGMC crashes even though I'm not using DCT.
...desu!
Old 24th September 2014, 13:48   #64  |  Link
HolyWu
No problem. First post is updated. It may be helpful to let jackoneill know what preset or arguments you specified to make it crash. I just let it run on a 1920x1080 clip about 10000 frames with all default values and don't encounter crash. The average speed is roughly at 5.0 fps.
HolyWu is offline
Old 25th September 2014, 03:10   #65  |  Link
lansing
I tried the new version with native mvtools added, on my 720x480 video, qtgmc(preset="medium"),
vapoursynth 32bit: 94fps
vapoursynth 64bit: 94fps
avisynth mt mvtools: 125fps
Updated the result for Vapoursynth 64 bit version, kind of disappointed. I was expecting it to be much faster.
lansing is offline
Old 10th October 2014, 08:48   #66  |  Link
HolyWu
Updated r11.
The mvtools-related filters used in QTGMC and ivtc_txt60mc are all native now.
Because QTGMC's SVThin and Lossless modes require rgvs.VerticalCleaner, I also include RemoveGrainVS.dll in the archive so you don't have to wait for the next release of VapourSynth.
HolyWu is offline
Old 4th November 2014, 09:13   #67  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Why do we have to do?
import havsfunc
haf = havsfunc.HAvsFunc()
clip = haf.QTGMC(clip, Preset='Medium', TFF=True)
Wouldn't it make more sense to remove the HAvsFunc class that effectively does nothing so we can do:
import havsfunc as haf
Myrsloik is online now
Old 4th November 2014, 15:23   #68  |  Link
HolyWu
You are right. The class was used to let users pass the core instance to the module before VapourSynth R19. Since the core now uses a singleton pattern, the class becomes redundant. I just didn't think of doing the modifications though...
HolyWu is offline
Old 25th December 2014, 17:30   #69  |  Link
HolyWu
Update r12.
  • The class is ditched so you can reduce one line in your script.
  • Add function Vinverse2.
  • Delete function InterFrame.
  • DeHalo_alpha: Remove the color family restriction of input clip.
  • HQDeringmod: Remove the color family restriction of input clip. Remove dering kernel 'dfttest' and related parameters. Remove stack16 related parameters.
  • QTGMC: Remove EdiMode 'nnedi2', 'nnedi', 'eedi2' and 'tdeint'.
  • Vinverse: Remove the color family restriction of input clip.
  • GSMC: Use native filters of MVTools. Remove lsb parameter.
  • SMDegrain: Use native filters of MVTools. Remove stack16 related parameters. Change prefilter=3 to MinBlur(3).
  • FastLineDarkenMOD: Remove the color family restriction of input clip.
  • LSFmod: Remove the color family restriction of input clip. Change the type of parameter 'preblur' from string to bool.
HolyWu is offline
Old 25th December 2014, 19:58   #70  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Is your vinverse different from the one in the VapourSynth source tree?
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline
Old 25th December 2014, 20:36   #71  |  Link
Reel.Deel
Vinverse2 is a modified version of Vinverse used as a helper this dot crawl removal script. tp7 also included a fast implementation in his Vinverse plugin.
Edit: oops, I completely misunderstood jackoneill's question. I honestly thought he asked about vinverse2. The eggnog must of been a little stronger this year
Reel.Deel is offline
Old 26th December 2014, 05:10   #72  |  Link
feisty2
I'm Siri
feisty2's Avatar
edit: okay, it's wrong, just tried and the result is completely different from mdegrain
I thought something from here could be useful
any luck with mcompensate + templinearappoximate to imitate "mdegrain (lsb=true)" ?
feisty2 is offline
Old 26th December 2014, 15:13   #73  |  Link
HolyWu
I think the only difference is high bitdepth support.
HolyWu is offline
Old 28th December 2014, 22:16   #74  |  Link
MonoS
I've also ported a avs script to vs, if you want you can add it to your collection [so that as much script will be available in only one place].
The original script is here http://recensubshq.forumfree.it/?t=64839203
The code is here: https://github.com/MonoS/VS-MaskDetail
The thread is here: http://forum.doom9.org/showthread.php?t=171546
MonoS is offline
Old 17th January 2015, 01:33   #75  |  Link
lansing
Hi, I'm getting an error while using deblock_qed.
No attribute with the name dct exists. Did you mistype a plugin namespace
ret = haf.Deblock_QED(ret, quant1=40, quant2=24)
I'm using the latest Vapousynth, mvtools and deblock plugin.
lansing is offline
Old 17th January 2015, 01:50   #76  |  Link
Are_
dctfilter
Next time you can search for the missing dll here.
Are_ is offline
Old 17th January 2015, 02:00   #77  |  Link
lansing
thanks, it works now
lansing is offline
Old 31st January 2015, 13:02   #78  |  Link
Mystery Keeper
Beyond Kawaii
MVTools now support up to 16 bits and other formats. Functions need to be fixed to add that support too.
...desu!
Old 2nd February 2015, 16:44   #79  |  Link
HolyWu
Update r13.
  • Remove the format restriction of the following functions: QTGMC, GSMC, SMDegrain.
  • SMDegrain: Use sbr for prefilter instead of MinBlur.
HolyWu is offline
Old 4th February 2015, 06:54   #80  |  Link
zerowalker
SMDegrain acts a bit different compared to the Avisynth version on the same settings.
Is there some Default settings that are different?
SMDegrain(tr=2,thSAD=500,search=3)
That's what i tested and compared with.
zerowalker is offline
